Intermittent steering wheel shake issue
09-22-2019, 10:25 PM | #1 |
Rep 27
Perhaps someone on here can help shed some light...
My 08 335i has an odd issue where every so often, maybe 3,4 times a week, I leave work, and going in a straight line my steering wheel shakes as if the tires are out of balance, and that shake translates into the brakes if I slow down while the symptoms are occurring. though the tires were changed (mounted and balanced) just before I bought the car... Also the fact that it is present all the way to highway speed, but only for a short while (usually doesn't last more than the first stop sign or two) and not consistently, (it's been two weeks between the last time this happened and Friday.) just makes it really hard to believe it could be a balance or alignment thing, steering wheel is straight when I drive. I've read around on other forums and E46 get it sometimes if a rim is bent out of shape but I find that kind of hard to believe given this car's history... (service records, clean carfax.) Any ideas? -R |
09-23-2019, 05:56 AM | #2 |
20
Rep 65
Drives: 2007 E90 318i
Please let me know your findings, as I am having the exact same issues.
Thanks |
09-23-2019, 08:20 AM | #3 |
263
Rep 1,225
Service records and clean carfax wouldn't tell you anything. It could be bad shocks or struts or possibly a bend rim or out of round tire. The prior owner may have driven over a huge pot hole, or something, and damaged the rim without them realizing it or jogged the shocks or struts loose.
Do you have a compact spare? If so, try swapping out each tire one at a time and drive it around. If the vibration stops, then you will know what tire/rim it is.
2010 BMW 335i: Monaco blue metallic/Premium+Sport Auto-Steptronic, BMW PE, Cobb Stage 2
2005 Mustang GT: Redfire metallic/5-spd/Ford Racing (Axle backs, silver Bullitt wheels)/K&N CAI/ Diablo Sport Predator Tuner 1997 Toyota Corolla 1983 Mercedes Benz 380SL Roadster |
Red_Tears6.50 |
09-23-2019, 08:34 AM | #5 | |
Rep 27
Will definitely do so next time I notice it. Thanks for the suggestion! |
09-23-2019, 11:46 AM | #6 | |
263
Rep 1,225
BMW 5 SERIES Spare tire and Jack: 525 528 535 545 550 (2004 2005 2006 2007) BMW 3-SERIES Spare tire and Jack: E9X: 323, 325, 328, 330 (Up to 2006) BMW 3-SERIES jack only: E46 (1998 -2007) Good luck.
Red_Tears6.50 |
09-23-2019, 12:52 PM | #7 | |
Rep 27
09-23-2019, 02:23 PM | #8 | |
2738
Rep 4,065
I would suggest trying some/all of the following as deemed appropriate: 1) rotate the tires diagonally, 2 at a time (e.g. LF to RR) assuming no stagger; Drive until problem recurs and compare "feel"; 2) When issue recurs, see if problem gets better or worse when you "load" Left side (in RH Turn) or "load" R side (in LH Turn); 3) Test to see if there is any "Pull" to the L or R when you apply brake moderately OR when you release the brake pedal; a sticking caliper will often pull more to the sticking side when you RELEASE the brake pedal, as the pads on that side still contact the rotor. QUESTIONS: a) When you say "steering wheel shakes" do you mean you feel "vibration" in the steering wheel, or does it oscillate circumferencially -- Left to Right, as a "warped rotor" causes when applying brakes? b) When you apply the brakes slowly or moderately, does the nature or degree of "steering wheel shake" change, and HOW? c) Does the occurrence of the shake seem related to any identifiable factor such as ambient temp; wetness of roadway; distance or time traveled and/or temperature buildup in components; length of time the car has sat unused before? d) What brand, type & size of tires are installed, and are all 4 the same? e) Have you examined the tire tread & sidewalls for any clues such as irregular tread wear, cupping, bumps or irregularities in sidewalls or tread? f) Have you carefully examined the wheel rims, on BOTH the inboard & outboard sides, for any bend or crack, such as results from pothole impact, particularly if you have 50 profile or less? g) Has the problem been present since you bought the car, or if NOT, was there any event (such as bumping a curb, hitting a pothole, etc.) that preceded its emergence? My SWAG on info furnished thus far is a tire issue of some sort, so the suggestion to swap in a spare, one wheel location at a time, is a good idea. If it takes 2 weeks to recur, that process may take awhile. Rather than getting a donut, why not go to a salvage yard and get a full-size replacement wheel, or even buy a new wheel of same type as on your vehicle and mount a tire of same type, so now you have a spare wheel at home that you can rotate to keep all 5 same tread depth, or have available if you get a flat or tire damage. You DO carry an air pump & plug kit I presume? Please let us know what you find, George |
Red_Tears6.50 |
09-23-2019, 03:11 PM | #9 | |||||||||||
Rep 27
Thanks for the input, -R |
