WTF did I do wrong? E93 M3 rear sway in non-M E91
08-15-2019, 05:51 PM | #1 |
3058
Rep 3,910
Please someone put me out of my misery... I've just installed an e93 M3 rear sway/ARB on my e91 330d. Besides that possibly not being a great idea, how could I mess it up?
The problem is that with the suspension at full droop, the bar touches the front underside of the upper arm. I've got the bar orientated so that the tips point upwards... There's surely no other way it would go in. I've got the brackets on the subframe orientated to that the short tab is at the top/rear. I've got the rubber mounts orientated so that the split is vaguely horizontal, not that it should make any difference to the clearance. I fitted new drop links, which are the same part number for M3 and non-m, according to realoem... All this agrees with the info I can find on newtis. What gives?? Last edited by Tambohamilton; 11-11-2019 at 04:35 PM.. |
08-18-2019, 12:24 AM | #2 | |
Daily Driver
108
Rep 199
03-26-2020, 04:54 PM | #3 |
3058
Rep 3,910
So, I sorted this out today. It's not pretty, but it'll work just fine. I tried putting the brackets on the other way around (opposite to how newtis says they should be), but that moved the centre section of the bar too close to the subframe.
At that point I was just a bit fed up, so I grabbed a drill and drilled the bracket holes out to 12mm (bolts are 8mm). That allowed enough slack to move the bar back away from the subframe a bit, and clear the other suspension arms too. So, a bodge fix, but it'll function 100%. Shorter links may also have done the trick, but £$... |
01-13-2022, 05:06 PM | #4 |
3058
Rep 3,910
Totally forgot I made this thread.
The answer, just in case it helps someone, is that you also need the M3 "wishbones"; they have more clearance than the non-M ones. No need to do anything with the sway bar brackets. |
