BMW M3 Forum (E90 E92)
Go Back   M3Post - BMW M3 Forum > E90/E92 M3 Technical Topics > Track / Autocross / Dragstrip / Driving Techniques
      08-16-2008, 11:36 AM   #1
lucid
lucid's Avatar
374
Drives: E30 M3; Expedition
Camera recommendations for the track?
I will be buying a camera for recording on the track. What do you recommend? Please speak from experience with a specific model rather than broad opinion on electronics. Meaning, please recommended devices that you know work well as opposed should work well.
The only requirements I can think of are that it should have effective image stabilization and be able to record 2 hrs of video, which, I suppose, is a function of desired resolution and memory size, but I am curious about what people think is appropiate in that regard.
Thanks in advance.
      08-16-2008, 11:50 AM   #2
icemang17
icemang17's Avatar
37
Drives: 2008 E92 M3 DCT
The "hero" is a great lightweight little camera that can be mounted just about anywhere...cheap too at about $180 with window mount
http://www.electricsupercharger.com/products-hero.html
I need to buy one before my next track day
Brian
2008 E92 M3, MR, DCT, extended BB leather, loaded!
1988 Porsche 928S4, Guards red/Champagne leather
1989 Porsche 928S4 track beast!!!
      08-16-2008, 01:18 PM   #3
lucid
lucid's Avatar
374
Thanks. Does anyone have experience with this camera? Maybe another requirement is a mic jack as I might consider using an external mic.
      08-16-2008, 01:22 PM   #4
ace996
NASA/PDA Instructor
ace996's Avatar
21
Drives: E92M3
The industry standard is ChaseCam. Not cheap, but neither is the M.
http://www.chasecam.com/
"Arcadian, I've fought countless times, yet I've never met an adversary who could offer me what we Spartans call "A Beautiful Death." I can only hope, with all the world's warriors gathered against us, there might be one down there who's up to the task."Μολὼν λαβέ!!
      08-16-2008, 04:33 PM   #5
cchan
11
Drives: '12 F30 328i/'11 C2S/'04 GT3
I started with a regular DV camcorder mounted onto a bar mounted onto the passenger headrest supports. At that location, you will probably need a wide angle lens adapter, assuming this is for DEs and you want to see A pillar to A pillar out the front window as well as your hands/steering wheel.
Relatively cheap these days, great quality, high res video, and most camcorders will do well with changing light conditions and interior/exterior brightness differences. But watching it you have to deal with tape winding, and if you want to upload, you have to connect it to your PC, transfer, edit, etc... becomes a bit troublesome to deal with. Would avoid hard drive/CD type camcorders if you go this route, the vibration is a problem from other people I know who have tried.
I then shifted to a "digital" recording solution a couple of yrs ago. Went with a Hoyt bullet cam (was cheaper than ChaseCam at the time would still take a look since I think they use the same Sony electronics for the bullet cams), connected to an Aiptek MPVR mini digital camcorder (was ~$100 at the time). The Aiptek camera/optics absolutely suck, but it does take a standard video input and converts/records to MPEG. So the bullet cam is just providing the video signal and the Aiptek is just digitizing and recording it. Nice thing about the Aiptek being a "camcorder" is that it has its own display screen, which is useful when mounting/aligning the bullet cam, plus I can play back and watch the video on the spot.
Nice thing is that I just take the memory card out, pop it into the card reader and I can just watch it on the PC as a video file. I only record at quarter VGA resolution, so I think about 2 hours will fit on a 2GB card. My bullet cam is only 380 lines of resolution, so more than enough for QVGA.
With the bullet cams, because they have a wide field of view and are lightweight, image stabilization is not really an issue IMO. There are probably newer/better digital video recorders now.
Assuming you are recording goal is more to be able to review what you did on the track, and aren't planning to produce a high def video, you can go with lower res digital solutions. lucid, I can send you a sample video if you want to see how it looks.
Golden Gate BMWCCA - Car Control Clinics
'13 C4S/'12 328i/'04 GT3
Past: '09 M3 DCT/'03 M3 SMG/'95 M3... missing an E30 I suppose...
      08-18-2008, 09:23 AM   #6
lucid
lucid's Avatar
374
That looks good, but not sure if I want to shell out that much at this point. $1000 with the built-in accelerometer, which would be a must I'd say. Thanks.
      08-18-2008, 09:29 AM   #7
lucid
lucid's Avatar
374
Thanks for the this suggestion. This type of approach seems like a low-cost option, probably in the order of $250-$300.
      08-18-2008, 03:44 PM   #8
icemang17
icemang17's Avatar
37
A friend runs that site...he races the red 928 with Heros all over the place....including on the rear bumper....it gives some great footage....look him up on youtube and you can see for yourself...his handle is zanick
Brian
      08-19-2008, 03:53 AM   #9
M3Rad
M3Rad's Avatar
Drives: 2008 BMW M3 DCT
I bought a JVC Everio. It records in Compact Flash card. Pretty light, good lense, $400 on ebay. It works quite well.
03 Celica GTS
04 Hummer H2
07 Cayman S
08 BMW M3
09 Scuderia
      08-21-2008, 12:44 AM   #10
skierman64
skierman64's Avatar
125
Drives: E92M3-E46M3-E46Wagon-E89Z4-E36
1994 325is Race Car  [0.00]
2011 BMW Z4  [0.00]
1998 M3 Coupe  [0.00]
2008 M3 Coupe  [0.00]
Here's my low budget solution. My daughters low end Hitachi DVD camcorder. It records on 30 minute DVDs. So you essentially have to change out a disk per session. I hook it to a cruisecam.com mount which clips to the headrest mount. I think the mount was about $50. I put it on the driver's headrest so it's looking right over my right shoulder. It's quite adjustable for angle and position left and right.
Next problem is the camcorder battery, since it only lasts about an hour, I hooked up a small (350 watt) Radio Shack power inverter in my trunk which I previously secured with duct tape and cable ties to the bar that was next to the battery in the trunk on my E36. However for my E92, I'm going to use those metal pipe sinching things (can't think of the name), and secure it to just above the HD radio mount. (on my car with HD radio, left side of trunk, there's a plastic tray, I'm going to pull the tray out and secure the inverter to the metal mount for the radio.) I'm going to use this set up for this weekend and I'm going to hook it up tomorrow night, so I'll take pics.
I haven't done this in my E92 on the track yet, so this is the first attempt, however I did some test fitting tonight and it seems like it will work.
Here's some video using this setup in my E36. Perhaps not wide angle enough, but it's good enough for me. For the most part the camera is pretty steady, even on a rough track like Summit Point.
Here's some video using this setup in my E92, not on the track.
Not perfect, but it works great and it's low budget.
Invest Wisely...The best mod for your money?? BMWCCA high performance driver's school. The mod that lasts a lifetime and improves the performance of any car you drive[/LEFT]
Search this Thread:
Advanced Search
m3post
