BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N57 / M57 Turbo Diesel Discussions - 335d > Factory Boost Sensor
      09-03-2019, 08:59 PM   #1
RioPGTMN
Drives: 11 335D
So it seems the factory sensor maxes out at 48.58 PSI (look at this log
Are there any plug and play sensors that will read beyond this limit?
Thanks
      09-04-2019, 02:34 AM   #2
Yozh
Yozh's Avatar
No_Country
870
Drives: 2011 335d M-Sport
Can be rescaled with tuning
      09-04-2019, 01:18 PM   #3
Nadir Point
Nadir Point's Avatar
103
Drives: Diesel
I'd like to see you make 48.5psi. I mean I'd like to see the YouTube video where it lifts the head on the Dyno.
robnitro160.00
      09-04-2019, 06:24 PM   #4
robnitro
160
Drives: x5 35d e70 2011
Your logs are odd, requesting 36 psi but getting 48? What are you messing around with? Be careful.
      09-04-2019, 06:48 PM   #5
RioPGTMN
Drives: 11 335D
Actually the car makes 60 psi on current tune.
I purchased the white m sport from Jerry Adkins - the one originally from DieselOpa with the custom Comp Turbo setup on it
Has valve springs, and ARP head studs. Holds the boost fine - was at 68 actually. Still working on the tune with Malone currently.
      09-04-2019, 07:26 PM   #6
robnitro
160
If you are fooling the tune as your logs show, maybe it's better to just run a mechanical boost valve on the tdi we used a Dawes device, boost valve with the breather sealed shut to work on vac system... It opens and kills the vac, which opens the vac actuated vanes/wg up.
But then with 2 stages it would be hard to figure what to do with the small turbo. I suppose using 2 boost valves, one for each turbo would work.
      09-04-2019, 07:36 PM   #7
RioPGTMN
Drives: 11 335D
The first goal is just to get all the logging in one place. Protool works fantastic, the MAF has been deleted as it’s out of range. We have a 5 bar map and manifold EGT logging from the edge 2
      09-05-2019, 12:25 AM   #8
Yozh
Yozh's Avatar
No_Country
870
Oh that’s cool. You are the buyer. I thought that car was well sorted out. The log does look unusual.
      09-05-2019, 07:06 PM   #9
ranthum
23
Drives: Looking to Buy
Why not just delete the vac stuff (except motor mounts)?
