08-15-2019, 09:53 AM | #1 |
27
Rep 71
Hermanns Revenge
Otherwise known as "lane departure warning with steering intervention". Designed to give you the ****s when you first experience it . You are on a road which is clear of traffic except for a cyclist in front. In order to give him a wide berth you ease to the centre of the road and as you are approaching him the lane departure warning intervenes and shoves you left violently. What the hell ! who thought this up ? Of course in i- drive you can kill this stupid feature ( remembering to also do it for the spare key )
Wonder what other interesting experiences they have incorporated for the customer Last edited by Bumble; 08-15-2019 at 10:46 AM.. |
08-15-2019, 10:21 AM | #2 |
36
Rep 72
Couldn’t agree more, turned mine off after first drive.
BMW g20 330i msport
Portimao blue, Technology pack, Comfort pack, Msport+ pack, Premium pack, Visibility pack |
08-15-2019, 01:51 PM | #5 |
56
Rep 150
After driving back from the dealer, it was instantly turned off.
It's bloody awful |
08-23-2019, 03:06 AM | #6 |
2810
Rep 4,935
Drives: 340i MPPSK
If it encourages the use of indicators then that's a good thing. However if it intervenes when it shouldn't then it should be scrapped. Imagine having a passenger who tugged the wheel left every time they thought you shouldn't be moving right.
Also, if it intervenes and pulls the wheel left causing an accident, then technically could the car (BMW) be held responsible?
Life is a state of mind |
08-23-2019, 03:35 AM | #7 |
145
Rep 379
To be fair to the system driving late at night on empty motorways back from the airport after enduring all sorts of nightmares I find it very useful. That said it is my third car with such system I am used to using it but I select on and off because some roads around town where 40 is the norm too many cars just pop their noses out way past the lines and you have to avoid at last minute. This is the third system (both Audi and BMW) and by far the best iteration I have tried.
My wife was driving the other day first drive since we got it for a days outing and had to swerve to avoid a tractor not stopping at a side turning on a national speed limit road. She wasn't aware of the system being engaged and she easily overrode it after the initial surprise. That was medium intervention, she now drives it with low and hasn't complained so far. Not saying it is perfect but it if it was turned off completely, counter to the issue of it causing an accident, it did not prevent one, how would the insurance view it? Not a view just a question. |
08-23-2019, 04:32 AM | #8 | |
27
Rep 71
Not aware that it is mandatory to use autonomous systems if they have an OFF switch. |
08-23-2019, 05:41 AM | #9 |
2810
Rep 4,935
Drives: 340i MPPSK
I'm just thinking why would I want a technology active that works on a fraction of the parameters available to me as a driver? I'm not anti lane departure warning when it's just that - a warning (such as vibrating the steering whel), but when it intervenes that's another matter. E.g. you swerve to avoid a cyclist, the system detects you've crossed a line without indicating and swerves you back - straight into the cyclist.
There's also the argument that at this stage of early autonomous driving technology, you're potentially dumbing down drivers. How many will not bother to look and just change lanes in the belief the car will act if there's a problem? What about the other drivers who have to react to this sort of behaviour?
08-23-2019, 08:08 AM | #10 | |
240
Rep 534
Will be interesting to see how aggressive the BMW system is in comparison, the Ford is fairly gentle, it definitely doesn't grab the steering away from you, more a gentle nudge back on course if you stray too close to the line and then a vibration in the wheel if you cross the line. If you blatantly cross the line without indicating (e.g. over taking a bike) it just lets you (with the vibration warning in "full effect"). I tried a Toyota Rav4 that had a warning chime rather than a vibration, now that was very annoying and I couldn't find a way to turn it off without turning the whole system off... The argument about dumbing down driving is a difficult one. You are still completely accountable for your driving; it will be no defence in court that your lane avoidance system didn't work. Most people understand that and you can't always cater for the odd idiot who doesn't. If the BMW system literally yanks the wheel out of your hand however that's a different story because you wouldn't normally be expecting it and if it then forces you to hit something you were trying to avoid and effectively causes the accident then liability is very tricky!? You could argue that seatbelts, airbags, ABS, traction/stability control encourage drivers to be more reckless because you're less likely to get hurt but most people treat them as an added safety protection, not moving the barrier closer to the edge (this is a BMW forum tho!? ;-) ). Most accidents are low speed, lack of attention issues (e.g. hitting someone up the back because they stopped quickly, pulling out without noticing something coming, reversing into someone in a car park) and modern safety tech will definitely reduce those. I've had my "your about to crash" warning come on a few times slightly quicker than I'd noticed myself when something ahead has stopped quickly. Maybe I'm just getting on a bit ;-) Last edited by tricky6; 08-23-2019 at 08:15 AM.. |
08-23-2019, 09:41 AM | #12 |
711
Rep 1,239
Your post made me check whether the G20 is supported on Bimmercode and it is so you could code out ASS.
Current: Portimao Blue G21 330i
Previous: EB F30 340i Shadow Edition Previous: EB F30 330d xdrive |
08-23-2019, 01:58 PM | #13 |
27
Rep 71
Actually I have found the auto stop/start on my G20 pleasantly good .It works so well that stopping and cutting back in are so discreet that no noise or engine shake occurs, hardly any system lag. Whereas in my Q3 and previous F30 I always switched the systems off before moving, in the Bumble mobile I now tend to leave them active.
08-23-2019, 04:20 PM | #14 |
85
Rep 179
Agree with the above. I had a 330i on test for a day and found the system quite aggressive.
Whereas other systems just vibrate the steering wheel, the BMW actually tries to steer you. This is fine if you’re genuinely drifting out of lane, but I found myself fighting against the system going along a slip way to join a dual carriageway. Because that involved moving across a dotted white line, the system thought I was drifting out of lane (and before you ask, yes the indicators were on!) |
