08-31-2019, 02:53 PM | #2 |
4332
Rep 6,121
Drives: 2022 Porsche Boxster GTS
I noticed that, I simply hit "off" then "auto" and the symbol went away
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order) 2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD) 2018 BMW M2 Mineral Grey(SOLD) 2019 BMW X5 50i Carbon Black/Tartufo (SOLD) |
08-31-2019, 02:54 PM | #3 |
4332
Rep 6,121
double post
08-31-2019, 02:59 PM | #5 |
4332
Rep 6,121
try hitting the dog light button then turning off the fog lights I also did that so one of the two fixed it
09-01-2019, 05:33 PM | #6 | |
4448
Rep 7,489
Perhaps my confusion is based on my perspective of a 2013 f06...when that light is illuminated it indicates that the side lights are on. The symbol is explained in my owners manual as indicating manually turning the side lights (or the DRLs) on. And if I look at my light switch...that symbol is printed on the switch to indicate that the side lights are on (see #5 in the pic below). It also illuminates in the cluster if I have the AUTO headlamps turned on...or if I press the fog light switch (which turns on the headlights, too) and the headlights turn on. If you don't want your daylight running lights illuminated (front and/or rear) you can turn those off in iDrive (its probably under LIGHTING). If you don't want that symbol illuminated on your cluster, then turn your headlights to the OFF position because if you have AUTO headlights turned on or you turn the headlight switch to the side light or low beam position to manually turn them on...that symbol will illuminate in the cluster. And if you're in AUTO mode (headlight)...anytime the lights turn on, that symbol illuminates to let you know your lights are on.
2015 F06 650ix Gran Coupe`(Moonstone/Cohiba Brown)| 2014 F15 X5 50i MSport (Space Gray/Mocha)
Become a BMW CCA member! Click HERE to join and feel free to use my BMW CCA member #191509 as a referral. |
09-01-2019, 11:26 PM | #7 | ||
4332
Rep 6,121
09-02-2019, 04:58 PM | #8 | |
4448
Rep 7,489
It only comes on when the AUTO headlight system turns on the sidelights/headlights...like dawn, or in the morning when the sun is still low in the horizon...or if I drive into a tunnel....then again at dusk. But again, in broad daylight with my DRLs on...that little green light is not illuminated. It only comes on when the side lights and or headlights are illuminated either automatically or by me (like hitting the fog light button which turns on the headlights). Post back your experience...I'm thinking they're probably going to be similar to mine if you have DRLs and AUTO headlights activated. That little green icon will probably illuminate when your sidelights/headlights/foglights illuminate.
09-06-2019, 11:25 PM | #9 |
Rep 13
Since I bought it in March, front daylight were on and I only can turn them of via iDrive.. after the actualization I now have front and rear day lights and green light appear I can turn them off only by iDrive. Lights continue working auto as usual in tunnels, or at night. Kind of messy but I guess I'm the only one having this "issue"
09-07-2019, 12:49 AM | #10 | ||
59
Rep 36
Before 2013 or so, all BMW DRLs activated the front and rear lights but this changed for some reason in 2013 to be front only. I remember asking about it at the time and I was told it was some sort of EU regulation. I was very upset about this at the time. I got my G05 updated to the .39 version of idrive last month and was pleasantly surprised to find DRLs now, once again, include tail lights. Not sure why but it's a positive development as far as I'm concerned. |
09-07-2019, 01:56 PM | #11 | |
838
Rep 1,236
For example in Canada, you cannot turn off DRLs. And starting from 2021, tail lights have to be turned on as well; as well measures to prevent any cars driving in the dark without lights. |
09-07-2019, 02:20 PM | #12 |
186
Rep 506
Especially if they are painted with Vantablack!
09-07-2019, 03:20 PM | #13 |
265
Rep 479
I didn’t know that the rear taillights are on now with the front halos if DRL is set to on. That’s a good feature. I use remote start and it’s and this makes it easier to confirm that the X5 started. Also seems like a good safety feature. Glad I did the July update.
09-11-2019, 12:48 PM | #14 | |
Rep 13
09-14-2019, 09:08 AM | #15 |
265
Rep 479
