Bimmerpost
4 Series
Technical Topics Wheels and Tires G20 AWD and 17" winter wheels, possible?
      08-31-2019, 11:00 AM   #1
limla
Drives: G20 330i xdrive
Is it possible to do? car does not have M Blue calipers but came with 19" staggered. Would like to get winter set , 18" is good but if can go with 17" that is great.
      09-03-2019, 02:13 PM   #2
remmib
remmib's Avatar
Norway
1568
Drives: 2013 F10 520d M-Sport
Yes, at least on the 330i.
F10 520d M-Sport Alpine White | HRE P43SC 20x9+20x11 | Michelin PSS 255/35+295/30 | KW V3 Coilover | M5 Front Sway Bar + M550d Rear Sway Bar | 3DDesign Front Lip | BMW M Performance CF Spoiler | BMW M Performance Diffuser | BMW M Performance Black Grills | BMW M Performance Pedals |
      09-04-2019, 04:54 PM   #3
Calamari
209
Drives: 2024 G21 330d, 2008 E87 118i
Without performance brakes you can fit 17" wheels. For winter driving 17" is definitely a better option than 18".
      09-27-2019, 07:41 AM   #4
Trowa
Jack Bauer
11
Drives: 2019 330i xDrive, 2016 S1000RR
What is the wheel and tire spec?
I'm assuming for tires its 225/50/17 and for wheels 17x7.5 w/ 20 to 40 wheel offset?
      09-27-2019, 12:01 PM   #5
remmib
remmib's Avatar
Norway
1568
OEM 17" spec is 225/50/17 and 17x7.5 ET30 wheels. I might add that OEM 18s are 18x7.5 ET 25, so I wouldn't get anything higher than a ET30 offset.
      06-16-2020, 10:45 AM   #6
Mtl128_25
26
Drives: 328i 2008
Can we also install 235 50 17 on non blue brakes?
      06-16-2020, 12:57 PM   #7
Bimmerius
34
Drives: 2016 F30
sub for future updates
      10-13-2020, 12:55 PM   #8
olhomau
olhomau's Avatar
Brazil
Drives: BMW F30
I have 19 wheels on my M340, as I have blue brakes, I would like to try to put 17 wheels to run on poor quality roads on certain occasions, if not for the pattern 5x112, an original F30 wheel rim 17 would have fitted. I have been looking for someone who has made use of 17", but without success. As a second option I am thinking of using 18 "rims with a different tire configuration from the one recommended in.
234/45 front 245/45 rear... looking for sidewall height... can anyone help?!
MacBarros
      10-13-2020, 05:36 PM   #9
Calamari
209
17" will not fit on M340i brakes that you have. Brake disc and calipers are too large for the inner diameter of 17" rim.
Appreciate 2
g20
