08-28-2019, 02:39 PM | #1 |
91
Rep 143
Active Roll Stabilization for a non DHP 50i
I’m one of those guys that believed my salesman and bought a loaded 50i but regretfully found out it did not have the DHP package until it was too late.
After riding around in sports+ the lean around the turns is Ok. It leans hard enough that your wife will look at you with that look, “your going to fast - slow down” ... What is wish i would have known at the time: ZDH - Adaptive M Suspension Profession, includes IAS (integral active steering aka 4 wheel steering), active roll stabilization Is the active roll stabilization possible to add or is this just a thicker sway bar? The rear differential is a loss - calipers have been professionally painted blue. I’m hoping adding the ARS might be possible. Does anyone know or ventured down this path? Selling my X5 50i to take a 25k loss to upgrade is a hard no for me. |
08-28-2019, 02:43 PM | #2 |
4332
Rep 6,121
Drives: 2022 Porsche Boxster GTS
You could look up the P/N's and see if it can be retrofitted or if a 3rd party is going to make a better sway bar
2022 Porsche Boxster GTS Gentian Blue
2023 Porsche Spyder Python Green (on order) 2022 BMW M3 Comp AWD IOMG/Kyalami Orange (SOLD) 2018 BMW M2 Mineral Grey(SOLD) 2019 BMW X5 50i Carbon Black/Tartufo (SOLD) |
08-28-2019, 02:44 PM | #3 |
1053
Rep 1,952
Based on this it doesn't seem like you can add it after the fact.
https://www.youtube.com/watch?v=GYBPc9748xQ |
08-28-2019, 04:48 PM | #4 | |
4362
Rep 4,246
Alternate route is to go with is aftermarket springs/struts and lower it. Chalk it up to a learning experience. Dynamic Front Stabilizer Dynamic Rear Stabilizer IAS Unit
Current BMWs - '20 X5 xDrive40i M Sport, '20 BMW M550i | Past BMWs - '03 E39 540iT M Sport, '06 E53 4.8is, '11 E70 M Sport LCI
08-28-2019, 09:54 PM | #6 |
538
Rep 1,201
It would be at least 10k to retrofit something like that, not to mention you'll void the warranty of the entire drivetrain. It'll be cheaper to replace the car.
Lesson learned, always ask for the build sheet or window sticker and verify the equipment yourself prior to taking delivery. A lot of us have made that mistake before.
2022 X7 M50i Phytonic Blue
2019 M5 MBB (wife's DD) |
08-28-2019, 11:10 PM | #7 | |
4332
Rep 6,121
08-28-2019, 11:56 PM | #8 | ||
538
Rep 1,201
AndroidRobot4331.50 |
08-29-2019, 06:02 AM | #9 | |||
4332
Rep 6,121
sandwi54538.00 |
08-29-2019, 09:41 AM | #10 |
5457
Rep 7,037
Due to the complexity of ARS and integration into the electrical system and control system of the car it will be a nightmare of issues with no warranty to lean on. Don’t do it.
I know people who have had success fitting the M5’s passive sway bar on regular F10 5 series cars for under $1k in parts and labor. In your case this would be the sway bars from new X5M when it arrives. It’s worth checking if it will fit. Another option is after market coil-overs but this is also a road to electronic issues including fault codes being thrown etc. if your X5 has some sort of adaptive dampers now. |
08-29-2019, 12:07 PM | #11 |
6290
Rep 5,324
What is your end goal for this SUV?? In the 50i, you have to really push it in the corners before DHP becomes a factor. All passengers I have given rides up my mountain roads are scared to death long before DHP is a major factor.
In a 5000lbs + SUV I question how much harder core performance you are realistically requiring of your 50i? |
08-29-2019, 12:30 PM | #12 |
186
Rep 506
08-29-2019, 02:28 PM | #13 | |
5457
Rep 7,037
I owned two BMWs with ars and the effect is felt at almost all speeds. ARS is a heavenly match for an SUV and should IMO be standard on all premium SUVs. Last edited by solstice; 08-29-2019 at 02:39 PM.. |
08-29-2019, 02:49 PM | #14 | |
55
Rep 120
AlexM51.50 |
08-29-2019, 06:54 PM | #15 |
22
Rep 62
Wondering if you can comment on how the DHP's ride quality was (compared to air suspension)...and what size wheels you were riding on? Many thanks!
08-29-2019, 07:40 PM | #16 |
4332
Rep 6,121
I've driven both on 21"s and own a 50i/DHP on 21"s. The DHP is much more buckled down, has more confidence etc. The AS is bouncy, and while it is adjustable body roll is noticed and the X5 doesn't feel as good. This is coming from a person who pushes theirs pretty hard because I enjoy the craziness of how this big, heavy SUV can handle It's no sports coupe but it sure tries!
08-29-2019, 08:01 PM | #17 |
191
Rep 802
In Canada, you can't get ARS w/o the air suspension (I would have considered it as a stand-alone option), but don't want it with the air suspension. Everything I've read / test driven w the AS made the ride feel like I was driving an old cadi.
2020 X5 M50i | 2015 X3 28i xLine | Retired 2013 335i M Sport
solstice5456.50 |
08-29-2019, 08:08 PM | #18 |
4332
Rep 6,121
They offer the active sway bar without DHP? I've never seen it offered with AS on the X5
08-29-2019, 08:31 PM | #20 | |
55
Rep 120
08-29-2019, 08:41 PM | #21 |
4332
Rep 6,121
I live in West TX ie roads suck and the ride is way softer than my X3 M40i even when I put 20" wheels with non-rfts. Keep in mind my X5 has 21" wheels with RFT tires and rides better. Impacts are felt but not jarring. The steering wheel doesn't really move even over large potholes which is nice. I wouldn't call it an old caddy in terms of taking bit hits, it's like a tennis ball hitting a wall vs a baseball. One has give but isn's super hard, the other is like a rock. So the suspension is firm, not overly so yet also compliant. It's been a long day so my explanation is probably awful but I hope it gets the point across.
08-29-2019, 08:52 PM | #22 |
5457
Rep 7,037
Also remember that ARS not only acts as super beefy sway bar when needed to near eliminate body roll in all situations, it also improve comfort when going straight compared to a non ARS car. ARS is effectively a sway bar that is fully decoupled going straight and dynamically “grows” to counteract body roll forces. In summary it’s super awesome on a luxury, sporty but also comfortable heavy vehicle with high center of gravity like, well an SUV
