Is there a fuse that has power when ignition and accesories but not off
07-15-2019, 07:00 PM | #1 |
2657
Rep 6,290
That's my fuse diagarm. Icons. No idea how I'm supposed to know what they are exactly it's only categorised... so I'm asking here. I'm wondering if there is a fuse that has no power when off but has power on accessories and ignition. I already tried 08 (I think it's for cig lighter/12v) with a test light and only has power on ignition. |
07-16-2019, 03:27 PM | #3 | |
2697
Rep 4,031
TIS can. For your 2011 335is the TIS schematic is NOT as clear as for earlier models, but if you look at the Terminal 30G (KL30g) fuse distribution at the bottom of the schematic, you will see 20 different fuses that have their source power (B+) SWITCHED by "IO1068" which is the "Terminal 30G Relay." https://www.newtis.info/tisv2/a/en/e...box/1VnXpW4emV The fuse you identified, F63, is NOT ignition-switched (Terminal 15 or KL15), NOR is it Terminal 30G-switched. It is directly powered by the battery with NO intervening relay per this F63 circuit: https://www.newtis.info/tisv2/a/en/e...3-fuse/jQYinmG You don't say WHAT you want to add to be powered, or what its current draw or use may be. It is generally safe to add accessories to the lighter circuit which is ignition-switched (Terminal 15 or KL15), but make sure you read Bentley or get reliable advice from someone knowledgeable in BMW Electrical Systems BEFORE adding an "Electrical Consumer" to any other circuit. George |
07-16-2019, 03:33 PM | #4 | |
2657
Rep 6,290
So are you saying that fuse F63 should be sending power even when the car is off? I'll double check with my test light but pretty sure it wasn't. It's just for a dash cam so only 1.5A draw I'd say. F63 fuse from my understanding has to do with the garage mirror control's antenna? |
07-17-2019, 04:55 PM | #5 | |
2657
Rep 6,290
BUT if it's currently empty does that mean it is not in use in my car? So I could tap a fuse tap and only put one fuse in my fuse tap for my dash cam circuit? I would like to swap my fuse tap to that one when I go at a dealer to record what they do. |
