08-12-2019, 09:49 PM | #1 |
NASDAQ
Rep 24
Heads UP Display
For anyone who had/has an F15 and now a G05.......
Do you notice that the Heads Up Display is completely useless in the G05 if you are wearing polarized lenses yet that was not the case in the F15? Anyone find a "fix" to this within the settings or know what the issue is between the two cars? Thanks in advance..... |
08-12-2019, 09:53 PM | #2 |
6290
Rep 5,324
I can see it with my polarized lenses. it is just not as bright. I did just get another pair of RX lenses in a separate pair of Prada sunglasses just so I didnt have it so dim. There were a lot of other issues with traveling with polarized glasses like most gas pumps displays disappear. I usually take a few different pairs when traveling. You can always slightly tilt your head and the display will get a lot brighter. It works if you really have to concentrate on directions in the heads up display.
08-12-2019, 10:04 PM | #3 |
360
Rep 133
Polarizing, whether a lens in a camera or a pair of glasses, is designed to cut down on reflections; given how the HUD on basically every car I know works (reflecting off the windshield), polarized sunglasses will by nature cut down on the visibility. The extent of how much it disappears depends on angles (just test this by angling your sunglasses in the car next time), but I have a pair of sunglasses that aren't polarized in my door pocket too.
First world, but annoying.
2020 G05 40Msport, 2002 E39 M5 (AW on black), 1969 Porsche 912 w/?86 Euro 3.2 swap
M4 (sold) 335is (sold) |
08-12-2019, 10:10 PM | #4 |
5556
Rep 4,504
Drives: 2022 iX xDrive50, DGM
Didn't work in my F15 or my Audi Q7 with polarized lenses - or at least visibility was severely limited. So much so that I specifically used/use non-polarized sunglasses.
08-12-2019, 10:27 PM | #5 | |
778
Rep 1,070
2018 M3 6 spd
2017 M3 AW/SO 6spd 2014 435i M sport BSM/Coral 6spd (retired) 2013 550i M sport Alpine White/Cinnamon (retired) |
08-12-2019, 10:35 PM | #6 | |
The Dark Knight
422
Rep 1,262
08-13-2019, 07:36 AM | #7 |
Retired soccer mom
252
Rep 937
Drives: x5 40i 2019
Garage List 1998 Jeep Cherokee ... [0.00]
2011 Toyota Highlander [0.00] 1998 Plymouth voyager [0.00] 2019 X5 40i [0.00] |
I didn’t order HUD because I always wear polarized glasses. I kind of wish I had ordered it, just for resale, but I won’t wear anything but polarized sunglasses.
08-13-2019, 07:53 AM | #8 |
31
Rep 85
As people have said, polarized lenses either don't work with the HUD or severely cut down on the brightness of its display. I knew this going in but love my polarized lenses. Spoke to a guy at a sunglass shop and picked up a pair of Revos that were specifically made for this type of thing - aviator version or some such. It seems to dim the display when looking through a little bit, but not too bad. It's most noticeable when it is really bright and sunny, but for average sunlight it seems to work well.
Tenac4539.50 |
08-13-2019, 10:23 AM | #10 | |
838
Rep 1,236
It has not effect on polarized glass. |
08-13-2019, 11:03 AM | #11 | |
2723
Rep 4,337
08-13-2019, 11:04 AM | #12 |
838
Rep 1,236
08-13-2019, 11:15 AM | #13 |
2723
Rep 4,337
So if you are on a circular track, doing 130mph and therefore your head is tilted, the HUD will tilt too? Ok, seriously, isn't the default position horizontal. I get the up/down and sideways positioning but the rotation just seems strange to me. I don't have it, so I can't play with it.
Tenac4539.50 |
08-13-2019, 11:26 AM | #14 |
186
Rep 506
It's a pretty fine adjustment to the angle. I think it is there because there are factors that can get it out of wack, for example, a windshield replacement. Putting it into xDrive just makes it easier to fix things when it does get tilted.
08-13-2019, 11:34 AM | #15 |
1053
Rep 1,952
Rotating the HUD will help visibility with the polarized sunglasses. When two polarized lenses are aligned perpendicular to one another you cannot see through them, as you rotate them, you gain more visibility. This is the science on how the lenses cut down on glare. The same works for the reflection of the HUD - instead of tilting your head (getting away from that 90 degree angle) you rotate the HUD as much as you can tolerate so you can see it with your polarized sun glasses w/o having to tilt your head.
1230vani652.50 |
08-13-2019, 11:47 AM | #16 |
186
Rep 506
I'd test that rotating the HUD image made any difference. If it's just the image itself that is being rotated then it won't make a difference. You would have to rotate the image display to change the brightness through polarized sunglasses.
My guess is it's just the image itself that is being rotated so it wouldn't make any difference, but it would be worth a try to find out for sure. I don't have any polarized sunglasses to try it out though... I stopped using them a while ago because displays in cars and phones are polarized enough to make them look dim through polarized material. |
08-13-2019, 12:30 PM | #18 |
2723
Rep 4,337
HOW DOES BMW HEAD-UP DISPLAY WORK? The BMW Head-Up Display system uses a small projector and a system of mirrors that beam high-contrast images onto a translucent film on the windscreen. Images are projected directly into the driver’s line of sight, and appear about two meters away, making them easy to read and process. BMW Head-Up Display has adjustable height for optimal viewing, and produces full-color images in many newer BMW models. Drivers can control their BMW Head-Up Display output through the iDrive Controller. General info article/video but doesn't speak to polarization or rotation.. .. . |
08-13-2019, 12:55 PM | #19 |
377
Rep 623
Rotating the screen won’t help much. Rotating your head to one side or another will open up a partial view of the HUD when wearing polarising glasses. I decided HUD > glasses and got a new non-polarising pair for the car. They can also cause an issue with the idrive screen and dash...
08-13-2019, 01:04 PM | #20 | |
838
Rep 1,236
08-13-2019, 01:42 PM | #22 |
5556
Rep 4,504
Had HUD on my last 4 cars with the rotation feature, and no, it won't help visibility with polarized lenses. It might help by causing you to rotate your head, but the primary purpose of the rotation is to correct the - perceived - horizontal aspect of the display for those of us with OCD. Only a very minor correction might be needed, but at least it enables you to correct whatever tilt might be present on the display to where you think it should be.
