The Tire Rack
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Technical Forums > Suspension | Brakes | Chassis > Shock mishap
      08-16-2019, 06:41 PM   #1
330xiNewf
Drives: 06 330xi
Shock mishap
Was trying to get the top nut off my shock. I had the 6mm ratchet holding the top of the shock why trying to wrench off the nut. Then all of a sudden the 6mm stud at the top snapped off. What can I do now to get it off.... Is cutting the nut off my only option.
      08-17-2019, 02:05 AM   #2
avocet
252
Drives: 2007 328i 2011 X5d
Impact wrench?
Are you replacing the shock? A big pair of vice grips should do the trick on the shaft in wheel well.
      08-17-2019, 03:41 AM   #3
330xiNewf
Drives: 06 330xi
Originally Posted by avocet View Post
Impact wrench?
Yes I`m replacing the shock. Yea I`ll try the impact gun. Also where would I attach the vice grips to, where I would normally use a wrench getting the bottom nut off?
      08-17-2019, 11:51 AM   #4
avocet
252
Originally Posted by 330xiNewf View Post
Also where would I attach the vice grips to?
Underneath the boot on the piston rod... I dont recall if the boot rises enough when lifted to gain access or if you will need to cut it away. Since they are getting tossed it doesn't matter if you destroy the boot or damage the chrome finish.
      08-17-2019, 12:42 PM   #5
330xiNewf
Drives: 06 330xi
Well when the car is jacked up, you still can`t see the steel rod. And the new KYB shocks I`m ordering do not come with new boots... Hopefully the Impact Gun trick works or good bye nut!! LOL
I guess I could order new boots at $11.60 each. Might save me a headache.
      08-17-2019, 07:03 PM   #6
avocet
252
ah dang. Whatever way you choose hope it all works out! Hate these speedbumps on otherwise not that difficult jobs!
      08-17-2019, 07:25 PM   #7
bmwbaltimorem5
Drives: 2005 BMW M5
Following
      08-17-2019, 11:31 PM   #8
weehe126
1161
Drives: 2017 340i
Pull the bump stop down...
Appreciate 2
avocet251.50
      08-18-2019, 03:45 AM   #9
330xiNewf
Drives: 06 330xi
That's exactly what I did after and it worked!!! Got the shock out and the bolt is now off and I can remove the shock now. Man the shock is so bad that when I compress it down, it don't return back up. Crazy.
Thanks for all your help guys, appreciate it!
Appreciate 2
avocet251.50
