09-05-2019, 10:43 PM | #1 |
Rep 6
Touchless boot entry disabled by towbar fitting
I haven’t come across this on the forum anywhere, so I thought I’d post this to make others aware...
When you install a tow bar on the new x5 (G05) vehicle, it disables the ‘touchless’ boot open function. Wish I had been told that when I ordered the car. May have reconsidered putting a tow bar on the vehicle! |
09-05-2019, 11:26 PM | #2 |
1699
Rep 2,609
It has actually been discussed quite extensively on the forum, but being pissed about it is still justified. So Australia gets the "female receiver" version tow package then, not the European cavalier "ball on a stick" version? More info here: https://www.bimmerpost.com/forums/sh...php?p=24738131
G05 X5 x40i (04/2019 mfg, Canada) on S18A-19-11-540
09-06-2019, 08:13 AM | #4 |
186
Rep 506
I've found the touchless rear gate works pretty consistently, it rarely doesn't open. When I first started using it waved my foot from side to side and that didn't work so well. Now that I just, sort of, kick the air under the car it works just about every time.
09-06-2019, 04:07 PM | #6 | |
838
Rep 1,236
My experience too. It makes me look like a fool when it refuses to open - so I rarely used it in my previous BMWs. For me, the factory tow hitch is much more useful - it also has trailer stability control. This feature alone is worth getting the factory tow hitch instead of aftermarket ones. |
09-07-2019, 01:55 AM | #7 |
166
Rep 199
From the owner's manual:
Performing the foot movement 1. Stand in the middle behind the vehicle at approx. one arm's length away from the rear of the vehicle. 2. Wave a foot under the vehicle in the direction of travel and immediately pull it back. With this movement, the leg must pass through the ranges of both sensors. |
HODLM363.50 |
09-08-2019, 07:10 PM | #8 | |
364
Rep 350
09-09-2019, 01:53 AM | #9 |
166
Rep 199
Glad to help! I don't have my car (45e) for another half a year so all I can do is read the f* manual
06-23-2021, 01:33 PM | #10 |
Rep 1
Touch less boot operation
Just got my G05 45e and it has the factory fitted tow bar, I’ve read previous posts stating the the touchless boot entry does not work if the factory fitted tow bar is present. Glad to find out that mine works extremely well.
06-23-2021, 01:44 PM | #11 |
127
Rep 317
Mine works 15 out of 10 times, I'm always accidentally activating it when I'm loading stuff
06-23-2021, 01:46 PM | #12 |
237
Rep 432
06-23-2021, 02:10 PM | #13 |
1165
Rep 1,778
square up your foot under the BMW roundel (the logo in the middle of the trunk), and stand less than one foot away from the back. you can either kick under the sensor or sweep your foot. I use this pretty much every day and it rarely fails to work.
HODLM363.50 |
06-23-2021, 02:13 PM | #14 | |
364
Rep 350
06-23-2021, 03:37 PM | #15 |
25
Rep 32
Yep, mine too. Wonder if it’s a RHD thing?….. JC49 Congrats on the car by the way. Very pleased with mine.
06-23-2021, 04:22 PM | #16 |
3166
Rep 6,805
There are three different tow bar options, available only in certain markets. The only one that retains the kick to open is the powered, retractable gooseneck ball version, I think.
06-23-2021, 04:24 PM | #17 | |
446
Rep 810
The only other advice I can give you is get a BMW dealer to install your towbar. In addition to the physical install,the car needs some extensive coding to integrate the towbar into the car's advanced electronics & safety systems, and unless you really know what you're doing - I wouldn't try it, or let a 3rd party towbar installer do it. |
06-23-2021, 10:26 PM | #18 | |
63
Rep 82
JcaliX6
