09-20-2019, 06:51 PM | #1 |
Rep 8
Will this work for N20 EWG?
Picked this JB4 PWG from a F10 520i owner. I have a few questions which I hope someone could help with:
1. Will this work on my F30 328i N20 with EWG? 2. Can this use the latest firmware? If yes, which one should I flash to? N20_OBDII_PWG_6.hex or N20_OBDII_EWG_6.hex? 3. Can this work with the latest revision of the JB4 connect kit? 4. The harness comes with 4 pairs of connector: rainbow, brown, black and blue. I know for EWG I can skip the blue connectors. How about the black wire connectors? 5. The harness also comes with a ground cable (and I think also a red power cable). Do I need to hook them up? If yes, I assume black to shock tower nut and red to +ve terminal? 6. Anything else I need to make it work? Im getting conflicting responses - some say it'll work for EWG up to map 2 while others say it wont work. Attached is a picture my JB4 for reference. Sorry for all these questions. Last edited by N20MY; 09-21-2019 at 03:24 AM.. Reason: More details |
09-21-2019, 12:40 AM | #2 |
242
Rep 804
make sure you it is a EWG jb4 or else it will not work since you have a EWG
bluetooth connect kit should work if hooked up right download the ewg hex files for installations https://www.google.com/url?sa=t&sour...5MsFV249zvUbFi |
09-21-2019, 01:21 AM | #3 | |
Rep 8
Getting more and more confused with conflicting responds. Some say it'll work up to Map2 on EWG while some say it wouldnt work.
09-21-2019, 08:27 AM | #4 | ||
242
Rep 804
