Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > How can i make 2011 335d reliable
      09-19-2019, 11:14 AM   #1
bih_m3
Drives: 2009 BMW M3
Hello,
I'm planning on picking up a 2011 335d to ship to europe. I would like to know what preventative maintenance i can do before i ship. I want to make sure all the big problems are taken care of. If anyone can help that would be great also i know nothing about these engines but have heard they are good.
      09-19-2019, 02:03 PM   #2
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
Originally Posted by bih_m3 View Post
Hello,
You have strict orders to go read portions of the Mega thread please sir. It is in the list of stickys (very top one too).
Here is link to it in case you don't know where our stickys are.
https://www.e90post.com/forums/showthread.php?t=1334283
      09-19-2019, 05:55 PM   #3
335dlci
277
Drives: 335d
Agreed
      09-24-2019, 09:30 PM   #4
jdub486
273
Drives: 19' M2C dct/ e90 335d dd
Forgetting about the awful emissions system, I’d start by replacing the red boost hose, the top turbo oil feed line, and the harmonic dampener. And maybe vacuum lines depending on age.
      09-25-2019, 08:44 AM   #5
Thecastle
307
Drives: F10 550i
2020 BMW M340i  [0.00]
2019 RAM 3500  [0.00]
2020 BMW X3  [0.00]
2016 BMW 550i  [0.00]
2000 Ford F450 7.3l ...  [0.00]
In spite of what you read on the forums and my personal experience...... I can say a lot of folks make it well over 100k without emissions issues. If your car doesn’t have a history of problems it’s probably going to be okay for a while.
      09-25-2019, 02:44 PM   #6
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
Why not buy one in Europe.
      09-26-2019, 09:43 AM   #7
kbsilver
142
Drives: 340GT & '22 eDrive40
I am one of many without issues. 110K miles on the car, everything intact, bone stock, original injectors. In it's life the car had one CBU cleaning at 54K, NOx sensor at 70K, and replacement DEF tank (usual bad temp sensor) at 85K, all covered under warranty.
They did a ECU software update with the CBU cleaning and ever since then the car uses very little DEF, in the order of 1 quart per 1000 miles.
      09-26-2019, 01:07 PM   #8
335dlci
277
Drives: 335d
I'm at 106k now. Bought with 11k
Never had cbu. Methanol prevents this if you are atock equipped
      09-26-2019, 01:53 PM   #9
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
690
Drives: 2010 335d, 2014 328d
While I've had emissions problems (including NOx sensors and DEF tank replacement, etc.), the last couple problems have not been emissions related: glow plugs and controller, and throttle. They had the manifold off and the CBU was mild-to-moderate. 138K miles.
      09-26-2019, 04:10 PM   #10
dmanb2b
2125
Drives: G07, F97, F30, E90, E46, E30
I was about to ask the same thing and no DEF in European models
      09-27-2019, 01:05 PM   #11
Captain Buumer
126
Drives: 325D
About 310000 miles on mine, 325D though. Engine stock with DPF/EGR.
I use Common Rail fuel additive every fillup and change oil 6500 miles (both Liqui Moly products). Most reliable engine i've ever owned... just drive and enjoy.
      09-29-2019, 09:17 PM   #12
jdub486
273
My 335d has 80k miles. Quick break down of issues:
SCR cat failure 35k miles (warranty)
NOX Sensor failure 40k (warranty)
Glow Plug Mod Failure 55k (out of pocket)
Active Tank Failure 60k miles (warranty)
Red Boost Hose Failure 60k (out of pocket)
Top turbo oil feed failure 60k (out of pocket)
DEF Delivery pump failure 80k ($$$ out of pocket)
Cracking Harmonic Damp 80k (out of pocket)
Failed MAF sensor 80k (out of pocket)
Preventative I did DPF cleaning at 55k, trans and diff fluid at 60k, thermostat at 75k. Overall the car has been decently reliable. One issue is finding a knowledgeable bmw diesel tech.
      09-29-2019, 11:41 PM   #13
RioPGTMN
Drives: 11 335D
All the maintence items
Water Pump
All deletes + Tune
CBU
Fluidamper Balancer
Trans Service
Complete fluid flushes
Fuel Filter
Thermostat
All new vacuum lines
Diff drain and fill
That should make for a pretty reliable D
      10-02-2019, 01:00 AM   #14
lucinator
Drives: 2011 BMW 335d
I just picked up a euro 335d in the U.S. and i cannot for the life of me find out the physical differences in emissions/exhaust etc. Anyone care to shed some light?
      10-02-2019, 01:55 PM   #15
PerfectAce
PerfectAce's Avatar
107
Drives: 2011 335d Sport
I'm curious as to how you managed to do that. I'm sure US Customs would be very curious as well. But no judgment here on your possible grey market purchase, on to your question:
The US market cars have a selective catalytic reduction system not present on the Euro market cars. Basically: a urea tank and injection system to aid in NOx reduction.
Anyway, are you sure that you really have a Euro-spec model? Or was that just something the shifty used car salesman said in an effort to make you think you were buying something super-special?
      10-02-2019, 01:57 PM   #16
floydarogers
690
To the best of our USA/CA knowledge, all USA/CA E90 335d (10,000 cars in model years 2009, 10, 11) were BlueTec (SCR/DEF system, with significantly different exhaust/DPF/DOC. Look for the PDF's that are titled "AdvancedDiesel with ...", Introduction to Diesel ...", or "ST810 Advanced Diesel Technology ...". I believe that all have the differences listed.
Now, if you've bought an F3x, all bets are off (only 535d/540d, 740d have diesels, and they are N57 not M57.)
      10-02-2019, 03:36 PM   #17
PerfectAce
PerfectAce's Avatar
107
The US market cars have a selective catalytic reduction system not present on the Euro market cars. Basically: a urea tank and injection system to aid in NOx reduction. Play around with realoem.com and take a look at US and Euro market 335d's and the exhaust and fuel systems sections for each.
      10-02-2019, 03:37 PM   #18
floydarogers
690
      10-02-2019, 05:18 PM   #19
lnxguy
357
Drives: 2009 335D
I'm guessing you've got the same car like everyone else does here.
535d and the 540d use different engines. B57 in the 540d.
'09 335D
      10-04-2019, 11:05 PM   #20
bih_m3
Drives: 2009 BMW M3
Thanks for all the info! I would love to purchase one in europe but finding one in eastern europe is hard and very expensive compared in the us.
