09-02-2019, 03:43 AM | #1 |
43
Rep 205
VRSF 5" HD vs CTS Turbo FMIC
I know y'all been dying for another FMIC question, so here it is
All jokes aside, I couldn't find a thread on this specific comparison, so I wanted some input. I plan on making my purchase this week and just wanted to know if there were any significant differences between the two models. I've read that a lot of these aftermarket 5" bar and plate intercoolers are generally all the same, but was curious to know if the VRSF HD is an improvement/new design considering it's relatively much newer. I'm very hesitant to buy VRSF just based off some of the fitment issues I've been reading. I know it's probably a small percentage, but I'd rather not take the risk if possible. However, if indeed the VRSF is a superior FMIC compared to the CTS Turbo, I'd be willing to take the gamble. I plan on grabbing a CTS Turbo charge pipe as well. If I decide to go with VRSF, should I anticipate any fitment issues? I've also read that VRSF doesn't mate well with ER CP, so I'd like to know if the same applies to CTS. |
09-02-2019, 04:43 PM | #2 |
58
Rep 141
My ER charge pipe mated to my vrsf 5 hd just fine. The only knock I have about the VRSF 5 is I needed to bend the radiator tabs to make it fit.
wdeerfield2748.00 pw0n43.00 |
09-03-2019, 01:31 AM | #3 |
43
Rep 205
Interesting... their description does indicate it should be full PnP without any modifications/accommodations necessary. Is the radiator tab located on the body of the car or some shroud? If you have any pictures, that'd be very helpful!
09-03-2019, 08:40 AM | #4 |
201
Rep 254
I'd be curious to see exactly what he means by bending the tabs too. The tabs are on the radiator itself though, the OEM intercooler kinda 'clips' into them.
09-03-2019, 12:05 PM | #5 | |
993
Rep 1,934
F30 335iX | Remus Axleback | Fabspeed Catted DP | VRSF Comp IC | 18X9 ET35 19lb MT1 | 255/40/18 ECS | Ohlins RT Millway Street | Millway Control Arm Bushings | Turner Endlinks | TMH 75mm 14x1.5 Studs | BMW MPerf LSD | XDelete | Pipercross Filter | MHD Stg2 93
Alpine-F80200.50 |
09-03-2019, 12:44 PM | #6 |
272
Rep 290
Sounds like you're leaning towards CTS.
I was in the same boat and went ahead and got CTS CP and intercooler. Great quality and fitment. No regrets. The intercooler is a substantial piece of kit! Not having to worry about fitment, leaks, etc won it for me. |
alohasurftoad3081.50 Jake From State Farm54.00 |
09-03-2019, 01:02 PM | #7 | |
43
Rep 205
As for my other parts, I went w/ CTS Turbo's CP and catless DP. Stoked to go FBO! |
09-03-2019, 07:34 PM | #8 |
58
Rep 141
These tabs needed to be bent out to fit on the radiator. Other than that install was easy (didn't have to remove the bumper), it keeps IATS in check, and it doesn't weigh to much.
View post on imgur.com |
12-27-2019, 02:32 PM | #9 | |
21
Rep 54
2016 328i XDrive N26 8AT: K&N Drop-In Filter * GPlus FMIC * ER Chargepipe * DinanTronics Sport Tuner (Race +4psi) * AWE Midpipe (2nd Cat Delete) * Dinan Axleback Exhaust * Dinan Sport Springs * Megan Racing Front Strut Tower Bar * Cross-Drilled Rotors * Hawk HPS 5.0 Brake Pads * StopTech SS Brake Lines
12-27-2019, 02:56 PM | #10 | |
4364
Rep 7,607
Last post i saw from him in early November he hadn't installed the IC yet. |
12-27-2019, 07:41 PM | #11 |
217
Rep 821
Drives: Bmw 335i f30 N55 ( sold)
I installed my VRSF 5"HD myself. Did it very quick and no issues. Just got it November 2019. No issues here. Used BMS charge pipe
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
12-27-2019, 07:55 PM | #12 |
4364
Rep 7,607
Yeah i installed mine myself too... 3 or 4 times. Was curious as to his experience specifically because he ordered at the same time as me when they were temporarily out of stock.
12-30-2019, 12:57 PM | #13 |
BimmerPost Supporting Vendor
24201
Rep 190,807
VRSF intercooler will outperform the CTS. It also has better fin density for more cooling
