09-06-2019, 02:57 PM | #1 |
Rep 96
Should I be making this much
Hey guys
So I got some questions 1. Is 20.4lbs of boost a lot for a 328i on stock turbo?? 2. My mods are er cp vrsf dp jb4 rez and muffler delete running map 2 with 4 gals of e85 rest 93 3.Does the EWG change anything ?? I have a 2015 f30 do I need harness or what do I need to make 22lbs of peak boost ? 4. How are people making 21psi on just tune alone and I can’t make 21.. I have no leaks nothing |
09-06-2019, 03:41 PM | #2 |
Monkey
119
Rep 241
Stock peak is at around 18.9psi. 20.4 should be fine with cp, dp. If you're going beyond 22 then you should definitely upgrade to a bigger turbo.
I'm pretty sure you need the flex fuel harness to take advantage of the E85. Don't know about the other questions, hope that helps. |
09-06-2019, 04:39 PM | #4 | |
50
Rep 50
Anyways, why you worried about 22PSI? Just put a hose clamp on the waste gate rod so you can start hitting 30PSI. Should be good for 1000hp or so. As far as supporting mods, get a Raizin voltage stabilizer and one of their fuel atomizers. go 100% E85 and you should be straight. |
09-06-2019, 05:08 PM | #6 |
1599
Rep 3,748
Just a hypothetical question here.... how much really can you squeeze out of a N20/26 in power? You can change everything except stock turbo. How much you going to spend?
I have BM3 and awe quad exhaust (I could have gone cheaper on exhaust but I love the awe sound and the quad is just aesthetic) . That all I'm doing to my car. If I want power I would have just go inline 6 or M car. |
saltql1.50 |
09-06-2019, 05:21 PM | #7 |
Rep 96
Yeah I 100% get that it’s not that I’m trying to get some crazy power out of it I just feel like for the mods I have and reading what other people say they are getting 2-3psi more with jsit the tune so I guess I’m saying am I missing out on power
09-12-2019, 02:22 AM | #10 |
Rep 33
i just uninstalled my Jb4 and installed the BM3. I was running Map 2 on JB4 and i'm on stage 1 BM3. Overall i prefer Bm3 because the power delivery is more linear, and there is much more customization to it.
BM3 has burble customization for exhaust, you can tune the 8 speed transmission which is awesome, etc etc. JB4 Map 2 i'm pretty sure is quicker than stage 1 BM3, however the power kicks in hard at 3k RPM and a bit sluggish before that. I had no issues with JB4 too both are good tunes. |
