Studio RSR
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Comp Turbo 335d
      09-15-2019, 01:37 PM   #1
RioPGTMN
Drives: 11 335D
Comp Turbo 335d
Hey guys,
As some of you know I picked up the DO Comp Turbo car
Overall, It's pretty awesome. There are a bunch of "small stuff" that my OCD just can't live with. So I will be outlining all the changes and updates to the car in this thread.
I'll break down each task
1. 335i Trunk Liner - DEF Tank Removed - Performance
BMW Hex Bolts x8
Heat Insulation Silencer - Right
Heat Insultation Silencer - Left
Trunk Cover
2. OEM Black Kidney Grills - Aesthetic DONE
Kidney Grill - Left
Kidney Grill - Right
3. Front Seal above driver side headlight was missing - Restore
Front Seal (same for both sides)
4. Fuel Filter - Maintenance
OEM Fuel Filter
5. Thermostat - Maintenance
OEM Thermostat
6. Cabin Air Filter - Maintenance
Cabin Air Filter
7. Fog Lights - They function but lenses are scratched and foggy. Aesthetic
Foglight - Right
Foglight - Left
8. Motor Mounts - Maintenance
Motor Mount - Left
Motor Mount - Right
Motor Mount Bolts x4
9. Water Pump - Maintenance
OEM Water Pump
Water Pump Gasket
10. Cabin Filter Housing - Bottom clips are broken - Restore
11. Window Trim Slide Frame - Aesthetic (
Window Trim Gloss Black - Right
Window Trim Gloss Black - Left
That is the current order from FCP Today
Other Misc parts that I've noticed / getting hardware for - I will update with part numbers and pics of the locations
Headlight Cover - Wheel well driver side
Engine Cover Bolts
Bottom engine cover - Complete hardware set and a couple of brackets that were missing
Driver side lower weather stripping (torn)
OBD Port Cover
Fluidamper
All new vacuum lines
034 Motorsports Transmission Mounts
Hopefully over the winter I will get the car down to cryo detail in FL for an under-carriage detail - The process is amazing
Here are some pics to start it off.
Deftronix169.50
      09-15-2019, 02:43 PM   #2
Nadir Point
Nadir Point's Avatar
103
Drives: Diesel
Niiiiice. What's the story on that exhaust manifold?
      09-15-2019, 05:00 PM   #3
RioPGTMN
Drives: 11 335D
HSP Diesel did the CNC Work
      09-17-2019, 12:20 AM   #4
Jpm57tt
Drives: E91 335d
Follow...
      09-17-2019, 01:31 AM   #5
PURE340i
104
Drives: 2018 BMW 340i & 2011 335d
Monster
      09-17-2019, 04:00 PM   #6
RioPGTMN
Drives: 11 335D
Couple of Quick Updates
Just showing some hardware that was missing when I got the car, and why I need a new Cabin Air Filter Housing
The parts that clip to the power cable cover are broken and do not stay installed
Few pics :
Replacement Screws - These were missing.
Current Kidney Grills - They were just painted and are peeling. OEM Black are on the way.
This is the front seal above driver side headlight, This part: https://www.fcpeuro.com/products/bmw...nt-51767143757
Cabin Filter Bolts - These were missing.
Broken Clip on Cabin Filter Housing - Far left
Broken Clip on Cabin Filter Housing - Far Right
Will be doing an install post on the parts as I can get them installed, and small other fixes along the way like missing engine cover hardware, lower engine cover hardware (all of it was missing) and other plastic trim and bits as I find them
      09-18-2019, 12:20 PM   #7
Nadir Point
103
Drives: Diesel
Won't be much longer before everything is made from some sort of plastic.
      09-18-2019, 01:45 PM   #8
RioPGTMN
Drives: 11 335D
That's true
      09-25-2019, 02:49 PM   #9
RioPGTMN
Drives: 11 335D
Will be starting some of the installs very soon Will post pics of some of the progress soon
      09-26-2019, 09:03 PM   #10
RioPGTMN
Drives: 11 335D
Number 2 on the list is done. You can see below the before after, new being on the left.
The OEM black kidneys give it a way cleaner look, The ones on the car were the OEM painted black. Was NOT a clean look
Before with old on the right:
Both replaced:
      09-27-2019, 10:30 AM   #11
Deftronix
170
Drives: 12 X5d & 20 X7 M50i
Can't wait to learn more of your engine build. I spoke with HSP and they mentioned there are some modifications that will be required on the next manifold made therefore unwilling to make anymore right now due to their current workload. Curious if you will have any fitment issues because they should sell the cad files if they dont plan to make anymore and did most of the R&D already!
Please give us an engine update soon!
      09-27-2019, 02:11 PM   #12
RioPGTMN
Drives: 11 335D
This car needs so much, it’s a bit overwhelming to be honest but, one thing at a time
      10-22-2019, 10:54 PM   #13
Deftronix
170
Any updates?
      11-15-2019, 09:57 AM   #14
splatz400
Drives: 335d
subscribed!
      11-15-2019, 09:59 AM   #15
splatz400
Drives: 335d
please provide more info on that manifold, we want them available to the masses
      11-15-2019, 09:44 PM   #16
derkenblosh
Drives: White 335D & White Suburban
Get ya some black handles for the doors... I did, and now that I have em, I couldn't not have them. They really make the car pop.
https://photos.app.goo.gl/tFNVKT285juWo8NB8
      11-16-2019, 06:22 PM   #17
RioPGTMN
Drives: 11 335D
The manifold was a one-off and they are not interested in making more at this time.
I will be posting pics of the mounts and other progress soon. The 034 Motorsports Speed Density Engine and Trans mounts install and are a solid upgrade!
      11-17-2019, 01:12 AM   #18
Jpm57tt
Drives: E91 335d
Thumbs up
Thanks for the update .
So with the upgraded transmission mounts you are not experiencing any vibrations sound?
      11-17-2019, 09:55 PM   #19
RioPGTMN
Drives: 11 335D
Very little if any.
      06-26-2020, 11:58 AM   #20
RioPGTMN
Drives: 11 335D
Will be posting some more updates soon.
Here is a small one. This cover was strangely missing, lol
      06-28-2020, 11:19 AM   #21
BB_cuda
BB_cuda's Avatar
765
Drives: 2011 335D Msport, 2013 X5D
Someone worked on the headlight changing bulbs or something is why that lid got opened. They weren’t careful to get the rotating locks in place correctly. Those aluminum fins are the heat sink for the LED turn signal module.
