Can I Cut This?
07-21-2019, 10:37 PM | #1 |
27
Rep 72
Can I Cut This?
Heyo, so I was going to put my car on jack stands at each corner but when I went to jack from the rear cross member I noticed that this metal rod was directly under the middle of the cross member blocking the jack. It looks like it's just a brace between each of the exhaust pipes, and the pipes are supported within a foot up and downstream of the brace.
Can I just cut this rod out of the way or will my exhaust pipes rattle around really badly if I do that? Car is an N55 if that makes any difference. Thanks!
2011 E90 335i xDrive: MHD S1 Plus, XHP S2, VRSF 7in. FMIC and CP
2004 Jeep Grand Cherokee: 4.0L I6, 2in. lift |
07-22-2019, 02:26 PM | #3 | |
2697
Rep 4,031
What I can say is that BMW has NOT done a good job of describing WHERE to jack at the center rear. The TIS procedure below suggests that the Trolley Jack should NOT be placed under the Rear Cover of the Differential, and SEEMS to ME to suggest that it also should NOT be placed under that subframe cross-member above the Rod you are concerned with. NOTE the X at that point which appears to me to show the subframe member rather than the Rear Cover of the Differential. https://www.newtis.info/tisv2/a/en/e...-guide/I2a5leg Regardless of one's interpretation of the TIS Procedure, it DOES clearly show an arrow indicating a permissible jacking point under the Differential below the Output Shafts (as HassMasch suggests ;-) I notice you have the front wheels on ramps. If you are looking to get the vehicle level to change Transmission or Transfer Case fluid, you can simply jack each rear wheel at the Rear-Side body jacking points, and place 2nd pair of jack stands or pedestals under rear wheels. I have done that, for that purpose, and NOT jacked under the differential. You may find it easier to do it in two stages, putting 3" pedestal (two pieces of 2"x10") under one rear wheel, then jacking other side to full 6" and placing pedestal on that side; followed by rejacking first Rear-side and placing 6" pedestal there. You now have level & elevated vehicle that will be stable with motor running (which you need for Transmission Fluid Level check). George |
07-22-2019, 03:01 PM | #4 |
Is it the shoes!?
3884
Rep 5,112
Bimmer_Engineer1043.50 Efthreeoh17309.00 |
07-22-2019, 03:42 PM | #6 | |
2697
Rep 4,031
My questions are: 1) Does the "X" under the rear cover (or subframe) suggest that there is a problem with jacking by the subframe BEHIND the Differential Rear Cover? 2) Is there any reason NOT to jack by that rear subframe behind the Differential Rear Cover (OTHER than the fact OP's vehicle has a Rod in the way)? I have heard differing opinions on that in threads here in the last year, WITHOUT any support for the opinion. Just asking, George |
07-22-2019, 03:49 PM | #7 | |
2657
Rep 6,290
As to why not to lift by subframe brace I don't know. If it's really a subframe piece I would suppose it's safe but idk. |
07-22-2019, 04:36 PM | #8 | |
17309
Rep 18,733
Car ramps on the other hand frighten me. NFW I'd get under a car on ramps. |
07-22-2019, 05:42 PM | #9 | |
2697
Rep 4,031
Seems like there are several basic considerations for jacking at or near the Differential: 1) Don't let anything slip so that Driveshaft/ Pinion Bearing area is damaged, or Output Shaft/ Drive Axle Area is Damaged, or YOU are terminally damaged; 2) Don't apply compressive forces to the Differential in such a way that the case or Rear Cover, or their sealing areas are cracked or bent. 3) Don't bend/displace anything in the subframe that holds the differential, which might affect alignment, vibration, noise, etc. RAMPS: As to my concept of getting under a car supported by jackstands vs. supported by ramps, my concept is the opposite of yours, so maybe you can offer some facts that I should consider to change that concept. I have used BOTH ramps and Jackstands for different projects over many years. I have NEVER felt unsafe under a vehicle on Ramps, or even under an XJ-6 with about 12" of lumber (six 2"x12" sections ~ 18" long stacked on top of each other) under each tire so I could extract/ install an "over-axle" rear muffler & joined pipe. My concept is that a car resting on ramps (whether the old-style steel ramps or current plastic ramps like Rhino or Magnum 16000) is actually MORE stable, particularly with motor running as required for Auto Tranny Fluid Fill, than if supported by Jack Stands. The XJ-S V-12 was designed and built BEFORE COP Ignition and had the old Centrifugal and Vacuum advance system in a distributor for which timing was adjusted by rotating the distributor body. The timing specification for that engine is 18 Degrees BTDC with vacuum hose removed (NO vacuum advance) at 3,000 RPM). The timing marks are UNDER the Crankshaft Pulley. So you put the front wheels on ramps, set the HANDBRAKE to THREE GRUNTS, assure yourself this is NOT a 1980 Audi that killed xx people with transmission shifting OUT of Park on its own, check to make sure your life insurance is in effect, clamp the throttle at 3,000 RPM and crawl under to have a look while the engine roars away above you. It's been nearly 20 years since I last did that, but suffice it to say, that gives you respect for thinking about all the "what-ifs" and taking all due precautions. So if you have had any "untoward events" with ramps, or know of anyone who did, please enlighten me. I can't "bench" two tons. George |
Efthreeoh17309.00 |
07-22-2019, 06:11 PM | #10 |
27
Rep 72
After looking other threads about jacking the rear up I realize what a can I've worms I've opened, my apologies everyone haha.
07-22-2019, 08:26 PM | #11 | |
17309
Rep 18,733
The younger brother now uses a 2-post lift to work on cars. When cars are on their wheels, they can roll off ramps or (just 2) jackstands. When the car is properly lifted on 4 stands with wheels off the ground, the vehicle can not roll. Show me anyone, except The Rhino, Spiderman's arch enemy, who can knock a car off 4 jackstands turning a wrench on it. When one of my cars is on my lift, set on the locks, I'd sleep under it an not lose a wink. Detail of Bethesda added so you can google.
07-22-2019, 08:33 PM | #12 | |
2657
Rep 6,290
07-22-2019, 09:03 PM | #13 | |
2697
Rep 4,031
George |
07-22-2019, 10:58 PM | #14 |
1209
Rep 2,476
Just because some dude was careless back in 1972 and didn't take some, really simple, mind you, precautions, is no reason to write them(ramps) off.
You might as well write life off, in that case. I've been using the plastic ones since I bought my Suburban in 2010. That thing weighs roughly 1800lbs MORE than my E92 335i. I've never once felt unsafe while using them. |
07-23-2019, 12:28 AM | #15 |
3973
Rep 7,215
How about this - I swapped the entire drivetrain out of my E30 using jackstands *and* ramps - and it was on gravel!
Thankfully, my days of crawling around on my back in the dirt and rocks are long past. |
07-23-2019, 08:28 PM | #16 |
17309
Rep 18,733
Well, my fastball isn't what it used to be...
07-23-2019, 08:59 PM | #17 |
2697
Rep 4,031
07-24-2019, 05:08 AM | #18 |
17309
Rep 18,733
Tell me about it.
07-24-2019, 05:14 AM | #19 | |
17309
Rep 18,733
Just sayin'
07-24-2019, 05:24 AM | #20 | |
17309
Rep 18,733
And sure, I can go find and post pics of cars that have fallen off a car lift too. You can't out engineer dumbass, but you can engineer in safety. An E90 sitting on top of 4 flat-top jack stands with the wheels off the ground is safer than an E90 on ramps.
07-24-2019, 05:35 AM | #21 |
17309
Rep 18,733
Amen on that! Pulled the 2L out of my Pinto one sub-freezing January day on a gravel driveway. Maybe that's why the shop has a 100,000 BTU furnace hanging from the ceiling...
07-24-2019, 11:07 AM | #22 |
27
Rep 72
Totally fair. I just didn't realize it was such a dumb question
