BMW
X1 / X2
BMW X1 (F48) and X2 (F39) Forums General BMW X1 Forum (F48) Jb4 install
      07-10-2019, 04:14 AM   #1
Gussyldn
Drives: X2
Exclamation Jb4 install
Hi everyone anyone know how to get the obd cable of the jb4 from the engine bay to inside the cabin thanks
      07-10-2019, 11:00 PM   #2
808X1
80
Drives: F48 X1 M-Sport
On the driver side (LHD), when you pop the hood up, there's a black grommet covering a hole in the firewall. Shine a light in that corner of the engine bay and you will see it. Remove that grommet piece by peeling it off the firewall. Either make an X slit in the grommet, or drill a hole in the grommet, big enough to fit the OBD cable through. Once the cable is pulled through and passed into the engine side of the car, replace the grommet back into the firewall.
      07-11-2019, 04:22 AM   #3
Gussyldn
Drives: X2
[QUOTE=808X1;25013879]On the driver side (LHD), when you pop the hood up, there's a black grommet covering a hole in the firewall. Shine a light in that corner of the engine bay and you will see it. Remove that grommet piece by peeling it off the firewall. Either make an X slit in the grommet, or drill a hole in the grommet, big enough to fit the OBD cable through. Once the cable is pulled through and passed into the engine side of the car, replace the grommet back into the firewall.[/QUOTE
Thank you my car is RHD unfortunately but I’ll still try
xbimmers
