07-18-2019, 04:20 PM | #1 |
44
Rep 83
Having a bit of a crisis — could use some advice
So I was planning on going fbo this summer because my factory warranty just went out until I took my car in for service and they said that I had extended warranty until May.
My options are: I can either forget they told me that and go full send anyway or I could wait until my extended warranty goes out for peace-of-mind's sake Does anyone have experience with being modded with a warranty? How does it work if I want something covered even if I have aftermarket parts? |
07-18-2019, 07:34 PM | #2 | |
Gettin It Figured Out
1820
Rep 2,669
Welllllllll.....being its mid July, I'd say fire away .
07-18-2019, 08:13 PM | #3 |
1078
Rep 2,358
I never understood the idea of modding AFTER your warranty expires. The likeliness of something going wrong with the stock car is small and if something should go wrong after you have modded it you might get away using the warranty
M135i 8AT PWG, MHD, Pure Stage2, WMI via Torqbyte CM5-LT, Custom tuned by PureBoost
(A Dane in China) |
6SpeedCrewCab44.00 MAKH 588.50 |
07-19-2019, 07:58 AM | #5 |
1106
Rep 1,499
I've been FBO + bm3 stage 2 tune for almost two years. My extended warranty as well as BMW Ultimate Care maintenance package doesn't end until this September. I've had all my routine maintenance done at the dealership, other than an additional oil change between dealership oil change intervals and more frequent spark plug changes. I've also had the oil filter housing gasket and oil pan gasket replaced under warranty. I'm cool with the SA so all has been good so far.
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI). SPI Films Blog/DIY Vids |
mcintoshf30184.00 |
07-19-2019, 04:16 PM | #6 | |
202
Rep 533
I bought brand new 2012 Mx5 and dropped 8k in upgrades the first year. Car was a beast!!!! Last edited by BigJack75; 07-19-2019 at 04:26 PM.. |
6SpeedCrewCab44.00 imperfectluck426.50 |
07-22-2019, 02:32 PM | #7 | |
44
Rep 83
07-24-2019, 10:13 AM | #8 |
Yoda of mods
1675
Rep 3,006
Drives: X5 RWD
You have the mod bug my friend, pull the trigger!
Current: 2020 Explorer ST (Agate Black Metallic), F15 SGM RWD
F87 AW (retired) F30 SBM 316rwhp/440rwtq (retired) Follow me on Twitter: https://twitter.com/EdwyerCLT YT: https://www.youtube.com/@DWYERGARAGE/videos |
07-24-2019, 11:17 AM | #9 |
197
Rep 417
You should do it man, first thing start with the charge pipe.
If you have over 50k miles on the engine, I will also look at OFHG, VCG, and intake valves. You want to make sure the engine is fundamentally healthy before modding; once you treat it good, it will return the favor when you mod. |
07-24-2019, 11:55 AM | #10 |
521
Rep 1,288
Drives: 2015 335i xdrive Msport Mbrake
My BMW dealership takes care of my car
07-24-2019, 11:57 AM | #11 | |
44
Rep 83
Even though I've had the car for a year, I'm still pretty new to the world of modifying and dyi maintenance for bmws. I recently got an oil leak fixed at the dealer (turned out to be VCG) but I'm not sure if they checked any other gaskets while they were at it. Where can I find guides to check on all that you stated and fix them if necessary? |
07-24-2019, 01:38 PM | #12 | |
197
Rep 417
As far as oil filter housing gasket, I think we can see it around the oil filter? I haven't experienced it myself but I am sure there are plenty of picture on Google since it is so common. For intake valves you will have to remove the intake manifold. You can get a general idea by looking up walnut blasting. One way to prevent/significantly reduce carbon build-up is oil catch can. You probably noticed some oil in the CP when you replaced it, those oil are basically where the build-up comes from. What is the emission rule like in Dallas? The reason why I ask is that my team is in Dallas and I will most likely have to move there when I finish grad school next year |
07-24-2019, 02:04 PM | #13 | |
44
Rep 83
As for emissions in dallas, It's not as lax as Florida but definitely not as strict as California. A lot of my friends have catless cars and you can easily pass emissions with a o2 spacer or if you just go to the right shop |
07-24-2019, 03:24 PM | #14 | |
197
Rep 417
Thank you for the input on the local emission, I will most likely take advantage of that on top of the cheaper gas price |
07-25-2019, 09:15 PM | #16 |
44
Rep 83
07-27-2019, 08:32 AM | #17 |
302
Rep 526
You can but if your engine blows up it doesnt matter, they will find it. Tip and be nice to your SA, they will most likely pretend they dont see your mods for basic warranty repairs such as OFHG and VCG which are the only 2 things id be worried about on the 335i. If your turbo or rods fail then it will most likely be on you. Turbo will cost around 4-5k with the labor. Engine 8-12k with labor.
07-27-2019, 07:01 PM | #18 | |
550
Rep 949
You can do a lot of stuff flashing but you just have to understand that once flashed there is really no going back from a detection perspective. |
07-28-2019, 06:28 AM | #19 | |
48
Rep 164
2014 F30 335i xDrive 6MT - Pure Stage 2 GFB DV / Inlet | XDI-35 HPFP | Fuel-It PI w/ AIC and LPFP Upgrade | BM3 | Fabspeed Catted DP | Dinan axle back | VRSF Race FMIC/CP | Dinan CAI | KW V3 | Wiechers CF strut bar | Dinan ARB | Spec stage 2+ clutch SMFW | Full M Performance Interior | M Performance BBK | Vorsteiner VFF107 MPS4S | Jordan Tuned Full E85 - 558WHP/520TQ on Mustang Dyno
07-28-2019, 11:49 AM | #20 |
175
Rep 211
My thinking on that subject is to flash back to stock for routine service visits. Assuming nothing seriously wrong, more in depth scans will not likely happen. That way you're not getting your car flagged as tuned and possibly having small unrelated things denied.
Of course, should something major go wrong, own up to the tune. They're going to find it anyway and no reason to damage your relationship with your SA and dealership by lying about the tune. Just my opinion, I certainly could be wrong.
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
07-29-2019, 09:15 AM | #21 | |
1106
Rep 1,499
Yes I'm SPI Films on Youtube. Thanks, I love the way the car sounds. I now have my burble setting perfected. I'm not a fan of the loud gunshot or even the pops so I have it set to give a nice grumble on decel. I've had no issues with the clutch/tranny and have almost 73,000 miles on the car.
07-29-2019, 09:20 AM | #22 | |
44
Rep 83
