09-24-2019, 06:16 PM | #1 |
dad bod
387
Rep 382
Launch control failure after XHP tweaks, two fault codes. Any ideas?
Car is a 2014 335i xDrive 8AT, FBO E30, and has 55k miles. Was at Great Lakes Dragaway (1/4 mile track) the other night testing my car after flashing XHP. Car performed no better than it had before with the stock transmission tune and was seeing 60' times in the 1.8-1.9 range. I increased the "Launch Torque" (without touching the "Torque Scaling After Launch" slider) by 20%, and the car launched HARD and felt great but bogged horribly on the 1-2 shift. I then increased the "Torque Scaling After Launch" slider by 20% so that it matched the Launch Torque percentage.
This time the car revved up past 3k RPMs (it had never done that before) and then the converter "let go" (in other words, despite my foot on the brake pedal the car rolled forward) and I got a Drivetrain Malfunction warning. Pulled off the track and turned the car off to let it cool down. Did a quick scan and got these two codes: 48068C (DSC) transfer case - clutch temporarily shut down, possibly overheating. BMW fault code lookup says, "Clutch control temporarily reduced by transfer case control unit. This measure avoids the clutch overheating. There may be customer complaints concerning the all-wheel control (traction). No repair measures required (self-healing in same ignition cycle possible)." 440117 LMV_FR No description available. BMW fault code lookup says, "Possible fault causes: - Excessive thermal load on the clutch of the transfer-case servomotor. - Excessively high thermal load of the transfer-case servomotor. - Excessive delay in starting procedure. Some things to note: - After the XHP flash, I drove the car gently and normally for 50 miles as the manual recommends. - Did 6 runs. I waited 20-30 minutes between each run to let the car cool down. - The car shifts sluggishly in general, seems even more so after the XHP flash, though that could be a placebo effect. - BMW of Elmhurst performed a transmission fluid change a few months ago, but reused the original filter, assuring me it would be fine. Which has me worried that it's NOT fine and that there may be a leak. Of course, I can't check as there's no dipstick and I don't have the time/tools to check the correct way. I'm not suggesting AT ALL that this is XHP's fault. My guess is user error, or I was too aggressive with the torque adjustments. Taking the car to a trusted indy mechanic later this weeks, but what do you guys think? Is my transmission on the way out? Also, does anyone know what the "Torque Scaling After Launch" slider in XHP actually does? The manual doesn't really explain it clearly and I can't find an answer on the forums.
'15 F30 Estoril Blue 335i xDrive | 8HP | Stock Turbo | 420 awhp / 451 awtq | 11.85 @ 115 mph
E30 JordanTuned on BM3 | XDI-60 HPFP | Fuel-It! lines + sensor | VRSF FBO | GFB DV+ | XHP | Vörsteiner VFF-107s | Dinan Springs |
09-25-2019, 04:52 PM | #2 |
121
Rep 470
FWIW the app allows that customizability. I don't think it would be too far to say this is xHP's fault. That said, they're not going to cover anything that breaks. Definitely makes me weary to purchase as I'd like a bit of safety built in, not a possibility that I grenade my transfer case.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
09-25-2019, 06:24 PM | #3 |
485
Rep 1,105
Anytime you modify your car past stock settings you knowingly run the risk of damaging your car.
Although XHP should give better instructions on how to use some features, it's still up to the end user whether they want to use their car as a guinea pig to use a new feature. Taking it to the race track to test it where there is maximum tracking due to a prepared track might of not been the ideal place. But if I'm not mistaken x-drive has been know ton have transfer case issues so that could also be a contributing factor. |
09-26-2019, 07:16 AM | #5 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
Subbed.
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
09-26-2019, 02:44 PM | #6 |
Check out my Youtube @n55david!
1296
Rep 3,533
Drives: 2017 m240i, 2015 X3 x35i
Yeah, any update?
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
09-26-2019, 10:27 PM | #7 | |
dad bod
387
Rep 382
Hey folks, sorry for the delay on the update. Car is seemingly running strong. No fault codes stored and no new ones have popped up. Shifting is still sluggish but it was like that prior to the XHP flash.
My (uneducated) guess is that I was too aggressive with the torque settings. Regardless, I went ahead and ordered a transmission service kit and I'm having my indy shop change the fluid (AND the filter). I'll keep y'all posted. Quote:
By the way, anybody have any idea what the "torque scaling" slider does?
09-27-2019, 02:20 AM | #8 | ||
Driver
200
Rep 516
09-27-2019, 08:32 AM | #9 | |
1478
Rep 1,286
From XHP manual “The amount of boost/torque your car is allowed to build while the brake is depressed is setup with the "Set Launch Torque" slider. After releasing the brake the Car tries to manage torque and traction along programmed presets which can be tuned up and down with the "Torque Scaling After Launch" slider. 0% is the factory setting and is optimized for stock cars. Tuned cars may need different settings.”
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
09-27-2019, 12:10 PM | #10 | |
dad bod
387
Rep 382
Also, my experience has been the same re: comfort mode, however the sluggishness is present for me regardless of mode and regardless of map (stock, XHP 1-3, or BM3's transmission flash), which is a bummer. I remember when I first coded 2TB (when the car was stock) the shifts were LIGHTNING quick. Really hope I'm not murdering my transmission.
09-27-2019, 12:13 PM | #11 |
Yoda of mods
1674
Rep 3,006
Drives: X5 RWD
09-27-2019, 12:14 PM | #12 | |
dad bod
387
Rep 382
"After releasing the brake the car tries to manage torque and traction" -- okay, that still doesn't explain what the percentage value actually means or affects! My frustration isn't towards you, btw, it's towards the wording in the manual
10-11-2019, 10:39 AM | #13 |
dad bod
387
Rep 382
Update for whoever’s wondering:
This was 100% user error! Also I need new brake pads. Luckily I had the failure on in-car video finally watched it. I’d looked through the datalog and couldn’t figure out how I overrevved so dramatically during the LC procedure. But looking at the video, right before the revs go crazy, the car lurches forward slightly. I was able to recreate it in the pits last Sunday. Basically, my brake pads are pretty worn down and/or I may need new fluid or something else is going on. I engaged launch control and simply wasn’t pressing down hard enough (though I WAS pressing down very firmly as I have many, many times) — the car lurched forward, and when that happened I slammed on the brakes to try to keep from redlighting — well the TCU assumed I’d launched, and released the rev limiter. Revs go way past 4k, error error error. I’m horrible at explaining this, sorry. TL;DR — I wasn’t using the might and fury of a viking warlord to hold the brake pedal down during LC, so the brakes didn’t hold and the TCU thought I launched, disabling the LC limiter and allowing me to nearly blow up my transmission. NOT XHP’s fault. I’m an idiot and also need to service my brakes. I still don’t understand exactly what the torque scaling slider does though. |
07-01-2020, 08:46 AM | #14 |
43
Rep 170
A bit late but torque scaling is essentially how fast the car allows itself to ramp up to 'max torque' which is the engine's full output capability. This exists partially to prevent drivetrain shock and partially to prevent a sudden wave of torque from breaking traction immediately after launch.
Also I have no idea why they didn't change the filter for you. Its like a $100 part and really easy to swap. While I'm here reviving did the trans behave any better after the second fluid swap with filter? |
