BMW X5
      08-26-2019, 08:56 AM   #1
bimmer1000
Drives: Ford Mustang
Non-Heating Steering Wheel --> Heated Steering wheel?
How much would the dealer normally charge to do this swap, on a G05? Is it routine enough that I don't have to worry about airbag being negatively affected in any way? Thanks guys.
      10-22-2019, 09:15 AM   #2
VTENGR
1051
Drives: 2020 X5 M50i
I imagine you would just swap out the entire steering wheel, airbag and all - so whatever the cost of the steering wheel (guessing $700) plus an hours worth of labor.
      10-30-2019, 07:52 AM   #3
Ninefourteener
Ninefourteener's Avatar
1340
Drives: 2020 X5 M50i, 2020 Alfa 4C
I remember researching this on my F30.... and it was considerably more complicated than I'd initially thought.
Buying a heated steering wheel was easy..... but in an F30, the car wasn't wired for it, so it required the installation of a wiring harness through the steering column.
Then, even after I did that... it required coding.
I decided not to do it. Wasn't worth the effort.
Not saying the G05 is the same.... I don't know, but I would be 100% certain before you go buying parts. The $700 steering wheel could turn into a $2000 job.
2020 X5 M50i, Alpine, B&W, Air Susp, anthracite, coffee, **CD player**:
15+ PAGE BUILD THREAD:https://g05.bimmerpost.com/forums/sh....php?t=1694019
690HP / 928nM Dynotune:https://g05.bimmerpost.com/forums/sh....php?t=1729813
6-Piston/4-piston BBK:https://g05.bimmerpost.com/forums/sh....php?t=2097342
      01-08-2020, 12:49 PM   #4
CMBX23
CMBX23's Avatar
46
Drives: 20' 540i M Sport
2020 540i  [0.00]
I recently went to my SA at BMW and asked if this was possible to do. I was told that it would require a new wire harness, which is something that is currently unavailable unfortunately.
Hopefully they will make one soon
xbimmers
