07-22-2019, 12:16 AM | #1 |
Rep 5
I'm new to engine modification and want to chip my 2014 F30/nN0
Hello all, looking for some help.
Just bought a used 2014 328I w/ MSport Package.. I love it so far, as this is my first BMW, but now I'm hungry to squeeze more power out of the engine. I'm new to modifications and tuning in general, but am told a Stage 1 chip is probably the first thing I should do. I've been hearing a lot about racechip: https://www.racechip.us/shop/bmw/3-s...-255lb-ft.html Thought? Thanks! |
07-22-2019, 01:22 AM | #2 |
3082
Rep 4,333
although "racechip" has the word chip in it, the current terminology is "tune", "piggy-back tune", "flash" or "flash tune".
piggy-backs such as race-chip, jb4, active autowerke active-8 are wired to work with the factory ECU and intercept the signal from the sensors before the factory ECU and modify those signals so the stock ECU is “tricked” into making the vehicle behave the way you want. piggy-backs have fallen way to flash tuning. Flash tuning is where the DME(computer) that controls the engine can be effectively re-programmed, fuel maps, ignition timing, code elimination. etc. Flashes such as Bootmod3 and MHD are the two most popular and the recommended way to increase performance. other bolt-ons you'll want to add: aftermarket intercooler(FMIC) catless or high flow catted downpipe(for California?) charge pipes, diverter valve, turbo inlet pipe exhaust intake last |
rjd_F301999.50 CandyRedRC46242.00 |
07-22-2019, 02:32 AM | #3 |
Rep 5
This helps thanks! So just to be clear, should I upgrade charge pipe, inlet pipe, diverter valve, etc. before I perform the stage 1 flash tune? Or is the hardware only needed for stage 2 and above?
07-22-2019, 03:54 AM | #4 | |
2000
Rep 3,680
You don't need to change any hardware for stage 1, but you'll need an FMIC and downpipe for stage 2. Everything else is just supplemental.
Instagram: rjd_f30 | Current: EBII 2013 335i 6MT RWD & Sprint Blue 2008 Audi RS4 | Retired: 2013 328i, 2000 XTerra, 2022 Civic Si |
07-22-2019, 08:07 AM | #5 |
¯\_(ツ)_/¯
945
Rep 1,762
Change your charge pipes (at least the intercooler to intake) and do a bootmod3 stage 1 flash
Tensioner/belt DIY | Side skirt extension DIY
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC |
07-22-2019, 08:12 AM | #6 |
156
Rep 461
I would recommend Bootmod3.
HS S55 F87
MG B58 F30 - Gone MG N20 F30 - Gone |
07-22-2019, 06:56 PM | #9 |
2000
Rep 3,680
Extreme Powerhouse will have everything you need.
07-23-2019, 06:06 PM | #10 | |
¯\_(ツ)_/¯
945
Rep 1,762
07-25-2019, 11:28 AM | #11 | |
BimmerPost Supporting Vendor
24199
Rep 190,807
BeerHerder250.50 |
