F30POST
F30POST
BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > LPFP issue
ARMA SPEED
      07-22-2019, 05:54 PM   #1
MineralF30
61
Drives: 09 E92 335i
LPFP issue
My car died on me for the second time in two weeks due to loss of fuel pressure in the tank. The first time it happened my gauge was reading a little under half tank, about 140 miles left. I had a drivetrain malf. pop up on the dash and the car died on me, and I opened the tank up and it was bone dry inside.
I filled it up with a gallon of gas and drove to the station and filled the tank all the way up but it stopped at 9 gallons..
Does anyone have any advise cause I don't know what's going on with this?
      09-08-2019, 10:01 AM   #2
MineralF30
61
Drives: 09 E92 335i
Bump. Recently dropped my gas tank and replaced it with a different one and also swapped out buckets to replace the fuel regulator and it still didn't work.
Any advice??
      09-08-2019, 11:30 AM   #3
ronanz
Gettin It Figured Out
ronanz's Avatar
1820
Drives: 435i FBO PS2 bm3 w/ options
Have you verified fuse (#165?) is still good?
My Build Thread can be found HERE
      09-08-2019, 12:35 PM   #4
MineralF30
61
Drives: 09 E92 335i
What fuse is that? Fuel pump?
      09-08-2019, 12:42 PM   #5
ronanz
ronanz's Avatar
1820
Possibly, yes....not 100% certain as LPFP does not have its own icon. Just a logical guess as it's always been under the fuel icon with higher amperage...but, I'd certainly start there..
      09-08-2019, 12:45 PM   #6
MineralF30
61
Drives: 09 E92 335i
I just checked it along with all of the other fuses that go with the fuel icon and they all checked out good, except for fuse #150. I don't have a fuse there but that could be a normal thing for N55's.
      09-10-2019, 08:40 AM   #7
zole2112
Modder of everything I own
zole2112's Avatar
147
Drives: 2013 335i Xdrive
I was getting some really weird shit going on with my fuel tank level when my HPFP failed, I didn't think it was related though. I got the following codes:
193208 (multiple times) tank level, plausibility: deviation between consumption and level change
11A002 (2 times) Fuel Pressure below target
1193001 (11 times) fuel level sensor, left, signal:short circuit to positive
110001 cylinder injection shutdown: too low pressure in the high pressure system
When I pulled the LPFP the tank was so full it overflowed, I never had that happen before and I've pulled my LPFP at least 6 times before. Not sure if it's in any way at all. I checked my fuse and it was good. In the end I changed my HPFP due to the various issues and finally the 110001 code pointing to the HPFP. I also changed my level float/sensor on my LPFP but I don't know if that had any effect or not. I haven't had any related codes since.
The only fuel level issue I have is that when the low level light comes on the miles remaining will drop a lot faster than seems realistic.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
      09-10-2019, 08:46 AM   #8
MineralF30
61
Drives: 09 E92 335i
I've gotten hpfp codes also for the pressure being too low but I always figured it was due to the low pressure side. I do have port injection too so maybe since that is spraying a lot it is sorta masking the signs of the hpfp dying.
That might be what I'll have to change next. That along with the fuel lines going from the hpfp to tank are the only things I haven't changed yet.
      09-12-2019, 12:36 PM   #9
zole2112
zole2112's Avatar
147
Yeah, during this process it first died going about 25 mph in town. I then first changed my Stage 2 LPFP and put my stock LPFP back in and it actually ran fine for about 12 hours so I thought that was it. Then it died again on the highway with the code 110001 cylinder injection shutdown: too low pressure in the high pressure system, then I figured it must be the HPFP, which it was.
      09-12-2019, 12:44 PM   #10
MineralF30
61
Drives: 09 E92 335i
Yeah, during this process it died going about 25 mph in town. I then first changed my Stage 2 LPFP and put my stock LPFP back in and it actually ran fine for about 12 hours so I thought that was it. Then it died again on the highway with the code 110001 cylinder injection shutdown: too low pressure in the high pressure system, then I figured it must be the HPFP, which it was.
Interesting, I'll have to look back at my code history but I'm sure I've gotten that code before.
I'll update the thread in the next day or two after I change it and see what it does.
      09-13-2019, 11:26 AM   #11
zole2112
zole2112's Avatar
147
Sounds good! Good luck!!
      09-14-2019, 12:01 PM   #12
MineralF30
61
Drives: 09 E92 335i
Update: I changed the HPFP but it didn't fix the issue, it still died when the tank got past half. However, now i keep getting active O2 sensor codes so I'm going to replace those along with the LPFP with a Walbro 525 and see if that does anything...
      09-14-2019, 12:51 PM   #13
Munchi435i
Munchi435i's Avatar
485
Drives: 2014 Alpine White 435i M-sport
I'd say to replace the O2 sensor first before upgrading the lpfp
      09-14-2019, 01:08 PM   #14
MineralF30
61
Drives: 09 E92 335i
That's the plan, I have to wait for it to ship though so I won't have it for about a week.
The main problem is that my fuel isn't transferring from the left side of my tank so that's why I'm trying the lpfp first. I don't think it'll fix it but it's worth a shot.
      09-15-2019, 12:59 PM   #15
MineralF30
61
Drives: 09 E92 335i
Problem is fixed! Installed a new lpfp and that solved the problem
      03-22-2021, 10:58 PM   #16
Ajax915
Ajax915's Avatar
53
Drives: 320i BMW
What were the fault codes?
f30post
