07-20-2019, 01:53 PM | #1 |
967
Rep 2,655
After changing my oil filter housing and cooler gaskets I decided to give my engine bay a good degreasing due to oil and coolant getting on the belts, I discovered my coolant overflow line didn't look too good. I gave it a little shake and the whole thing disintegrated. Luckily my local BMW parts department had it in stock. Part is $40 and should be swapped when the gaskets are done.
2016 340i xDrive - BM3 Stage 2 93 OTS - xHP Transmission Tune Stage 2 - B58TU HPFP - Bilstein B14 - VRSF Catless DP - Kyostar CAI
07-20-2019, 02:01 PM | #2 |
242
Rep 765
mine snapped too while driving on the freeway. and there is a thread about this already, check it out. luckily its an easy fix
PSA for high mileage 335's, check your coolant hoses... https://f30.bimmerpost.com/forums/sh....php?t=1547622
MG F30 M-Sport 6mt FBO w/ MHD stage 2 plus (PWG), ST XA Coilovers, 19" VMR V804.
07-20-2019, 02:04 PM | #3 | |
967
Rep 2,655
07-22-2019, 07:54 AM | #5 |
Modder of everything I own
147
Rep 491
yeah, mine failed last summer and it looked deteriorated exactly like yours. I had about 75k on my car at the time so it's a good recommendation to inspect the overflow line ends.
2013 BMW 335xi F30 N55 PWG/VRSF DP/ER CP/Injen CAI/AA FMIC/JB4 map 7/Fuel= E50 w/ E85:93oct/Stock LPFP & HPFP/CATuned coilovers/Megan Racing Rear Swaybar/Powerflex Rear Subframe Bushing Inserts/Dual aFe Power Mach Force Mufflers/Resonator Delete/MHD & BMS Race BEF
07-22-2019, 12:19 PM | #7 |
202
Rep 533
07-22-2019, 05:20 PM | #8 |
481
Rep 1,572
I replaced mine as preventive maintenance when I installed my Chargepipe. I think the culprit is the amount of under-hood heat we experience with these turbo-charged engines. The plastic just takes a beating with all those heat cycles.
07-22-2019, 05:34 PM | #9 |
967
Rep 2,655
For sure. Heat cycles are no bueno for plastic parts.
