07-19-2019, 04:12 PM | #1 |
640
Rep 1,381
MHD blown something on my car?
Got a major problem on my hands.
I run MHD stage 2+ with a catless downpipe and an uprated charge pipe. Been running fine for about 2-3 months now, pulled up at traffic lights today and went to set off but found I had no power/car was hesitant, then it was perfectly fine. Filled up with fuel, parked up in my apartment (5 minutes after) and left the car parked up for about 2 hours. Decided I’d flash back from stage 2+ to stock for the time being as my fuel economy is awful. Set off from the underground car park at my apartment and bam! The drivetrain error came up, ran the codes and I’m getting the following: 120408 - Charging pressure control: Switch-off as consequence 121532 - Charging pressure sensor, plausibility: Pressure before throttle valve too high at engine standstill. The car has a really rough idle and sounds like it’s stalling at times, then it’ll slam the revs up to 2-3k rpm before dropping The exhaust also has a deep raspy sound to it which I feel like is coming from the back of the engine maybe?
2015 435i - 401whp
Scorpion catless dp, VRSF 6.5" HD FMIC, MST V2 inlet, NGK 97506, MHD Stage 2+ 102, xHP Stage 3, M Performance Exhaust (modified for valved straight thru) |
07-19-2019, 04:40 PM | #3 | |
640
Rep 1,381
I hate to be an idiot, but where am I best looking to find the waste gate actuator? I've also just found a shadow code too: 121521 - Charging pressure sensor, multiple fault: electrical and plausibility
2015 435i - 401whp
07-19-2019, 04:45 PM | #5 |
640
Rep 1,381
Will this be the same for the EWG's as mine is a European car
2015 435i - 401whp
07-19-2019, 04:48 PM | #6 |
52
Rep 202
Turbo design for stuff like this is rather pretty universal in general, but may be located in a different area. Then again I never had this issue, 2013 F30 328i xDrive n26 122,122 miles. No timing chain issues to speak of either
07-19-2019, 11:40 PM | #7 |
184
Rep 288
07-20-2019, 03:11 AM | #8 | |
640
Rep 1,381
I'm just mind blown that flashing from 2+ to stock has managed to do it
2015 435i - 401whp
07-20-2019, 05:43 AM | #9 |
640
Rep 1,381
Been for the codes reading and the turbo was massively overboosting.
Looks like some of these MHD maps are pretty whack 😩 They're convinced the wastegate isn't operating correctly and so it's choking the engine, thus turning off the module and leaving it stuck wide open in failsafe mode, hence the lack of power. They struggled to get the reader to recognise the car after that though, and I believe this is because the tune uploads MHD's own ecu software on, so I'm going to erase the map completely (not stock map) and see if this clears it
2015 435i - 401whp
07-20-2019, 07:05 AM | #10 |
640
Rep 1,381
Update:
Flashed the car to stock and removed all MHD ecu software Reset throttle and MAF adaptations and it's fine, the wastegate is now operational and no more codes. I'm still going back for a visual inspection as this has made me a bit unsure. In the meantime I'm awaiting MHD's response to their dodgy map
2015 435i - 401whp
07-21-2019, 11:32 AM | #11 | |
42
Rep 107
Personally I would guess that your issue will return, even with the stock tune. You might have a failing map or maf sensor. If the problem returns and a simple adaptations reset resolves the issue, I would lean towards failing map/maf sensors. Might be a good time to clean your maf and upgrade to a 3.5bar map sensor
2014 F33 435i M Sport N55 EWG - MHD - Wagner HFC - VRSF 6" Race FMIC, CP & TIC - GFB DV+ - FuelIT Stage 3 525 - EOS PI - Turner Strut Brace - Bilstein B14 - M-LSD - Turner Aluminum Subframe Mounts - PowerFlex Adjustable LCA & TS Bushings - H&R Sway Bars - Dorch Stage 1 HPFP
mbanks211267.50 |
07-21-2019, 08:55 PM | #12 |
1078
Rep 2,358
Does indeed sound like a sensor issue. Especially as it happens right when you startup the car and not putting load on it. Maybe even just a loose connection.
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
07-22-2019, 03:53 PM | #13 | ||
640
Rep 1,381
Just out of curiosity what are the stock sensors rated to? I thought the 3.5bar option was for N20's only? I have the N55 435i engine. If that's the case though that we can run it as an upgrade then for sure, I'll be doing this as a preventative measure. Quote:
The only thing I have noticed is that the car under low rpm's has the same lawn mower/m4 sound as it did when I had the codes, so I'm not too sure if something is yelling permeant damage: https://streamable.com/0sk5d
2015 435i - 401whp
07-22-2019, 05:12 PM | #14 | |
Gettin It Figured Out
1820
Rep 2,669
Although I’m biased towards bm3, to be fair....if you have ANY weakness within your PowerTrain and/or supportive hardware; regardless of tune, it WILL highlight the weakness and potentially expedite the failure. .
