Question about the door locks.
07-13-2019, 06:47 AM | #1 |
45
Rep 418
My doors would unlock or lock with my remote or button in the car. I found the problem was a fuse and replaced it. None of the doors would open when locked. I couldn't even open them from the inside. The only way I could get out was by rolling down my driver side window and putting the key in the lock to unlock it. It was a pain to change the fuse because I couldn't get the passengers door open. Would this be a major safety issue if there was an accident and the power to the battery was damaged? No one would be able to get out.
Is there a trick to getting the doors open when this happens? |
07-13-2019, 09:46 AM | #2 | |
2697
Rep 4,031
https://www.newtis.info/tisv2/a/en/e...tlputs/dWHzxgC https://www.newtis.info/tisv2/a/en/e...inputs/dPBLOhG If your doors are locked at this time, and your remote key will NOT unlock any of the doors, then use the mechanical key to get in the driver seat, reach over to passenger door interior handle & pull that handle twice. If that door does NOT open, post back. If passenger door DOES open, check F56 & F57 ELECTRICALLY, and replace if NO continuity across fuse spades. After installing good fuses in F56 & F57, test: (1) remote lock/unlock, (2) mechanical key lock/unlock (Turn Counter-clockwise TWICE -- 1st time unlocks driver door, 2nd time unlocks other doors), (3) Dash button lock/unlock, and (4) each door lock plunger and door handle double-pull. If one or both fuses were blown, you may have a wiring or lock motor fault which will blow replacement fuse(s), so test functions as described above if ANY fault recurs and also let us know if you have, or have access to, ANY BMW-specific Scan Tool or Software, such as INPA. Please let us know what you find, George |
07-13-2019, 09:59 AM | #3 | |
14
Rep 76
07-13-2019, 04:51 PM | #4 |
45
Rep 418
I figure out what fuse it what but none of the doors would unlock by double pulling the handle or by using the key fob or using the lock/unlock button on the dash. Basically if I was locked in the car unless I rolled the window down and unlocked it by putting the key in the drivers side lock.
07-14-2019, 12:43 AM | #5 |
101
Rep 535
I had my locks blow and a similar thing happen. It’s lretty stupid actually. They should default to unlocked. It’s a major potential safety hazard if you’re in an accident and need to get out of the car quickly.
07-14-2019, 06:44 AM | #6 |
45
Rep 418
That was my thought. I was hoping there was some sort of trick to get the doors to open. It was hard to change the blown fuse without being able to open the passengers door.
