Bimmerpost
4 Series
Technical Topics iDrive, Nav, Phone, Audio, Video, Cameras, Electronics Radar Detector Issue
      08-25-2019, 03:03 PM   #1
NBAFAN
Drives: 2020 BMW M340i
Own a fully loaded G20 XDrive. I have a valentine one radar detector and I also have it mounted on a bracket thatJust below rear view mirror. The problem is the radar detectors interfering with all the radar sensors on the vehicle specifically the radar cruise control..Has anyone had this issue and is there a workaround? The K40.360 is supposed to work but don't want to permanently install.
      08-25-2019, 03:21 PM   #2
claykin
1588
Drives: various BMW
I believe your issue is false laser coming from the gesture control IR sensor mounted in the overhead panel. If you cover that sensor with black electrical tape, the falsibg should stop.
BMW radar sensors are much higher frequency than your V1 is looking for. I believe BMW uses 76-77Ghz.
2023 840GC | 2021 740i | 2019 X3
      08-25-2019, 04:26 PM   #3
NBAFAN
Wow,I completely forgot about the gesture control. I think I’m just gonna deactivate it because I don’t use and hopefully that should solve a problem.
Thanks!
      08-25-2019, 04:35 PM   #4
claykin
1588
Drives: various BMW
Wow,I completely forgot about the gesture control. I think I'm just gonna deactivate it because I don't use and hopefully that should solve a problem.
Thanks!
If deactivating in iDrive does not disable the IR sensor, you'll want to cover it with a piece of opaque tape. On iDrive 6 cars, deactivating gesture control in iDrive didn't stop the falsing.
Or maybe you can find the fuse powering it, but I'd be concerned about powering off other devices.
      08-25-2019, 04:39 PM   #5
tturbolife
tturbolife's Avatar
236
Drives: None
2020 BMW M340i  [0.00]
I would just disable laser, by the time you're picking it up you've already been nailed
M340i: Arctic White, 790M wheels, Cognac interior, Aluminum Tetragon trim - Totaled
      08-26-2019, 06:16 AM   #6
NBAFAN
We own Laser Diffusers so I'll get them transferred and valentine one. I suspect that all of the radar manufacturers are going to
update software to accommodate all of the safety systems,
      09-20-2019, 05:58 PM   #7
HapkidoNinja
HapkidoNinja's Avatar
42
Drives: 2020 M340i xDrive
I have the same issue. I kind of like the gesture control but suspect I might cover the emitter on longer road trips.
Between Waze and the V1 have not been pulled over for several years (though my V1 is likely getting old in the tooth).
      12-27-2019, 08:47 PM   #8
Powaup
Powaup's Avatar
1253
Drives: 2021 Supra 3.0 (Past: 2015 M23
2015 BMW M4  [10.00]
Have this problem as well. Only happens at night though.... I just gave up and turned off laser on the valentine one
Check out my YouTube Channel Powaup
Instagram: @ Powaup
g20
