08-01-2019, 07:39 PM | #1 |
Rep 9
Drives: '13 328i
iDrive Constantly Rebooting
I have a 2013 F30 328i non-nav, non enhanced audio that I am having issues with. I have searched and not been able to find an answer for my problem. The other weekend my screen started turning off every 3 minutes or so and my music would turn off also. This is constantly happening everyday and I have tried disconnecting the battery and letting the car sit and that did not help. My phone will not pair with the car anymore either. I am really hoping that I do not have to replace the whole iDrive system as I am sure that is not a cheap fix. Anyone else ever deal with this before?
08-01-2019, 09:36 PM | #2 |
879
Rep 1,689
Drives: 2014 428i and 2018 X5
You'll need a new head unit.
___________________ 2014 F32 428i M-Sport 2018 F15 M-Sport |
08-03-2019, 03:55 PM | #4 |
2466
Rep 5,457
Drives: F30
This exact thing was happening to mine. I updated the firmware and it hasn't happened since.
Do not throw a new head unit at your car until you've exhausted other options. Thats just bad advice... and ignorant. |
08-03-2019, 05:16 PM | #5 |
879
Rep 1,689
That hurts my feelings 😢
08-05-2019, 10:43 PM | #6 |
Rep 9
Drives: '13 328i
How can I update my firmware? I downloaded the update from BMW but it says my version on my car is current.
08-10-2019, 03:21 PM | #7 |
34
Rep 92
Update IDrive
As per the above suggestion in relation updating firmware, that is the correct way. A flash using Esys and latest PSDZdata should do it. I have had many of these issues brought to me and managed to sort them all with a flash of the headunit to the latest version
Vehicle Diagnostics and Coding ISTA ESYS CarPlay Activation Sat Nav Map Updates SLI FSC |
sspade2466.00 |
08-10-2019, 05:44 PM | #8 |
Rep 9
Drives: '13 328i
I assume that would be a dealership only thing then?
08-11-2019, 02:39 AM | #9 |
34
Rep 92
No, if you have the right software and ENET cable you can do this yourself.
08-11-2019, 10:06 PM | #10 |
Rep 9
Drives: '13 328i
08-12-2019, 02:09 AM | #11 |
34
Rep 92
You could use another vehicle that's running via jump cables if you don't have an actual PSU
08-12-2019, 04:00 AM | #12 |
Rep 3
Sadly mine started doing the same thing after I plugged in my iPhoneXR to the media USB for charging and now it reboots every -minute. Anyone around the Coventry - Warwick area who could fix this.
Or maybe M3nt4l you could help me out on this. |
08-12-2019, 04:09 AM | #13 | |
34
Rep 92
Have you tried downloading the latest software update from BMW website: https://www.bmw.com/en/footer/software-updates.html Try that (you might not be able to complete it due to the reboot but worth a try) If not get back in touch, I'm only based in Derby
08-12-2019, 05:27 AM | #15 |
34
Rep 92
Okay, since you have the .bin file just stick that on a fat32 formatted USB and put it into the USB slot in the car. Navigate to "software update" in the idrive and start it. Like I said with the reboot issue you might not be able to get that far within the given time but it's worth a shot.
08-12-2019, 07:37 AM | #17 | |
34
Rep 92
Follow that and choose just HU(headunit) to flash
