Bilstein B4-Sport issue - front sitting too high.
08-25-2019, 01:34 PM | #1 |
Save the manuals!
6016
Rep 6,747
Solved.
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc Last edited by 6ixSpd; 08-26-2019 at 08:23 PM.. |
08-26-2019, 12:30 PM | #3 |
252
Rep 1,157
Were any of the control arm bolts removed to help get the strut out? If so, were the bolts retightened with the arm in the loaded position(the bushing acts as a spring... if tightened while unloaded it will act like a spring)?
Volasko705.00 |
08-26-2019, 12:43 PM | #4 |
705
Rep 2,605
Drives: 06 330i E90, 18 530xe G30
This was the first thing that came to my mind when I read this. Though I'm pretty sure this isn't your first rodeo so I would assume you already know about this.
6ixSpd6015.50 |
08-26-2019, 01:46 PM | #5 |
Save the manuals!
6016
Rep 6,747
Control arm and it's mounts weren't touched.
New strut mounts (same height as the ones I removed, the old ones had not collapsed), bump stops, sway bar endlinks. None of which will raise the ride height by 1.5" which is what I am seeing. The upper and lower coils on the springs are also seated properly against their stops on the perches. The strut tab is fully seated against the knuckle as well. I'm at a total loss here. May have to bite the bullet and just slap some coilovers on it and call it a day. I've spent almost $800 CAD in parts in the last month and still not satisfied with the ride height and comfort. Or part this bitch out and get a F10...
'16 M3 | '23 718 Spyder Past: E92 M3, F87 M2, E39 M5, etc |
09-01-2019, 09:45 AM | #7 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
+1
Common sense is a flower that does not bloom in everyone's garden
09-11-2019, 02:04 PM | #10 |
60
Rep 217
09-11-2019, 04:34 PM | #13 |
Save the manuals!
6016
Rep 6,747
Night and day. Koni Yellow with Eibach ProKit maintains all the stock comfort, if not more, yet handles much better too. It's the best DD combo imo.
09-13-2019, 12:14 PM | #14 | |
60
Rep 217
Looking to do the same Did you need to replace any other parts. Bump stops etc.. Did you do the install yourself? Cost to instal? Were you going from a sport package suspension to the new setup? How much did was the ride height effected? In terms of mm or inch? Glad to hear you’re so happy |
10-14-2019, 10:51 PM | #15 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
10-16-2019, 10:39 AM | #16 |
705
Rep 2,605
