08-01-2019, 07:46 PM | #1 |
14
Rep 63
I need some help with troubleshooting my car. I just finished installing the pure stage 2 turbo, 3.5 bar and the XDI-35 fuel pump.
I took the car to the drag strip and it was great. When I drove it home it started to idle rough. I let it cool down over night and did a log this morning. Still really rough. I have new plugs on order but have not arrived yet. Can someone help me review these logs? Car: 2014 N55 435i F33 EWG Map 93 stage 2 3rd gear pull. http://www.bootmod3.net/log?id=5d46285bc090c66f5cf2a032 Thanks for the help. Steve
Current Mods
2014 F33 435I // Intercooler//Pure Turbo Inlet // DV+//Charge Pipe//Boost Pipe//Downpipe//BM3 Custom Tune//Pure Stage 2 turbo//XDI-35//PR Black Coils//LSD |
08-01-2019, 07:58 PM | #2 |
Gettin It Figured Out
1820
Rep 2,669
need a log in 4th gear @ 2500rpm to redline (or at least close to redline)
08-01-2019, 08:05 PM | #3 |
14
Rep 63
I was going to do that but it is sounding really bad. I have logs from the drag strip.
Here is one of them: http://www.bootmod3.net/log?id=5d423eb6c090c6613bea8683
Current Mods
08-01-2019, 08:09 PM | #4 | |
1820
Rep 2,669
Miles since last plug change? Verify your charge pipe is still seated and/or intact...also verify your coils are all seated .
08-01-2019, 08:16 PM | #5 | ||
14
Rep 63
Plugs have 20k on them. New ones will be here on Tuesday.
Current Mods
08-01-2019, 08:19 PM | #6 | |
1820
Rep 2,669
Once you install new plugs...consider re-gapping .
08-02-2019, 07:24 AM | #7 |
1106
Rep 1,499
No trouble codes?
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
08-02-2019, 07:29 AM | #8 |
14
Rep 63
This is what I now have this morning.
I check and the pipes are all on. So nothing came loose.
Current Mods
08-02-2019, 07:58 AM | #9 |
14
Rep 63
I just flashed it back to just the stage 2 93 octane. Seams to idle better so I am going to go do a 4th gear pull later today.
Current Mods
08-02-2019, 03:16 PM | #10 | |
14
Rep 63
Current Mods
08-03-2019, 09:21 AM | #11 |
14
Rep 63
Can someone review this 3 gear pull. Could not do a 4th hear because of traffic but just looking for something not reading correctly.
It sounds like it is going to die when i idle. The whole car shakes. I just updated the turbo, XDI and tmap 3.5. I did order new plugs but won't be here for a few days. http://www.bootmod3.net/log?id=5d46285bc090c66f5cf2a032
Current Mods
08-03-2019, 04:14 PM | #12 |
14
Rep 63
I pulled the first 4 plugs to see how bad they were.
Current Mods
08-03-2019, 04:45 PM | #13 |
1820
Rep 2,669
Look great...what are they gapped at?
08-03-2019, 05:00 PM | #14 |
14
Rep 63
Right around .028
Current Mods
08-03-2019, 06:03 PM | #15 |
1820
Rep 2,669
doubtful that's the root of the issue...however, I'd consider closer to .20 - .22 I'd send log to PTF to rule out XDI and tune .
08-03-2019, 06:06 PM | #16 |
14
Rep 63
I will see what they say. Thank you for your help.
Current Mods
08-03-2019, 11:17 PM | #17 |
42
Rep 107
Don’t change the gap on Bosch platinum plugs. They deteriorate and can break apart in the cylinder. If you want to run a smaller gap switch to NGK plugs.
2014 F33 435i M Sport N55 EWG - MHD - Wagner HFC - VRSF 6" Race FMIC, CP & TIC - GFB DV+ - FuelIT Stage 3 525 - EOS PI - Turner Strut Brace - Bilstein B14 - M-LSD - Turner Aluminum Subframe Mounts - PowerFlex Adjustable LCA & TS Bushings - H&R Sway Bars - Dorch Stage 1 HPFP
08-03-2019, 11:18 PM | #18 |
14
Rep 63
They are on order and will have them on Tuesday.
Current Mods
08-03-2019, 11:26 PM | #19 |
42
Rep 107
Do you have a way to enable actual HPFP psi? I’m not a bm3 guy so forgive me if I’m missing something, but your throttle is barely opening during your second log. Normally this is due to fuel rail pressure issues.
Do you have an upgraded lpfp?
08-03-2019, 11:34 PM | #20 | |
14
Rep 63
I check all the Connections from the turbo to the intake. Everything is solid. I went back to the normal map and still did not help. Thinking about going back to the old tmap sensor to see if that changes anything.
Current Mods
08-04-2019, 12:25 AM | #21 | |
42
Rep 107
08-04-2019, 05:43 AM | #22 | ||
14
Rep 63
Current Mods
