E90 335i need help coding out adaptive headlight
09-09-2019, 04:44 PM | #1 |
Rep 1
Hi Im in the Norfolk, VA area and was wondering if there was anybody around here that could code out my adaptive headlights for me? my car unfortunately was in an accident and cracked the front headlight. Ill pay anybody who can help/do it for me!
11-27-2019, 05:29 PM | #2 |
Rep 4
Drives: BMW E92 (pre-LCI)
Not in that area or I'd help you but you can get kit to do this yourself easily and for not too much. Bimmercode app + one of these adapters in your OBDII port should do the trick: https://www.ebay.co.uk/itm/193060943881
It's much cheaper than Carly and it's a one off payment. Very simple to use and a worth while investment. There are many cool extra features which can be coded in. Edit: I misread your location (I was thinking you were in Norfolk UK!) but you should be able to get that adapter or a different compatible one from ebay.com in US easily enough. |
11-27-2019, 07:28 PM | #3 | |
185
Rep 780
12-27-2019, 03:33 AM | #4 | |
654
Rep 1,893
You'll use NCSExpert to modify the VO (vehicle order; a list of options installed in your car) by removing $524 (option code for adaptive headlights). The steps are: Open NCSExpert with "Expert" protocol Load VO Modify VO Save VO (FA_write) to the CAS and NFRM modules. "Default" code (SG_Codieren) CAS and NFRM The above is obviously just the bare bones of what you'd do. There are many tutorials on how to install and use NCSExpert and a number of threads on how to code out adaptive headlights. Search is your friend. But if your headlights no longer correctly aimed after your accident, coding is not going to help you. The adaptive headlights are rather fragile internally and the plastic bits necessary to establishing the orientation of the projector break easily. |
01-07-2020, 02:14 AM | #5 |
91
Rep 817
Can I assume the above method could be used to do the opposite and code IN an adaptive headlight? I got one new headlight after being damaged by hitting a deer and it's not adaptive after the install like my other original one.....the new one was installed by a BMW collision center but they said I had to take it to the dealer to have it "coded"......now I have one adaptive and one not
01-07-2020, 06:02 AM | #6 | |
654
Rep 1,893
I'd try coding the AHL first, which is the last step in the very bare bones list I posted. With more detail below: Open NCS Load "Expert" or "Factory Coding" profile F1 (Start) F3 (CHoose Chassis) Select E89 Select CAS (this loads the VO so NCSExpert know what to do) F6 (Back) F3 (Choose ECU) Select RSMC or SMC_R or SMCDS_R (if the offending headlight is on the right; LSMC if on the left) F1 (Change Job) Select "SG_Codieren" (This may already be the default) F2 (Execute Job) Something like that. |
01-07-2020, 12:16 PM | #7 |
91
Rep 817
Thanks, I think I will get the cable and software and give it a try. The headlight I got was brand new so it should just need initial coding I would guess...Also, the step where you choose chassis and select E89, I would select E92 here instead right, since my car is an E92 coupe?
01-07-2020, 01:03 PM | #8 | |
185
Rep 780
dpaul653.50 |
