BMW
X7 and XM
forum
BMW X7 (G07) Forums General BMW X7 Forum Side mirrors in reverse
      07-13-2019, 10:58 AM   #1
dmann33
24
Drives: 07 650i
Is there way to disable the side mirror from pointing down in reverse? I’ve scoured I drive and can’t find a disable option.
Thx!
      07-13-2019, 11:44 AM   #2
///WeissBisBlau
///WeissBisBlau's Avatar
265
Drives: ‘21 M5C
Believe you may have options to disable this in iDrive, but one quick and dirty trick you can use is to simply switch the mirror adjustment switch to the passenger side, as I believe the tilt down feature only works when it is set to the driver (left) side.
dmann3324.00
      07-13-2019, 03:41 PM   #3
Missduvy
288
Drives: 2019 X7 50i
I tested this today and you’re correct. How on earth did you stumble across this trick?
      07-13-2019, 03:51 PM   #4
jokinawa
293
Drives: 2019 X7 40i
This has been around since at least 2016 as my 3 series had it.
If my post was informative or helpful, please click the appreciate button. Thank you.
      07-13-2019, 04:45 PM   #5
///WeissBisBlau
265
Drives: ‘21 M5C
Ha ha. Well, I guess it’s just the way it was designed. I haven’t tried it in awhile, but I believe my 2013 M3 also does it.
Unfortunately, I looked in the iDrive menus for awhile, for a way to change the “dip” setting. Maybe it is there, but I could not find it
      07-14-2019, 06:18 AM   #6
X5_CC
X5_CC's Avatar
289
Drives: X5 40i
I tested this today and you're correct. How on earth did you stumble across this trick?
Just FYI, this is pretty standard across the car industry. Every car I've owned of different makes is like that (except opposite from what's described... move the switch away from passenger side to turn off)
      07-14-2019, 03:05 PM   #7
Wild Blue
Wild Blue's Avatar
3684
Drives: 2021 X7 M50i, 2004 330i w/ZHP
My 2004 330i even does this!
xbimmers
