08-20-2019, 08:12 AM | #1 |
35
Rep 172
Signs of weak battery?
Hi guys,
About 6 months ago, I noticed that my car doesn’t start properly after stopping at the red light with auto start stop. It will result in a drivetrain error which goes away after restarting the engine. (I manually switch off ASS most of the times as I didn’t code it off) Now the car doesn’t switch off at the lights even without switching off ASS. Sometimes I have long cranking, and usually accompanied with a stabilization error for the rear spoiler. This error also goes away almost immediately. Signs of a weak battery? It’s almost 6 years and ~55k miles. I have JB4 for the past 30k miles, and no codes when scanning for error. Just changed my spark plugs as well. Thanks in advance. |
08-20-2019, 08:56 AM | #2 |
201
Rep 545
I replaced the battery on my 2012 F30 335i last year at 77k miles. The only symptom I noticed was: ASS didn't stop the engine at the red lights. However, I didn't get any error messages on the screen.
After the new battery was installed, ASS worked fine again. |
x-m4n148.00 |
08-20-2019, 09:17 AM | #3 |
63
Rep 109
Most places list expected battery life to be about 2-5yrs, living in a warm climate wont help extend its life. So it is probably safe to assume your battery is probably near the end of its life
https://blog.nationwide.com/extend-car-battery-life/ |
08-20-2019, 10:25 PM | #5 |
35
Rep 172
Thanks a lot. Should I change it ASAP or do you think I can wait till my next service in two months time? I read that there will be a error message for weak battery but have not seen it yet (fingers crossed)
08-21-2019, 06:07 AM | #6 |
E4 Mafia
329
Rep 418
if it were me I'd get it done asap. you don't want to be stuck somewhere with a a car that wont start knowing exactly what is wrong!
Squad - '90 E30 325i MT (225k) | '98 E36/5 318ti MT (153k) | '03 E46 325i MT (152k) | '04 E46 330xi MT (198k) | '15 F22 M235i MT (60k) | '15 F30 335i MT (80k)
KIA - '91 E30 325i AT (146k) | '02 E46 325i MT (212k) Bring back the purple M stripe |
08-21-2019, 10:11 AM | #7 |
949
Rep 279
Drives: 2014 328Xi GT, 2020 X3 MC
I'd change it asap. It could happen that the sunroof won't close at the worst possible time or something like that.
08-25-2019, 07:00 PM | #8 |
52
Rep 80
Drives: 2018 330i xDrive Gran Turismo
And can we open the doors properly if the windows don’t drop to clear the seals with a dead battery?
2018 330i xDrive Gran Turismo - Mineral White, Coral Red Interior
2016 Mazda Mazda3 GT - Deep Crystal Blue Mica, Off-white Interior 2007 Four Winns Horizon 190 |
08-25-2019, 08:48 PM | #9 |
8271
Rep 16,130
That's one of the reasons why I have the connector for my charger extending through my lower grille, wired to the charging posts. I don't have to open the hood to connect the charger, so I don't have to open the driver's door to open the hood.
08-26-2019, 09:23 AM | #10 |
F34 GT XDrive M Sport
Rep 1
Battery Issues
My battery was having some issues when starting the car it would say it’s losing power while off until it one day died. I jumped the car and got to the mechanic the battery scanner said it’s healthy... maybe the eco drive helped charge it up.
mgbabe When it died the doors would open but then wouldn't shut right due to the windows, gift and curse of the frameless doors!
The Angel
Instagram @Alpinewhitegt |
09-07-2019, 08:42 AM | #12 |
2034
Rep 2,815
Drives: F33 430 and F39 M35i
Don't forget to register the battery after changing it.
I don't see how people get batteries to last that long. I've never made it four years without replacing a battery. A coworker went 9 years on a battery before he traded it in. Not sure how he managed that. |
08-27-2022, 10:03 AM | #15 | |
I make videos for all things F34 !
55
Rep 40
This has happened to my last GT a few times…I want to say each time it happened it was raining. Other signs of a weak battery could be your windows not rolling up all the way, and you can see the window sticks out when you close the door. Easy DIY replacement. |
10-02-2022, 10:08 PM | #16 |
31
Rep 21
Drives: 2015 328i GT xDrive
You can also use an app to see the charge capacity on the battery (kind of like the iphone battery monitor). I have the Bimmercode app and it told me I was at 67% capacity. Replaced the battery and it now says 99% capacity (just posted my battery research if you live in Canada).
I was talking with a friend of mine who has an e60 and he suggested getting a battery charger (his reco was this one): https://www.walmart.ca/en/ip/schumac.../6000199054568 I have not bought it yet, but he has claimed he has got 12 years out of a battery by maintaining it with this. Anyone else have any experience using one of these? |
Amsham3.00 |
10-28-2022, 11:04 AM | #17 | |
Rep 4
Hi could you tell a bit more about the battery health app. Like where is it available.. How to use etc. TIA Regards |
10-28-2022, 02:30 PM | #18 | ||
31
Rep 21
Amsham3.00 SupremeF3455.00 |
02-06-2023, 09:04 PM | #19 |
Rep 7
Are the warnings the OP had typical of the way the vehicle reports battery issues or will it specifically identify a failing battery before it it mechanically detectable? I haven't had the issue, just curious how much advance notice the car will provide that a battery is near its end of life.
Anyone have data on how long a typical 2018 340 or similar can sit without being driven before parasitic drain will cause issues with starting? |
02-06-2023, 10:22 PM | #20 |
8271
Rep 16,130
In winter, when I only drive once or twice a week and then only in town, my battery maintainer is always plugged in. It's not just to be sure the car will start, it's also to keep the battery topped off, which extends its lifespan. Mine turned eight years old last week, still works like a champ.
02-10-2023, 01:28 PM | #21 | |
282
Rep 476
My record on original battery is 11-1/2 years on my dad's 2012 F10 with N55. Car was/is on battery tender for 6+ continuous months every year (April to October) while being garage stored. Daily driven November to March without tender.
2003 E39 530i 5-Speed w/ M Spec, Saphire/Black, M54B30, Active Autowerke Performance Tune
2010 Lancer GTS 5-Speed, Black Pearl/Black, 4B12 2015 F30 335i XDrive w/ M Sport Pack, Alpine White/Black, N55B30M0 2017 F34 340i XDrive w/ M Sport Pack, Azure II /Black, B58B30M0, Dinan Stage 1 |
02-13-2023, 03:50 PM | #22 |
41
Rep 106
I'm probably jinxing myself, but my 2016 GT has the original battery. Not sure about the first 3+ years of this car's life, but I do garage it and I commute ~ 3 days/week 80 miles roundtrip that's 60% highway.
I rarely use the battery tender, but sometimes in the winter when I know the car may sit for 4 days straight I hook it up. I was planning on getting a new battery before this winter, but I don't see any signs of weakness so I'll wait. |
