BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Engine, Transmission, Exhaust, Drivetrain, ECU Software Modifications
European Auto Source (EAS)
      08-18-2008, 10:01 AM   #1
JuniorDee
JuniorDee's Avatar
73
Drives: the speed limit
Racing Fuel?
Out of curiosity, has anyone put racing fuel in their M3 other than what I have read on this post:
http://www.m3post.com/forums/showthread.php?t=164325
any dangers with putting 110 octane in?
EDC.....viagra for your car
      08-18-2008, 10:17 AM   #2
Herms
26
Drives: '15 M235i
higher octane should be fine so long as you make sure it's unleaded fuel. I mix it in at times when I can find it just to try to get a 93 octane mix since all we get here in LA is 91.
'07 e92 335i (sold)
'08 e90 M3 (sold)
'15 M235i
      08-18-2008, 10:36 AM   #3
big fra
big fra's Avatar
28
Drives: M5,M3 CSL
Should have no problems at all!Here in the UK we have BP Ultimate 102 Ron at some pumps and that is excellent if not a tad expensive($8.00 a litre at todays exchange rate!)
      08-18-2008, 12:23 PM   #4
Kadarin
Ambassador of Crunk
17
Drives: SG/blk '08 E92 M3
Will there be any significant benefit, given that the engine is naturally aspirated?
      08-18-2008, 12:32 PM   #5
J08M3
J08M3's Avatar
285
Drives: 2011 M3 COUPE
I'm just guessing here. But I'd think there would be very little benefit if any at all. The engine was not tuned by BMW for 110 octane fuel so I would think it's not going to take advantage of the higher octane fuel. I am positive you will lose some HP with 87 octane and the computer will back of timing to not allow knocking. You might see a little gain with the race fuel as it will burn slower. You will not cause any damage to the car, just your wallet when you go to pay for the more expensive fuel.
      08-18-2008, 12:53 PM   #6
GT3 Tim
Moderator
GT3 Tim's Avatar
94
Drives: 2014 MB E63S
PencilGeek got +14hp with 100 octane vs. 91 octane. I guess the DME will adapt to the higher octane. How much remains to be seen. At some point, there is no gain...the DME cannot advance timing infinately, so there is a max benefit somewhere. Whether that be 93 octane, 95, 100, or somewhere else is the question.
Tim <--- apparently likes "3" cars
2014 E63S -- The Rocket
2014 F30 328i -- Kids car
2008 E90 M3 -- Sold
2004 GT3 -- Sold
1997 M3/4 -- Sold
1995 M3 -- Sold
      08-18-2008, 01:19 PM   #7
JuniorDee
JuniorDee's Avatar
73
I asked this question based on pencilgeek's results. I was thinking of mixing 93 with 110 to get to around 100. I was just afraid that if I run much higher than 100 and the engine is running rich then I could possibly have the engine running too hot.
      08-18-2008, 01:31 PM   #8
Herms
26
Drives: '15 M235i
+1 seen results that show an improvement. Also, since people can get more than 91 in Europe and in the US (just not Cali) the car is likely designed to use better than 91. Also, you get better mpg, though not nearly enough to justify the cost (101 octane near me costs $8.99/gallon)
'07 e92 335i (sold)
'08 e90 M3 (sold)
'15 M235i
      08-18-2008, 03:40 PM   #9
icemang17
icemang17's Avatar
41
Drives: 2008 E92 M3 DCT
as long as you run UNLEADED race gas it will be fine....I tried some 100 octane & there is an improvement!
Brian
2008 E92 M3, MR, DCT, extended BB leather, loaded!
1988 Porsche 928S4, Guards red/Champagne leather
1989 Porsche 928S4 track beast!!!
      08-18-2008, 04:27 PM   #10
GT3 Tim
Moderator
GT3 Tim's Avatar
94
+1
Higher octane, even 110, etc. won't cause a problem as long as it is UNLEADED.
2008 E90 M3 -- Sold
2004 GT3 -- Sold
1997 M3/4 -- Sold
1995 M3 -- Sold
      08-18-2008, 07:47 PM   #11
ChinoOrtega
ChinoOrtega's Avatar
Guatemala
50
Drives: 991 C2S
I've heard that mixing methanol with the gas can give 100oct, In Guatemala gas is the worst, so someone told me he had done this to his Cupra R, it's just a tank of methanol and it mixes with the gas before combustion and it gives you 100oct or whaatever octane you want, do you guys think this is a safe mod??? The only doubt we had was if the car could recognized the higher octane, and since it does do you think there's any drawbacks? any info woul really help since I was tempted to do it but wanted expert opinion, and I see some of the board members are experts, thanks
      08-19-2008, 10:11 AM   #12
GT3 Tim
Moderator
GT3 Tim's Avatar
94
Not really sure. I think you would be fine, but I don't want to tell you to go for it and then you have an issue!
I have also heard of people using Acetone, Toluene, etc. I think the major issue is not with the additive per se (as most "octane boosters" are basically comprised of this stuff), but with the purity. The crap you buy from Home Depot, etc. is not "pure". If you could get some laboratory pure stuff, then maybe...but personally, I would not risk it. I am not a Chemist, so I don't think I would go down that road based on what some numbnuts said on the net!
2008 E90 M3 -- Sold
2004 GT3 -- Sold
1997 M3/4 -- Sold
1995 M3 -- Sold
      08-19-2008, 11:19 AM   #13
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
I don't see why your engine would run richer with higher octane fuel. The ECU should change ignition timing only, and not the air/fuel mixture.
      08-19-2008, 12:14 PM   #14
GT3 Tim
Moderator
GT3 Tim's Avatar
94
The ecu will adjust timing, but it does also adjust your A/F mixture...that is what the O2 sensors are for. However, as long as you don't contaminate the O2 sensors (with leaded fuel, etc.), they should function properly and keep you at ideal A/F ratios all the time...octane levels would not effect this.
2008 E90 M3 -- Sold
2004 GT3 -- Sold
1997 M3/4 -- Sold
1995 M3 -- Sold
      08-19-2008, 12:18 PM   #15
MWorldorder
MWorldorder's Avatar
Drives: M4
I have 101 in right now and definitely notice a difference.
      08-19-2008, 12:25 PM   #16
lucid
lucid's Avatar
374
I know the ECU adjusts the A/F mixture, and many other variables as well, but that's not the question. The question is why would the ECU change the A/F mixture in the presence of higher octane fuel? What is the relationship between A/F mixture and octane?
      08-19-2008, 12:35 PM   #17
GT3 Tim
Moderator
GT3 Tim's Avatar
94
I don't think there is a relationship between A/F ratio and octane...I thought I said that in my last sentence...maybe not.
2008 E90 M3 -- Sold
2004 GT3 -- Sold
1997 M3/4 -- Sold
1995 M3 -- Sold
      08-19-2008, 12:39 PM   #18
J08M3
J08M3's Avatar
285
I can't imagine being able to notice the difference of 14hp gain as Pencilgeek got. Of course it can be measured, and if you are on the track. But driving on the street in a 414hp car compared to possibly a 428hp car can't really be that noticeable. Can it?
      08-19-2008, 12:53 PM   #19
lucid
lucid's Avatar
374
Now that I read your post again, it seems like you did, but the first part threw me off I guess.
Anyway, there actually may very well be an indirect relationship. Maybe a richer mixture will be more likely to knock, and in the presence of higher octane, mixture can be made richer for more power. However, there are many other relationships between mixture and efficiency and emissions, and I would assume those would dictate mixture more than anything else.
      08-20-2008, 10:02 AM   #20
GT3 Tim
Moderator
GT3 Tim's Avatar
94
I agree. I wouldn't think you would notice a difference.....However, things like throttle response, etc. can be felt. That may enhance the feeling of more power...I dunno.
2008 E90 M3 -- Sold
2004 GT3 -- Sold
1997 M3/4 -- Sold
1995 M3 -- Sold
      08-20-2008, 11:39 AM   #21
icemang17
icemang17's Avatar
41
Pencilgeek got a 14hp gain with 100 octane (same gas I buy)....but he also got a 17hp gain with the evosport pulley and Gruppe M intake....so in theory a M3 with the pulley, intake and 100 octane would be about 390whp....
Brian
      08-20-2008, 04:31 PM   #22
Gearhead999s
Gearhead999s's Avatar
814
Drives: RR Velar R=Dynamic M2C R1200GS
The noticable difference would be the torque gain in the lower rpm range,right where you can use it.14 hp at the top end you would never notice in the a seat of the pants test.Torque is good
m3post
