NBT EVO OABR to Ethernet Cable Diagram
08-14-2019, 05:49 PM | #1 |
12
Rep 32
I'm looking to make my own coding cable sinve I've got the oabr connector and cat5 or 6 depending what is needed. Does anyone out there happen to know what the pins need to be in order to have this work directly to an ethernet cable? I'll be coding from my laptops ethernet port with the stereo plugged into the car (everything but oabr obviously).
Any help would be greatly appreciated. |
08-14-2019, 09:15 PM | #2 |
12
Rep 32
vilord vilord actually had the pinouts for everything written up in the development thread. A huge thanks to him and especially Nickco43 from that thread.
Copying and pasting it here in case someone needs just this down the road: OABR socket: 61139299610 OABR pins: 61139230105 pinout: evo side: 2: ETH ATM RX- 4: ETH ATM RX+ 8: ETH ATM S 17: ETH CODING TX+ to RJ45 pin 1 and/or OBD2 pin 12 18: ETH CODING RX+ to RJ45 pin 3 and/or OBD2 pin 3 19: ETH CODING TX- to RJ45 pin 2 and/or OBD2 pin 13 20: ETH CODING RX- to RJ45 pin 6 and/or OBD2 pin 11 atm side: 2 - ETH + to evo pin 4 3 - ETH S to evo pin 8 4 - ETH - to evo pin 2 7 - KCAN2 High to retrofit adapter KCAN2 lines 9 - KCAN2 Low to retrofit adapter KCAN2 lines Passthrough mic, bmw assist: 15 - Mic + to head unit quadlock 17 16 - Mic - to head unit quadlock 22 17 - Mic S to head unit quadlock 33 18 - Mic S to microphone 19 - Mic - to microphone 20 - Mic + to microphone Last edited by DenoirN54; 08-14-2019 at 09:46 PM.. |
lab_rat394.50 |
08-30-2019, 10:13 AM | #3 |
488
Rep 1,309
For the ATM cable, the factory uses a single 18 or 20 gauge twisted pair of stranded wire, not the typical 28 gauge tiny stuff you'll find in cat5/6 ( it follows the BroadR-Reach/100base-T1 standards ).
I used the thickest shielded cat5/6 cable I could find, which I think was 24g, but even that is super thin and more likely to snap over time due to vehicle vibration/motion... just something to keep in mind when choosing cable. And don't use solid wire, it'll break way too quick. |
lab_rat394.50 |
08-30-2019, 10:17 AM | #4 |
488
Rep 1,309
oh, also, at least some of the eNBT emulators when active seem to interfere with the coding ethernet port.
I found that a bunch of the time my laptop would not connect. just some extra weirdness to make it more fun! |
