08-15-2019, 02:20 PM | #1 |
35
Rep 80
Unable to Change Drive modes or turn off start/stop - Intermittently
This happens about 50% of the time we get in the car. We go to turn off the start/stop and nothing happens when the button is pressed. Also cannot change drive modes with the buttons on the center console.
Anyone else have this problem? |
08-15-2019, 02:38 PM | #2 |
154
Rep 602
I have not but I assume the usual fix of resetting idrive by holding down the volume button for 30 seconds or so would apply. I have plenty of other weirdness that goes away by doing so.
08-15-2019, 03:38 PM | #3 | |
35
Rep 80
Do you know if there is a software update for this? |
08-15-2019, 03:56 PM | #4 |
154
Rep 602
From what I have read there is a general update that came out last month. I don’t know what specifically it addresses. It seems it is fairly difficult to get dealers to agree to perform the upgrade and for some it has caused problems. Mine is from March.
08-16-2019, 06:12 AM | #5 | |
35
Rep 80
Surprised no one else appears to be reporting this same issue we are having. |
08-16-2019, 06:54 AM | #6 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
Garage List 1998 Jeep Cherokee ... [0.00]
2011 Toyota Highlander [0.00] 1998 Plymouth voyager [0.00] 2019 X5 40i [0.00] |
Be sure your doors are fully closed. This has happened to me a few times, I finally realized I hadn’t shut the door all the way. Now it is the first thing i check if car won’t go into gear.
It isn’t obvious that your door is ajar as in other cars I’ve owned. |
08-16-2019, 07:20 AM | #7 |
35
Rep 80
This is not the issue. We are driving when we are unable to shut off the start/stop and change the drive modes (from Comfort to Sport for example). I can shift the gear selector to sport mode by moving it to the left, but still cannot use the buttons on the console.
08-16-2019, 08:05 AM | #8 | |
113
Rep 236
08-16-2019, 09:32 AM | #9 | |
4540
Rep 3,507
It is possible the connection under the switches might have come a bit loose or never fully snapped in... I'd say swing by the dealer for sure on it. I've had a couple different software updates never heard of or seen this problem. Do keep in mind in ECO/PRO you cannot deselect ASS. When you go into sport it auto disables ASS you should see it indicate that.
2022 M8 Comp Convertible
2023 718 Cayman GTS 4.0 2019 718 Cayman Base 2015 M235 Manual On the list for the M2 CS |
08-16-2019, 11:34 AM | #10 | |
35
Rep 80
Good idea on a loose connection. Will ask about that when we bring it in. OTOH, if it were that, why does it work sometimes and not others? Still will mention it. We never use Eco/Pro and yes the auto start/stop disengages when we shift to move the shift lever manually to the left to engage sports mode. This helps when at lights, but if sitting in the car parked with the AC on (such as when my wife runs a quick errand and I am sitting in the car or me running in and her waiting) this solution is not available. |
09-04-2019, 11:09 PM | #11 | |
Rep 4
09-06-2019, 01:30 PM | #12 | |
35
Rep 80
Many thanks. |
04-05-2022, 12:48 PM | #13 |
Rep 8
I am having the exact same issue! Did you manage to fix it?
05-02-2022, 09:32 AM | #15 |
Rep 18
I am having the same exact issue. Going to give the dealership a chance to fix it. Started with the ASS button working intermittently and they said they have ordered a new panel but that was about 6 weeks ago.
03-01-2023, 10:27 PM | #16 | |
Rep 23
Thanks |
