M2 Technical Topics > S55 Engine / Drivetrain / Exhaust / Bolt-ons / Tuning > How-to: Find out your ISTEP version (guide)
      07-31-2019, 01:28 AM   #1
Dav3
Dav3's Avatar
949
Drives: G87 M2/E89 35is/F21 M140i/GT4
1. Get yourself a USB (formatted to either FAT32/EXFAT) and plug it into the usb port under the armrest
2. Navigate to "My Vehicle" and select your profile
3. Select the Export to USB option.
4. Pull out the USB and insert it into a Windows Machine (Might work on Mac, just need a text editor)
5. Now navigate to the .mpd file, right-click on it, select "More options" and open the file with "Notepad".
6. The highlighted area on the text below is your Istep version.
I cross referenced my ISTEP Code on other forums and apparently it's a late 2018 version so my DME should not be locked right now. (Promising news!)
For reference, code should be read like this: F020 Platform Code - YEAR - MONTH - UNKNOWN
As a baseline:
- Version: F020-18-07-547 = July 2018 - DME Confirmed Unlocked
- Version: F020-18-11-531 = November 2018 - DME (Presumably unlocked)
- Version: F020-19-03-546 = March 2019 - DME Confirmed Locked (First software version that locks obd flash tune, anything above is assumed to be locked too for the time being 26/09/2019)
- Version: F020-19-07-539 = July 2019 - DME Confirmed Locked
UPDATE June 2021 Apparently, updated ISTEP version DOES NOT ALWAYS exclude OBD Flash possibility. Flashing lock actually depends on the bootloader version. If you contact BootMod3 and have an ENET cable, they can tell you if its possible or not. Source: Just flashed my F80 M3 with latest ISTEP. However, this should not apply for 2020+ Cars with new DME although Gx DME's have been cracked as of late
x
Appreciate 14
VIERsr2621.50
Altra265.50
ChrisK4449.00
Lotus99628.00
Poochie9104.50
gnx759.50
prompt292.00
iiNNeX18.50
m20e30871150.00
      07-31-2019, 01:35 AM   #2
doughboy
doughboy's Avatar
1545
Drives: 2018 M2 Comp 6MT
Nice DIY.
      07-31-2019, 03:35 AM   #3
VIERsr
Switzerland
2622
Drives: BMW M2
Mine is F020-19-03-546 (june build)
It seems that the updated version was released in March 2019
      07-31-2019, 05:05 AM   #4
Dav3
Dav3's Avatar
949
Format: F020 Platform Code - YEAR - MONTH - UNKNOWN (edit)
By June, do you mean June 2019?
By the way, your VIN is exposed on this sheet (right above istat version), suggest hiding it for privacy reasons
      07-31-2019, 05:15 AM   #5
Dav3
Dav3's Avatar
949
Originally Posted by doughboy View Post
Nice DIY.
Cheers!
Iirc you have BM3 flashed on your M2C, would it be too much to ask for your istep version?
If yours matches mine, we pretty much figured out which specific Istep update breaks obd flashing
Lots of first batch cars sitting on dealer lots and orders in between where chance of update being applied is 50/50
I'm still rocking last years update even after break-in and an additional recall maintenance visit, others might be in luck too
      07-31-2019, 05:19 AM   #6
VIERsr
Switzerland
2622
Drives: BMW M2
Originally Posted by Dav3 View Post
My best guess is:
20 = Car Year (BMW labels current year cars as next year)
19 = Day
03 = Month
546 = Car Model?
Done
      07-31-2019, 08:09 AM   #7
Arrow29
95
Drives: M2 comp, X5 M50i ordered
My m2c is a February 2019 build.
istep as per this method is: F020-18-11-551
      07-31-2019, 03:37 PM   #8
doughboy
doughboy's Avatar
1545
My best guess is:
19 = Day
03 = Month
546 = Car Model?
Not quite...
F020 is the platform code, F020 encompasses all F2x 2 series cars on which F87 is based. F020 model code is also used in Esys coding and ISTA diagnostic's.
19 is the year
03 is the month (march)
546 is just some sort of revision / variant code
Dav3948.50
      07-31-2019, 04:16 PM   #9
chmura
chmura's Avatar
1558
Drives: 2019 M2 Competition
No need to check mine since I picked up my M2c last year in October 2018 via ED. I know I have the old version.
      07-31-2019, 06:26 PM   #10
BlkSVT
389
Drives: 2019 M2c BSM, 2020 MB GLC63
Thanks for the write-up!
I wonder if the last 3 are Region code of some sort?
I just ran out to check and my October 2018 build US-spec M2c is
F020-18-11-520
I've been planning to go BM3, but have been reluctant to check version since I had the break-in service done in late April. I didn't want to face reality of possible lock-out. But now? Whoop! buying that sh*t tonight
      07-31-2019, 07:26 PM   #11
AlpsRider
AlpsRider's Avatar
2865
Drives: M2 Competition, LBB, 6MT
The ISTEP version on my car is:
F020-18-07-530
That is the oldest one so far.
      08-01-2019, 07:39 AM   #12
ChrisK
ChrisK's Avatar
4449
Drives: '19 M2C
Build date: 2018-07-31
F020-18-07-530
I'm sure when I go in for my annual oil change they will upgrade the software.
www.ReTuneTheDeTune.com
2019 M2 Competition (Sunset Orange)
      08-01-2019, 11:18 AM   #13
AlpsRider
AlpsRider's Avatar
2865
F020-18-07-530
That is the same version that my car has. I think that may be the first M2C istep version for US cars.
I don't think they'll update cars just for the fun of it. They didn't update mine. I had my 10k mile service last week.l asked the SA if they do routine updates. He said that they never do an update unless BMW requires it, otherwise they charge you for the update. I checked the ISTEP version on my car after the service. It is exactly the same as before I took it in.
      08-01-2019, 11:42 AM   #14
ChrisK
ChrisK's Avatar
4449
Drives: '19 M2C
They never update ISTEP unless there is a recall, related issue, or you pay. However, I thought there was a TSB and the software needed to be updated.
Maybe what I read was for the EU market.
      08-01-2019, 11:45 AM   #15
AlpsRider
AlpsRider's Avatar
2865
I don't know about a TSB. The SA checked the computer and my car was listed as up to date, no updates required.
      08-01-2019, 11:47 AM   #16
ChrisK
ChrisK's Avatar
4449
Drives: '19 M2C
I don't see any TSB's open. Who knows what the heck I read
      08-01-2019, 11:54 AM   #17
AlpsRider
AlpsRider's Avatar
2865
I don't see any TSB's open. Who know what the heck I read
Now that I'm confident that BM3 will install, I'm tempted to try out the CS tune. It seems like a no brainer. I would rather have the official M2CS tune though since it will also come with a MT. I'm not sure if a tune is tailored to MT specifically or not.
Dav3948.50
      08-01-2019, 12:16 PM   #18
ChrisK
ChrisK's Avatar
4449
Drives: '19 M2C
I really excited about a CS Tune.
      08-01-2019, 07:12 PM   #19
Arrow29
95
I think that was in the EU related to the OPF. I remember reading something similar on a different thread.
I had my run in service in Australia and they didn't update
      08-01-2019, 11:39 PM   #20
Lotus99
Lotus99's Avatar
628
Drives: 19 M2C & 18 X3 M40i
Ah man... I had to go in last month for CarPlay issues and odd noises coming from the driver's tweeter, so they suspected the stereo headunit software was to blame. They said they updated the software to see if it would fix it... It happened to be the one year service date too.
Was hoping it was just a module they updated, but I just downloaded my profile and though my car's a July 2018 build, it says my ISTEP is:
F020-19-07-520
Which takes the cake as far as the latest version out there it looks like, according to OP. And I'm probably screwed should I decide to do anything...
      08-05-2019, 08:45 PM   #21
mshea397
Drives: 2015 M4 (sold), 2020 M2C
2015 BMW M4  [0.00]
my istep is F020-19-03-522. Will BM3 work?
      08-05-2019, 08:56 PM   #22
Arrow29
95
Very unlikely unfortunately, if as we assume the 19-03 refers to March 2019 (which is when the changes took place). At least unlikely to work with obd flashing.
m2
