08-29-2019, 04:48 PM | #1 |
119
Rep 293
Harmon Kardon Subwoofer
It might be my imagination, but I think there might be a short in my subs. I feel like sometimes the base really kicks in, but then disappears. Doesn’t matter the media source, and usually the base is not that substantial. I was always a bit unimpressed with the HK base, but when this happens, it has me thinking the subs are only working some of the time.
Is there a way to test for this? |
08-29-2019, 07:22 PM | #3 |
6290
Rep 5,324
08-29-2019, 07:56 PM | #4 |
1588
Rep 4,553
While the lower frequency tones are playing, reach under your driver's seats and touch the grill. You'll feel the vibration from the speaker. Or not if you've got a problem.
2023 840GC | 2021 740i | 2019 X3
08-29-2019, 11:33 PM | #5 |
1707
Rep 2,053
I just got mine about 8-9 hours ago and it seems evident to me there's a missing part of the sound stage in the Harmon Kardon system.
It's because we have woofers here. They're not subwoofers. That's the part that's empty- I think. Full disclosure I've had quite a few adult beverages this evening, and obviously the car is brand new to me.
Moved to the darkside: '23 718 GT4; 11-10-2022.
Le Mans Blue F80 - Munich 5-22-2015 / US 7-7-2015 / SOLD 9-17-2022 ED RecapArctic Grey G05 - Spartanburg 8-29-2019 X5 PCD Recap |
08-30-2019, 06:59 AM | #6 |
1053
Rep 1,952
This could be in part due to whatever you're listening to might be playing frequencies that happen to be right at the subs crossover range. I would imagine this is 80Hz or 120Hz. So if your music track is straddling that line it will sound like your subs are going on and off. Especially if you've setup your equalizer to really pump up the lowrange bass but doesn't taper to mid range. Does the HK system have a crossover that you can adjust? If so you may want to adjust it up so the subs are active more of time.
