Coby Wheel
BMW 3-Series (E90 E92) Forum > E90 / E92 / E93 3-series Powertrain and Drivetrain Discussions > N54 Turbo Engine / Drivetrain / Exhaust Modifications - 335i > Installed twin disc x-clutch and flywheel, now excessive noise.
      08-12-2019, 12:28 PM   #1
fredcase
261
Drives: Bmw=trash
I installed a x-clutch twin disc, mfactory smfw, ecs transmission mounts, new guibo, and brass pivot pin. I get a crazy grinding chattering noise, and vibrations. The noise is only heard in gear under load and in neutral with revs. No noise with clutch depressed.
      08-12-2019, 12:32 PM   #2
fredcase
261
Drives: Bmw=trash
These videos don't do it justice, its very load and apparent from inside while driving.
      08-13-2019, 02:16 AM   #3
streetpro
streetpro's Avatar
Czech_Republic
87
Drives: e92 335iA
I had a Tilton twin clutch plus a single mass flywheel on a S50 engine and it was far from being quiet... at idle even the transmission (MT) was chattering... and the launches were harsh, engine ignitions were beating through the trans to the chassis... but that was due to the single mass FW and no springs in the clutch itself..
"If everything seems under control, you're not going fast enough.” Mario Andretti
fredcase260.50
      08-13-2019, 10:07 AM   #4
dpaul
654
Drives: 2009 E90 335xi, 2011 E93 M3
Honestly, what did you expect? Why do you think BMW (and everybody else) installs those expensive and fragile dual mass flywheels?
You are probably aware of this but FWIW, you expect the noise to cease when you disengage the clutch. The noise is from gears in the transmission rattling back and forth reflecting the periodic changes in crankshaft rotational speed (i.e. momentarily faster when each cylinder fires). The noise does not come from the flywheel or clutch itself. The whole point of the DMFW is to damp out those periodic variations.
tisdrew97.50
      08-13-2019, 11:43 AM   #5
fredcase
261
Drives: Bmw=trash
Didn't expect it to be this bad.
      08-13-2019, 11:45 AM   #6
dpaul
654
Yeah it sucks - but performance comes at a price. Even with a dual mass flywheel it is clearly audible in my M3 (although my 335 is silent with the OEM DMFW).
fredcase260.50
      08-13-2019, 11:52 AM   #7
type-dRew
type-dRew's Avatar
641
Drives: 2009 335i xDrive
Yeah, thats to be expected.
Steel or aluminum flywheel?
2009 335i xDrive AT / 177k+ miles
PSP 750ic / Fuel-It! Stage 1 / BMS CP / Sutphin Tuning / RFP E50
11.61 @ 117.5
New setup; Covid 19Ts on RFP 93 + ARM inlets, dp, VTT cp and PSP outlets
fredcase260.50
      08-13-2019, 12:37 PM   #8
fredcase
261
Drives: Bmw=trash
steel
      08-13-2019, 01:03 PM   #9
type-dRew
type-dRew's Avatar
641
Originally Posted by fredcase View Post
steel
Seems right then, was going to say thats pretty quiet for alum
11.61 @ 117.5
fredcase260.50
      08-13-2019, 01:49 PM   #10
nissubaru
233
Drives: 09 335i MSport + 1990 300ZX TT
That does sound pretty shitty in my opinion. I have a Spec stage 2 clutch plus steel flywheel and it sounds like a tractor at low speeds but the more you rev it the less noticeable the sound is. No other knowledge on clutches to add, just stating how mine sounds.
fredcase260.50
      08-14-2019, 07:05 AM   #11
type-dRew
type-dRew's Avatar
641
Yeah, id always expect more noise when adding more moving parts and clamping strength
Ive never heard a quiet twin disc
11.61 @ 117.5
