09-12-2019, 02:13 PM | #1 |
3075
Rep 3,022
Drives: 2019 M2 Competition
N55 EWG rattle?
Question: Do you have waste gate rattle?
I am looking at what appears to be waste gate rattle at low boost (1-3lbs), that just cropped up about a month ago. I am a N55 F32, with 65k miles. Talked to my shop.. they *think* its waste gate. Talked to Seattle BMW shop foreman.. "oh yeah.. absolutely N55s have waste gate rattle like the N54s did, EWG hasn't changed that." Anyone else experiencing this? Honestly its driving me a little crazy, and apparently the only "fix" is a new turbo has its an integrated piece. I would go Pure2 for sure if I did, but just irritating. Anyone else experiencing N55 EWG rattle? Thanks
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
09-12-2019, 02:17 PM | #2 |
181
Rep 252
Drives: 2017 Model S P100D
With my valved straightpipe exhaust I can definetely hear wastegate rattle. It's pretty noticeable until it is fully warmed up then goes away mostly. And I can only hear it in comfort mode between 1000rpm and 2300ish when the valve opens. It goes away 100% in sport mode. I asked the mechanic what it was when I had it on a lift and he did a thorough check of the entire exhaust and said it's pretty much guaranteed wastegate rattle
2014 n55 ewg |
09-12-2019, 02:22 PM | #3 |
3075
Rep 3,022
Yeah.. I get a metal on metal ticking sound from about 1.2 - 2.6lbs of boost, not below, not above. Its quiet but especially since it just started, its driving me a little crazy.
09-12-2019, 04:07 PM | #4 |
172
Rep 1,375
The rattle can be tuned out in a custom tune with making changes to the WGDC / throttle target tables.
For example, you should notice that the rattle is less audible or nearly non existent in Sport+ mode when compared to the same throttle position in Comfort mode. -Nick |
09-12-2019, 04:25 PM | #5 | |
3075
Rep 3,022
09-12-2019, 05:17 PM | #6 | |
181
Rep 252
running bm3 ots st2 91 |
09-12-2019, 05:29 PM | #7 |
Car Hypochondriac
335
Rep 901
Drives: 2014 335i M-Sport Estoril Blue
Also have this. When I was under the car the other weekend I noticed that between the wastegate actuator and the arm of the wastegate itself is a small piece that connects the two. There's quite a bit of play in those attachments. I wonder if adding a spacer between the circlips and arms would prevent the rattle?
BMW DIY Guy3075.00 |
09-12-2019, 05:30 PM | #8 |
3075
Rep 3,022
I have this rattle regardless of mode for me, though I am in sport or sport+ 99% of the time.
09-12-2019, 05:54 PM | #9 | |
Gettin It Figured Out
1820
Rep 2,669
Great choice...as you know. But, consider SpeedTech S3 to REALLY take advantage of your XDI HPFP .
09-13-2019, 05:04 PM | #11 |
559
Rep 1,127
I would try an ISTA wastegate calibration before tossing parts at the situation. You can also remove the downpipe and check for play in the wastegate.
09-13-2019, 11:26 PM | #12 | |
3075
Rep 3,022
09-13-2019, 11:27 PM | #13 |
3075
Rep 3,022
Calibration?
09-13-2019, 11:49 PM | #14 |
Car Hypochondriac
335
Rep 901
Found a really good pic and circled the bit I'm referring to
Power mods: VRSF IC/Catted DP - FTP CP/BP - AFE Cat-back - BM3/XHP - Dorch S2
Handling mods: Koni yellow - Eibach prokit - Millway street - M Performance LSD - M3 brakes - EBC bluestuff Exterior: Euro LCI tail lights - Shitty ECS CF spoiler - Chinese M performance diffuser Interior: Bavsound stage 1 and subs - custom trunk sub by Mike1327 |
09-14-2019, 02:07 PM | #15 |
3075
Rep 3,022
Thank you.. if that is a source of vibration, wonder if there is a way to eliminate that?
03-02-2021, 01:55 AM | #16 |
Rep 3
I just went through this same issue!(rattling at around 2k rpm) After a lot of searching I ended up buying a replacement for the clamp that connects the downpipe to the midpipe. The metal part that goes inside the clamp can get disfigured during exhaust / downpipe installs and is supposed to be single use. Part no. 18307620349. Other exhaust rattles/vibrations can usually be fixed by readjusting your exhaust to make sure its not touching anything.
