Garage opener question
08-15-2008, 06:28 PM | #1 |
12
Rep 265
so i recently bought an e90 335i and joined this forum after hearing about it from my friends. I wanted to know if there is something wrong with my garage remote option thingy or if im just setting it up wrong.. (because its not working.. followed the steps on the manual).. does anyone know how to set it up?
08-15-2008, 06:35 PM | #2 |
Tire Racks
53
Rep 1,232
Depends. Is it a rolling code garage? Look at your garage manual, and if it is, then it should have directions on how to program it. I have a rolling code, and in the motor is a learn button. I press the button, run to the car, then press the garage button I want and the garage lights start flashing. (for my type of garage, dunno about yours)
Oh yeah, and when it flashes I let go, then the garage works. |
08-15-2008, 06:54 PM | #3 |
13
Rep 623
I tried and could not open mine garage but mine brother's garage its open just fine, still do not know what the heck? will try again sometime.
08-15-2008, 08:13 PM | #4 |
21
Rep 970
I had this problem too.. but do the steps in the manual exactly as it tells you. And THEN go to your garage door opener in the back and press the LEARN button. There'll probably be a little light flashing beside the button. After you press it.. PRESTO!
08-16-2008, 02:46 PM | #5 | |
13
Rep 623
PRESS THE LEARN BUTTON Confirmed and it works now. Thank you bro. |
08-16-2008, 03:43 PM | #6 |
pull my finger to get your kinder® surprise
148
Rep 10,455
it's in the manual all along. Not some new information that just popped up recently. It's really useful to read the owner's manual that came with the car.
08-17-2008, 03:26 AM | #8 |
Philanthropist
28
Rep 1,054
it didnt work for me. i just moved and the new house has a "liftmaster" garage door opener.
let me get this right. you pressed the learn button on the garage door opener, then ran to the car and held down just the desired button? or did you press it with the garage door opener button simultaneously?
"Where is your sense of adventure guys? If we don't cut in and out of traffic we will disappoint all those who think BMW drivers are all a**holes."
The 2011 3-Series coupe offering the infamous "Harmon Kardon Badging" |
08-17-2008, 08:15 AM | #9 |
I'm feeling much better now, Dave
Rep 305
Here's my version of what was in the manual, and took me about 4 times to understand.
(From the 328i/335i manual "Practical interior accessories - Integrated universal remote control", page 83). Opener: The Garage Door Opener & Receiver. The machine on the ceiling of the garage that opens the garage door and it's radio receiver that's built in. Hand-Held Transmitter: The Original Hand-Held remote radio transmitter that signals the Opener to operate. (This is the gadget you are trying to not have to carry around). Integrated universal remote control: This is the transmitter built into (integrated into) the BMW's rear view mirror, with 3 buttons and an LED flasher. 1) To clear ALL previous programming for the Integrated Transmitter, hold in BOTH outer memory buttons (the left most and the right most on the bottom of the rear view mirror, at the same time), for about 20 seconds, until the LED on the far left blinks twice. This erases the programming for all three buttons. (You can't clear them individually). 2) Determine if your Opener and Hand-Held Transmitter system was built to be compatible with the HomeLink standard (look for the logo, a stylized house with an arrow pointing up into the bottom. If that logos not visible, try going to the website of your opener, and look around. If you can't find that, surf the HomeLink site: http://www.homelink.com 3) Determine if your Opener and Hand-Held Transmitter system using an alternating (rolling) code. The more modern Opener systems may use a rolling code for security, (greatly reducing the chance that your neighbors remote will open your door). The remote transmitter for this type of system must change codes every time it's used according to a pre-set pattern, Again, see your original equipment information. 4) To clear ALL previous programming for the Integrated Transmitter, hold in BOTH outer memory buttons (the left most and the right most on the bottom of the rear view mirror, at the same time), for about 20 seconds, until the LED on the far left blinks twice. This erases the programming for all three buttons. (You can't clear them individually). 5) Simultaneously press the button on your Hand-Held Transmitter and the one of the three Integrated Transmitter buttons you have chosen. a) The LED will flash slowly at first, and when the Integrated Transmitter has learned the transmit code from the Hand Held Transmitter, the LED will flash rapidly. Release both buttons. b) If the LED doesn't change from slow to fast blinking within about 15 seconds, then the Integrated Transmitter isn't 'hearing' the hand-held. Try altering the distance and orientation of the hand-held and try again. Try holding the Hand-Held forward (towards the front of the car) of the Integrated Transmitter. 6) For those opening systems that use an alternating-code, an extra step is needed. If you followed the above directions, got the rapid LED flash, but it doesn't open your door, you probably need to do this step next. a) Locate the "LEARN" button on your Opener. This is usually a colored button on the actual door opener machine, usually next to the controls that let you fine-tune where the door actually stops, open and closed. You may need a step ladder or stool to find this button. b) Park the car within range of your garage door, (max 2-3 car lengths). You do not want to park the car so it blocks you from being able to reach the LEARN button, and you don't want to park the car where it would be hit by the garage door closing. c) Press the LEARN button, and before 15 seconds passes, get into your car (or have a helper) push the chosen Integrated Transmitter button. (I don't' think the LED blinks or anything). d) The garage should start to close. The universal is now programmed. e) Test the Integrated Transmitter button by holding it down for about 1 second, and the door should start to open or close. 5) Repeat steps 2 through 5, (through 6 if you have a rolling-code system) for the other two Integrated Transmitter buttons to program them for up to two other remote systems. (I put this together as it took me a while to figure it out the first time, and I expect that I'll have to move again - and probably enough in the future that I'd otherwise forget the steps above, so I wrote it down).
-=] 2008 335i e92 Montego Blue & Black; Prem; Sport; AT-paddles
-=] Mods= VEI Digital Boost Gauge in RiXeffects custom Pod -=] Tinted (front: 3M Crystalline 70); (rear: Johnson InsulatIR 40 ceramic); 3M ClearBra |
10-17-2008, 01:50 AM | #10 |
LURKER
Rep 131
WOW, thanks for the write up! I am going to give it a try one more time this weekend as I've tried numerous times before, and I couldn't get it to work.
10-17-2008, 07:48 AM | #11 |
448
Rep 2,032
Drives: Red Flyer
I'm kind of pissed off. I'm 99% sure that my apartment complex's gates are rolling code and it would be way to complicated to go down to the front office and explain to those idiots why I need them to open up the gate box so I can press the learn button. So I just say f-it and use the little remote.
04-28-2009, 01:27 PM | #12 |
Rep 32
I'm having a problem with the garage unit learning my bmw signal.
The homelink unit seems to recognize the garage door opener signal fine. When I go and press the learn button on the garage door, the led on the garage unit slowly blinks like normal. I go to the car to send the signal and I press/release several times about one second on and 1 second off. The garage door led stops blinking. However, the door doesn't open/close -- But, the led on the garage does blink rapidly when I press the homelink button. What gives!! Please help!! I've read many threads from searching and I don't know why it wont work. Also on a site note, I reset the garage door unit, reprogrammed the original remote control fine -- so the garage learning a unit shouldn't be a problem. |
04-28-2009, 01:40 PM | #13 |
62
Rep 1,736
Drives: '09 E92 335i
I can't remember exactly how I did it, but my rolling code garage door does work with the Homelink. I think I had to park the car right underneath the opener motor and stand up through the sun roof to press everything in sequence. One thing to remember, though, is that after everything is set up correctly, you still have to press and hold the homelink button to open your garage. A quick press alone often won't work.
| 6MT | ZSP | ZPP | |
04-28-2009, 02:32 PM | #14 |
Rep 32
I forgot to mention that I've tried that too. I know for a fact that the garage door opener requires a learn click and a confirm click from the unit that is being "learned".
I've tried doing the learn step slow and fast. |
04-28-2009, 03:14 PM | #15 |
56
Rep 1,232
Goto www.homelink.com instructions and opener info is there and it works like a charm, It's easier to understand than the manual with instructions per your opener etc..
04-28-2009, 04:13 PM | #16 | |
Rep 32
04-29-2009, 09:33 AM | #17 |
Rep 32
Fixed! The problem was fixed by having the homelink learn the small button on the remote -- not the big one.
Correct me if I'm wrong but I have NEVER seen that in any instructions! |
05-09-2009, 05:59 PM | #18 | |
Rep 248
Drives: 2013 E92 MW M3
1. Pressed Learn button on main opener 2. Then held the remote button and integrated transmitter on the car together until it learned the code then... 3. Re-pressed the Learn button on the main opener to commit. Everything worked after that. Let me just add that when I pressed the Learn button on the main opener, the light on the main unit blinked steadily. Once the code was transmitted, the light was solid just prior to my pressing the Learn button the second time to commit. Obviously, this may vary on different brands. |
05-09-2009, 11:28 PM | #20 |
11
Rep 149
I found it easiest to learn the remote on the car, then the opener to the car. Something the book wasn't all to clear on but my SA clued me in.
The other thing that drove me nuts was to place the opener FORWARD of the rearview mirror, almost to the glass. Just clicking in front, from the seat did not allow it to learn. After that was done, it was just press the purple button on the opener itself and then homelink. Presto. The distance on the homelink is much less than a normal opener IMO. which can be annoying at times.
05-10-2009, 12:20 AM | #22 |
30
Rep 1,451
I never figured out how to set my garage opener either. I just stuck with the standard remote... no biggy imo.
Giggity, Giggity Goo! |
