BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Door seal noise
      08-26-2019, 10:08 AM   #1
adi555
21
Drives: F48
Door seal noise
Past couple of days there's a lot of creaking noise coming from the doors, I guess it's from the door seals. Any fix?
      08-26-2019, 10:11 AM   #2
ejw2011
ejw2011's Avatar
94
Drives: x3 F25 35i, x1 F48 28i
https://www.amazon.com/nextzett-91480615-Gummi-Pflege-Rubber/dp/B004B8GTQG/ref=mp_s_a_1_5?keywords=door+seal+lubricant&qid=15 66832230&s=gateway&sprefix=door+seal+lu&sr=8-5
      08-26-2019, 11:24 AM   #3
Beagler
75
Drives: Sept 2019 Facelift X1 MSPORT
Have this myself and used it on car and caravan.
Used this on leaks as well,
Captain Tolley’s Creeping Crack Cure.
I kid you not. Sounds like a medical affliction remedy.
Everthing goes to Entropy in this Age.
      08-26-2019, 05:36 PM   #4
oakey46
159
Drives: BMW 2 A/T 220i Lux Auto 1.5
You could also try a silicone lubricant spray, which is relatively inexpensive, should be easily obtainable and doesn't cause rubber seals to deteriorate.
Don't use standard aerosol spray lubricant such as 'ordinary' WD40, though they do make a silicone version, which is clearly indicated on the spray can.
I suppose what you may be able to obtain will depend on your global location, but that isn't at all clear on your adi555 info showing your location as 'Mum' - Mumbai, India?
      08-29-2019, 02:56 PM   #5
StefanJ
StefanJ's Avatar
68
Drives: BMW X3 G01 xDrive 20d
I agree with ejw2011's suggestion.
This is the best door seal lubricant. And it's lasting for a long time.
      09-11-2019, 10:05 AM   #6
victorngcm
No_Country
30
Drives: F48
I used noise cancelling strips
      09-12-2019, 12:45 AM   #7
satz
Australia
336
Drives: 2019 BMW X3 M40i
Does this indicate a lack of rigidity in the body shell? My E90 335i also had these noises (which I silenced with an annual use of Gummi Pflege).
However, non BMW cars I've had, even SUVs, never had these door rubber noises, as the doors just didn't move in relation to the body when they were closed...
2019 X3 M40i, Sophisto grey, H/K, pano
Previous: 2019 BMW X2 Msport, Mineral Grey, Adaptive Suspension, H/K
Previous: 2009 335i LCI, Bluewater
      09-13-2019, 04:24 AM   #8
adi555
21
Drives: F48
Exactly! None of my other cars ever had this problem. Is this something serious? Should I get in touch with BMW workshop? Change of rubber seal advised?
      09-13-2019, 10:03 AM   #9
oakey46
159
Yes. Before you attempt to fix anything yourself whilst the car is within warranty its always best to visit the dealer and let them hear the noise and hopefully sort it for you. Not worth spending your own cash if it's covered, as it should be because it isn't a 'wear' item.
      09-14-2019, 01:13 AM   #10
pandrath
Drives: F20 118i
I had this issue on my previous 1 series. The dealer fixed within warranty by applying a thin invisible tape in each door where the rubber seals touch the body of the car (they also replaced all the rubbers).
      09-15-2019, 05:57 PM   #11
satz
Australia
336
They'll probably just lubricate it with Gummi Pflege, but anyway best for them to look at it in case anything else is causing it.
      09-29-2019, 04:35 PM   #12
adi555
21
Drives: F48
Ok so I bought Gummi Pflege and while applying the nozzle accidentally came out and some of the liquid spilled on the door paint. I wiped the excess with wet cloth. Is this going to damage the paint?
      09-29-2019, 07:58 PM   #13
satz
Australia
336
It should be fine. As long as you wiped it off. I remember the sponge tip fell off my bottle, so I just squeezed some onto a cloth and then wiped that onto the rubber.
Depending on your climate, and whether your car is parked outside a lot, you may need to reapply every 6 months.
cheers
xbimmers
