Unusual glowplug fault
09-19-2019, 11:23 AM | #1 |
Rep 6
Hey all,
So last winter my car started to having hard times starting in minus degrees. Carly said three of six plugs were off. I ordered a beru kit from ebay with 6 new plugs + module. Changed everything and now carly told me all 6 plugs were non functional. I thought plugs were bad and got 6 new plugs and changed AGAIN () Problem did not go away and plugs still did not work. I ordered a second module and switched, STILL SAME PROBLEM!? So another winter is coming and non of the plugs is working, what do you think the problem is ? Plugswires? +wire ? Carly is saying 1,2,3,4,5,6 glowplug nonfunctional. Car is a 325d m57 from 2009 (LCI) Module is BERU GSE 102. |
09-19-2019, 06:37 PM | #2 |
806
Rep 1,191
Maybe stating the obvious, but did you check the fuse?
Persian Whisperjet166.50 |
09-21-2019, 11:15 AM | #4 |
104
Rep 231
That power wire going across the valve cover to the passenger side i believe.... check that because mine was left loose after carbon cleaning and it threw some weird glow plug and glow plug module faults.
01-27-2020, 11:33 PM | #5 |
Rep 1
