09-21-2019, 12:05 AM | #1 |
143
Rep 242
Drives: 2013 328i 6mt
Aftermarket Clutch Recommendations
My oem clutch started slipping today... anyone here have a recommendation for a 6 speed MANUAL F30 328i clutch? Making quite a few horsepowers over stock.
Thanks!
F30 328i 6mt
Injen, ER, BM3, Solowerks, IND, BMS, BBS E46 M3 smg2 Bimmerworld, H |
10-09-2019, 06:18 PM | #3 |
Big Turbo Boys N Girls
327
Rep 579
If you want something to lost longer than 30K I would get the ZF Full face and NON SAC pressure plate. Otherwise you are stuck with Clutch Masters. Go with the Stage 3 as the stage 2 is just factory with copper in the disk.
You can also run any E90 328i clutch disk and any 335I pressure plate if you want to make a Frankenstein setup. I am currently running the ZF 4 puck and the 335I Non self adjusting pressure plate which is heat treated and pressure points wont shift like the problematic self adjusting pressure plates they use today.
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
rackjuediger143.00 Littlebear3509.50 |
10-09-2019, 07:13 PM | #4 |
1599
Rep 3,748
Wow... seriously this are all the clutch options available for the 3/4 series... Damn that sucks.
I'm happy I didn't have to worry about clutch anymore but I prefer to have manual if I'm still in the business of building car over 500 hp. |
