08-11-2019, 10:21 AM | #1 |
37
Rep 128
inlet pipe options ps2 turbo?/install kit nec?
Ready to order my ps2 today but wondering whats the difference between the inlet options... one is a hundred dollars more than the other
Also do i need installation kit? Thank you in advance for sharing your knowledge |
08-11-2019, 10:59 AM | #2 |
629
Rep 965
Drives: 2016 F36 435x MSport
Regarding the inlet.... The more expensive one is a full replacement single piece. The cheaper one is a subsection that you would retrofit into your existing inlet pipe.
08-12-2019, 03:59 PM | #3 |
No 55mph
1622
Rep 8,476
I replaced my inlet with the more $$ one piece design, the turbo to ic pipe with ER, and added DV+ when I did my ps2 install.
Already had the ER CP, Fabspeed Catted DP, AA FMIC, and Dinan CF hi flow CAI Also went with 3.5bar map sensor upgrade for higher resolution at hi boost and the appropriate tweaking to my AA OBD Stg2 flash tune + 1 step colder NGK plugs gapped to .022 You will find there are a lot of ancillary items that should be installed at same time to get optimum performance out of a bigger turbo, rather than just throwing the turbo on and go Next I will be going with upgraded HPFP for security CAN you run without this extra stuff? Guess you could, but I like to be thorough
F32 435ix//MGM//M Sport-Prem-Tech-Driver Assist-Lighting-Cold Weather-Dyn Handling Pkgs//M4 Black Lthr Int w/M4 Alum Blade Trim//HK w/Bavsound Stg3//763M//M4 Euro LCI Tails//M4 Mirrors w/CF Covers//AWCarbon CF F/R Spoilers-Side Splitters-Diffuser 6WB/ID6 HU+HUD/IND M4 Alcantara Armrest//PURE S2 Turbo//AA FMIC+DP//ER CP+TIC//3.5bar TMAP/TS DV//AWE Tuning Exh w/Blk Tips//Turner MS CF Intake//BM3 Cary Jordan Tune//MPerf Diff//PrecRW Ignition Kit
08-12-2019, 04:39 PM | #4 |
BimmerPost Supporting Vendor
24199
Rep 190,807
Option 1:
Is the custom aluminum section and t-bolt clamp only. You will need to cut your OEM inlet and clamp it to our section. Instructions and t-bolt clamp included. Option 2: One piece complete aluminum pipe
08-12-2019, 04:47 PM | #5 | |
37
Rep 128
Definitely going to go with second option |
08-12-2019, 04:48 PM | #6 |
24199
Rep 190,807
08-12-2019, 04:52 PM | #7 | |
37
Rep 128
What I don’t know is do i need new lines, oil and coolant, from turbo to block? ? Never heard of the 3.5 map sensor thing so I will do my research on that tonight I have a bm3 stage 2 now, 93 octane, going to do turbo upgrade now, and either put in a b58 pump a little later or pony up the money for the xdi, Little worried about going full xdi because I really don’t want to have to swap my clutch. |
08-12-2019, 05:49 PM | #8 | |
61
Rep 188
I would also get the 3.5 map sensor because it will allow you to run higher than 21psi on a custom tune in the future. |
08-12-2019, 08:01 PM | #9 | |
37
Rep 128
https://parts.bmwofsouthatlanta.com/v-2014-bmw-335i-xdrive--base--3-0l-l6-gas/engine--turbocharger-and-components |
08-12-2019, 08:02 PM | #10 |
37
Rep 128
08-12-2019, 08:05 PM | #11 | ||
61
Rep 188
08-13-2019, 07:31 AM | #12 |
101
Rep 221
I didn't get the install kit. I contacted bmw direct for a parts list required and ordered from fcp euro. It came to 128$ insted of the 200 od pure wanted
08-13-2019, 07:39 AM | #13 | |
1106
Rep 1,499
You don't need to get the 3.5bar MAP sensor right away if you're not planning on running high boost, over 20 PSI. It's super easy to replace so can be done at a later date. I would reccomend replacing or upgrading anything that's easier to replace while you have the turbo out, like the inlet, turbo to IC pipe, oil/coolant lines and DV+.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
08-13-2019, 08:04 AM | #14 |
4528
Rep 5,392
Drives: 2015 BMW 335i x-Drive Auto
The 3.5MAP sensor is simply the stock MAP sensor from the 4-cylinder engine because it is set to handle higher boost intake levels. It's a 5-minute install.
08-13-2019, 08:21 AM | #15 | |||
4528
Rep 5,392
1) Did you notice any increase in turbo lag with the Pure Turbos Stage2 turbo upgrade, especially from standing starts and around town in low rev daily driving? 2) I believe there are two MAP sensors- on the charge pipe before the throttle body, and on the intake manifold. Did you upgrade one or both of these? BootMod3 has settings for each one. 3) I'm looking to upgrade to DV+ now. How many hours might it take to upgrade all at once the DV, the inlet pipe and the TIC (turbo to intercooler pipe)? Trying to figure out what a reasonable labor quote might be. Thanks! |
08-17-2019, 02:36 PM | #16 |
97
Rep 373
Would the 1 piece design heatsoak quicker then the original design which mostly uses the stock plastic inlet? Pointless spending big money on a carbon intake like the eventuri go cool the air if it gets heated up straight away
'14 F20 M135i EWG FBO:// INJEN INTAKE // PURE INLET// TURBOSMART BOV DUAL PORT // //CSF INTERCOOLER // ER CP // SNOW S2.5 METH KIT // B58TU HPFP // NGK 97506 // ER DP // TMSS MID PIPE //MPE // MPBBK // UR STRUT BRACE // BM3 CUSTOM JORDAN E85 TUNE // XHP STAGE 3 // |
08-17-2019, 04:01 PM | #17 | |
4528
Rep 5,392
Heat soak occurs when the boosted or pressurized air is entering the engine's intake manifold at too high of a temperature. The engine's failsafe measures kick in to limit the engine's power. That's heat soak. You can't run at high power again until the boosted air temperature goes down into normal operating range. The biggest factor by far in keeping down the temperature of the boosted air is the size and efficiency of the air-to-air intercooler. Boosted air leaves the turbo through the TIC pipe (turbo to intercooler pipe), enters the intercooler where it is cooled, and exits into the charge pipe which takes the cooled, pressurized air to the engine to be combined with fuel. So it's a properly chosen, for your application, intercooler that prevents heat soak. Hope this helps! |
08-17-2019, 04:19 PM | #18 | |
97
Rep 373
08-17-2019, 04:37 PM | #19 | ||
4528
Rep 5,392
The metal being used in the turbo inlet pipe is aluminum which dissipates heat very quickly. If your fear about aluminum was correct then all of the aluminum charge pipes would be driving up IAT temps, and they aren't. Again, for the turbo inlet pipe the choice of one-piece or two-piece is inconsequential in terms of heat soak. It's simply your own personal preference. |
08-17-2019, 04:54 PM | #20 | |
97
Rep 373
