07-16-2019, 12:24 PM | #1 |
127
Rep 192
Bootmod 3 in California
My warranty will expire in about 6k miles on my 2016 435i. Looking forward to doing a flash tune (considering BM3). Still debating whether stage 2 is worth it for me in California with smog test req. If not stage 2, is stage 1 "good enough" and worth it by itself? I know the basics, need a new chargepipe and intercooler, maybe an intake. I already have a catback exhaust. I don't think I can go catless downpipe, but im reading stage 2 needs a DP. If anyone in California is in the same dilemna as me, pls share some thoughts.
07-16-2019, 12:46 PM | #2 |
1478
Rep 1,286
I think Stage 1 by itself is absolutely worth it. The power increase quite significant (60-70hp at the crank) and adding an intercooler will improve it further.
I do believe there are some catted downpipes that will not throw a CEL and still comply with emission regulations, and will allow you to then flash Stage 2, but maybe other users can chime in more on that. |
07-16-2019, 01:14 PM | #3 |
Resident Pedant
503
Rep 792
Some counties in California will perform visual inspections and catted downpipes will fail those. If you just get sniff tested, you'll probably be good to go with a catted downpipe. You might want to look into the legal penalties for being caught with CA-illegal equipment a la a downpipe. Not finger wagging, just saying.
I can't speak to BM3 but MHD Stage I is definitely worth it for me with an otherwise stock car. I can get 93 octane here though.
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ Last edited by Phyrexia; 07-16-2019 at 01:20 PM.. |
07-16-2019, 01:57 PM | #5 | |
370
Rep 552
I have all installed components to run BM3 Stage 2 (except gapped plugs) and I'm more than happy with BM3 Stage 1 at the moment. Running CG Catted DP + CP + FMIC + Catback in Los Angeles. I chose catted for a less raspy note with my AWE + minimal smell (and no CEL is nice) |
07-16-2019, 03:18 PM | #6 | |
127
Rep 192
yoon_209363.50 |
07-16-2019, 03:29 PM | #7 | ||
Luxury at the redline :)
9105
Rep 7,563
07-16-2019, 03:49 PM | #8 | |
1999
Rep 2,499
We pay a smog abatement fee every year of $20 but for years 7 & 8, that was raised to $25. So basically we pay $5 more per year to skip years 7 and 8. Fine by me. Probably bad for mechanics that do smog checks. I think everyone who wanted to modify their cars are finding ways around the smog checks and everyone who doesn't really don't have emissions issues the first 8 years of a modern car's life. So the smog checks are kind of pointless. California would need to increase enforcement efforts if they wanted to make a difference so they're just making it easier for the honest people, basically, by not requiring a smog test when new cars really don't need them if kept stock. |
Poochie9104.50 deezeedee33532.00 |
07-18-2019, 11:40 AM | #9 |
32
Rep 86
I am FBO and BM3 stage 2 in Nor Cal.
If you are very hands on with your car it should not be an issue. It roughly take me 30 minutes to change the down-pipe out of the car. Takes me longer to get the car on jack stands and remove the bottom engine cover. I have done it numerous times when I had to take it in for dealer service and recall work when I was under warranty.
2013 F30 335i PWG
VRSF DP/ VRSF FMIC/ ER CP/ AFE Intake Filter/ PowerStop Brakes/ Custom Exhaust/ BM3 Stg 2/ AEM Water Methanol Injection/ MotorSports Hardware Studs, Locks and Spacers |
07-18-2019, 03:30 PM | #10 |
215
Rep 558
Keep your OEM downpipe and just swap it in when time for smog check. bm3 catless all day.
deezeedee33532.00 |
11-04-2020, 01:43 PM | #11 |
Rep 16
bootmod3
I an a little confused about bootmod3. I have a 330i G20 and want a bootmod3, but I live in Cali. So would a stage 2 not be able to pass smog? or what is the best way to go at this.
11-04-2020, 02:39 PM | #12 | |
4364
Rep 7,607
"Starting January 1, 2019, if your vehicle is less than 4 model years old, you can pay a smog abatement fee instead of getting a smog inspection for the first 8 years that your vehicle is registered." https://www.dmv.ca.gov/portal/vehicl...g-inspections/ So you won't need one until 8 years after the vehicle was originally registered. You should be aware however it is technically still illegal to do any modification (except those CARB approved) that affects the emission control system (as all the disclaimers on websites state), but you wont have to actually go get checked unless you get pulled over and get a state ref or something. Typically not a concern people worry about, but just so you are aware. So basically, do whatever you want for now, and if you still own the car when it is 8 years old, be prepared to swap back in the OEM DP or get one that will get your emissions monitors into ready state. |
11-04-2020, 04:59 PM | #13 |
Rep 63
BM3 stage 1 is a great amount of fun. Im basically waiting to go stage 2 until I get the sport cat downpipe next year. Also cool with BM3 is that you can buy one map then all maps for only $50 additional.
2014 335i M-Sport, CTS intake, VRSF FMIC, VRSF CP, BM3 stage 1
11-05-2020, 01:32 AM | #14 | ||
Rep 16
11-05-2020, 10:04 AM | #15 |
13
Rep 196
Stage 2 all day, Im in Nor Cal and just swap the DP back to stock, flash it back to stock, drive for about 100 miles so everything can reset and bam, easy smog test done. then put the DP back on flash, and your back to having fun. Smog is every 2 years so its not much of an issue, and the fun is worth it. You might even start craving more and better to already be catless when that itch hits
11-05-2020, 05:38 PM | #16 | |
4364
Rep 7,607
11-05-2020, 05:39 PM | #17 | ||
13
Rep 196
True, all the better to do this now and enjoy it even longer |
02-13-2021, 02:24 AM | #18 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
So I think I got flagged by state ref because of my tune? Maybe it was random?
Took all my parts off and tuned the car back to stock but I didn’t relock it, thinking it would be fine. Went to get the car smogged and it got flagged to get inspected by state ref. Swapped the tune to stock but this time relocked it, hopefully this won’t be an issue... |
02-13-2021, 09:15 AM | #19 | |
Check out my Youtube @n55david!
1296
Rep 3,533
Drives: 2017 m240i, 2015 X3 x35i
2017 m240i xDrive 10.99@122.86mph bootmod3 stage 2+ ots
2015 335i xDrive 10.95@124.99mph w/bm3 - SOLD 2015 X3 x35i pwg 12.96 catless w/bm3 stage 2 93 ots IG: @n55david For pics and updates! Youtube: @ n55david For videos or Racing etc |
02-13-2021, 03:23 PM | #20 |
Instagram: @bmwdriven_
51
Rep 119
02-16-2021, 11:33 AM | #21 | |
4364
Rep 7,607
02-16-2021, 11:54 AM | #22 | |
32
Rep 90
In my opinion, if relocking the DME keeps the dealership from being able to detect tampering, then technically CA smog test stations wouldn't be able to either. Can anyone confirm relocking the DME keeps the dealership from detecting tampering? Last edited by GAB0; 02-16-2021 at 12:00 PM.. |
