Radiator Fan
07-12-2019, 11:59 PM | #1 |
Rep 4
Radiator Fan
Hi, I have a question maybe someone can answer. My temp got to 103C and still, the fan had not turned on, I know it supposed to come on way before. I did a fan test with a diagnostic scanner and it works at 50% and 90%. My question is this: What sensor and where is it that gives the signal for the fan to work?
Thanks |
07-13-2019, 02:39 PM | #2 | |
2697
Rep 4,031
That is essentially Top Radiator Hose Temp, and Bottom Radiator Hose Temp. If your model does NOT have the Radiator Outlet Temp Sensor installed in the Bottom Radiator Hose, INPA provides a "Calculated/ (faked ;-)" ROTS value which is EXACTLY 7.5C LESS than the ECTS Value, regardless of temp or engine conditions. Does your Scan Tool provide you with BOTH ECTS and ROTS values, and if so, what is the differential? I would check to see if you have any sensor at your lower radiator hose, and if NOT, check the ACTUAL temperature at the ECTS housing (OFH) using an Infrared Thermometer, to see if it is within several degrees of the Temp Parameter your Scan Tool is reading. In another thread, you said your engine could idle "for 1..2 hours and the temp never gets beyond 92--96 /197F..204F" so obviously the Fan IS coming on, but it may NOT ever run at as much as 50% (unless A/C on), but then you do NOT need A/C at the moment in Wellington. You can download Bentley Service Manual in searchable pdf format here: http://www.georgebelton.com/335i.tech/bentley.php Here's what Bentley has to say about Inputs to the DME which it "sorts" to determine Fan Speed, and other Fan Trivia (170-3, p.356 of pdf): Electric fan activation is based on the following inputs to the ECM:If your Fan "flunks" the Self-test described above, you should find BMW FC 2EFF saved in DME Fault Memory. So if you have NO ROTS in your 335i, the primary input used by the DME to activate the fan is ECTS signal/ temp reported to DME, in conjunction with vehicle speed, and Refrigerant Pressure Sensor signal. As to the latter, when you turn on the A/C with the "snowflake" LED LIGHTED on right of A/C Control Panel, (to dehumidify, even if you don't need to cool the air ;-) the E-Fan should run @ ~ 50% speed at idle (heat transfer @ condenser). Per your other thread, it would appear you have an intermittent fault in the ECTS or its associated connector/wiring. Please let us know what you find, George |
07-13-2019, 04:11 PM | #3 |
Rep 4
Hi, thanks for that response. Once I get my head around what everything means I will check it out. Yes, you are right we don't need an Aircon here just yet thanks again!!!
