drive belt replaced, new one is now squealing
07-16-2019, 04:28 PM | #1 |
Rep 7
had my car in the shop last week(2010 335i, n54), mechanic noticed my drive belt was worn so he replaced it. the next day my new belt was squealing which had never happened before, I brought it back to him and he just put lubricant on it, sound gone. he told me it just needs to break in. now a week later after a long drive my belt is squealing again. should I just go to auto zone and buy lubricant to put on it or should I bring it to a different mechanic and just get it replaced? this noise just started from my new belt so I believe the pulleys and bearings are all fine and its the belt specifically. could the belt have been installed wrong/misaligned or be the wrong type? I checked ofhg for leaks and looked for oil on the belt but its all dry, everything appears fine.
07-16-2019, 05:14 PM | #2 |
3058
Rep 3,910
First, don't lubricate the belt! You can get spray stuff that helps them grip, but it's a temporary bodge.
If the new belt is good, which it probably is (because it presumably fits correctly), one or more of the pulleys is probably bad. Or the tensioner. Or the crank vibration dampener is about to disintegrate. My dilemma would be, do you take it back to the mechanic who fobbed you off with the anti-slip nonsense, or do you pay someone else to sort out his mess? Good luck with it either way! |
07-16-2019, 05:32 PM | #3 | |
Art Collector
2425
Rep 3,448
When I'm dead, just throw me in the trash.
07-16-2019, 05:42 PM | #4 |
Rep 7
ok ill take it to a more reputable shop, I used a kind of dumpy indy shop because their two blocks away and I didn't think simple things like this could be messed up. Im having a hard time believing the pulleys were bad because its ran seamlessly until the new belt was put on, do you think this job being botched could have damaged anything?
07-16-2019, 06:04 PM | #5 |
3058
Rep 3,910
No, I doubt it will have caused any damage. May need to clean whatever the last shop used to stop the squeak off the pulleys. That said, they did manage to botch a belt replacement...
07-16-2019, 08:43 PM | #6 |
108
Rep 148
Belt slippage squeal usually only happens under acceleration then stops. If you have noise at idle or while steady smooth cruising, it's likely a pully. Replace the tensioner if it was not replaced with the belt.
07-16-2019, 08:48 PM | #7 |
2440
Rep 4,330
I'd be willing to bet he sprayed some lube at the backside of one of the tensioners and it was quiet for a week.
do not neglect this. broken belts kill n5x engines. it's worth it to buy the complete kit. This is an excellent opportunity to save some money, as it's a very easy DIY to do the belt and pulleys with minimal hand tools. |
07-17-2019, 07:24 AM | #8 |
1903
Rep 6,968
DO NOT use belt dressing. Something is a miss here.
I'd buy a kit from FCP Euro and take it to a reputable place that specializes in European Auto's and have them use your kit to replace the belt & pulleys etc. |
07-17-2019, 08:00 AM | #9 |
21
Rep 41
More than likely pulley (bearings) are worn out.
The last belt was stretched enough to not put as much pressure on the pulleys. The new belts is shorter putting more pressure on the bearings which is more than likely where the noise is coming from. |
07-17-2019, 08:08 AM | #10 | |
2341
Rep 3,539
Try to locate the writing on the belt, should say CONTITECH 7PK 1860 Last edited by Wolf 335; 07-17-2019 at 08:16 AM.. |
