Eibach 28mm front Sway-bar. Will it be noticeably flatter on corners?
07-08-2019, 05:21 PM | #1 |
30
Rep 142
Drives: 2011 328i sport
I apologize if this has been covered but I did try the search first.
Looking to upgrade to Eibach 28mm front sway-bar (non-adjustable). I have a 2011 328i with sport package with 18" square tire setup. Has anyone swapped this sway-bar on a 328i sport? I would like to know how much less body roll you experienced? and I know it is adding understeer but do you notice that in quick daily driving? aka - not at the track. |
07-10-2019, 01:07 PM | #2 |
226
Rep 290
I have that exact sway bar on my 325i, definitely noticeable improvement (stock front struts) after install. Less body roll in the front for sure, the polyurethane bushings do make some noise tho but it does not bother me.
07-14-2019, 08:41 PM | #4 |
52
Rep 164
I put the e93 m3 28mm front bar on my sport suspension 335 and it made a big diff in roll and bite, needed bigger tires to take advantage of the flatter attitude, so 245s on the front now with pins pulled and m3 control arms up front. No more understeer!
07-24-2019, 01:36 AM | #5 |
67
Rep 393
Drives: 2015 M3
I have the eibach 28mm front sway bay installed on my car it definitely reduced alot of the body roll my car had in turns. No real down sides. I also have BC coilovers with the adjustable sway end links.
Harry I.
Los Angeles 2011 AW 328i 2015 AW F80 M3 |
thormessiah164.50 |
07-24-2019, 11:39 PM | #6 |
2896
Rep 3,726
Yes I run both front and rear eibach sways. Noticeable improvement, especially paired with the m3 strut tower. Turn-in is greatly improved.
2017 F80 M3 ZCP / AA GESI DPs / Akrapovic Evo / BBS FI-R 19" / Bend Calibration ECUTEK Flex Fuel | Bilstein B16 DDC + CS EDC / BMC Filters / BMS OCC / CSF HE / ESS CP / Nitto NT555R2 / PD Crank Hub / SPL Suspension / Uniden R7 / Wagner Top Mount IC
2021 Mini GP3 / BMC Filters / BM3 / Cary Jordan E30 / Wagner IC / Remus Race |
08-05-2019, 10:34 PM | #7 |
165
Rep 1,402
Drives: 06' E46 M3 ZCP
did you use your stock end links or did you also add the M3 ones?
19’ F90 M5C | Signature VS-104 | M-Performance | IND | H&R
06’ E46 M3 ZCP | Karbonius | Ohlins | Vorshlag | Turner | Kassel | IND | Status Gruppe | Macht Schnell 03' E39 M5 | 100% Stock |
08-06-2019, 11:57 AM | #8 |
471
Rep 996
I installed e93 m3 bushings and front sway bar recently. Used stock end links. On stock control arms with new all around OEM suspension.
The turn in is noticeably quicker and flatter, I would recommend the mod. However, it changes the balance of the car, sort of in a weird way. I’m not sure if it’s just in my head, but it’s almost like the front is dialed in but the rear is still it’s old floaty self. It feels like the rear is trying to follow the front. This is versus the entire car feeling a bit like a boat in the corners with the original sway bars - at least it was consistent. Last edited by porsche959; 08-06-2019 at 12:04 PM.. |
08-17-2019, 11:56 AM | #9 | |
Daily Driver
107
Rep 199
08-17-2019, 02:19 PM | #10 | |
1903
Rep 6,968
They give you both front & rear upgraded swaybars & bushings. If you have their springs, the swaybars are tuned to the springs. |
08-18-2019, 09:25 PM | #11 |
Guest
Rep n/a
Drives:
08-19-2019, 09:48 AM | #12 |
1903
Rep 6,968
You mean the lowering springs found on the b12 kit?
08-19-2019, 11:26 AM | #14 |
1903
Rep 6,968
08-19-2019, 11:41 AM | #15 |
Guest
Rep n/a
Drives:
08-19-2019, 09:13 PM | #16 |
eBay Special
3066
Rep 3,028
Drives: E90 330xi
Curious to see the drop of the Eibach Sportline springs on Bilstein B8s
Common sense is a flower that does not bloom in everyone's garden
08-19-2019, 11:37 PM | #17 |
No one sleep in Tokyo
945
Rep 1,507
Drives: 2011 E90 328i//1995 E34 530i
Below is a great, visual, representation of the difference between stock suspension and Eibach suspension + anti-roll(sway) bars.
Should answer your questions.
2011 E90 328i, 1995 E34 530i, 1992 E32 740i, 1991 E34 525i
mike512438.00 |
08-20-2019, 03:53 PM | #18 |
471
Rep 996
nice video, but some of those tests seems biased. especially the last braking test, they counter steered with the eibach kit, versus just letting the car swerve stock.
08-22-2019, 07:32 PM | #20 |
945
Rep 1,507
Sure, but some of the cornering footage shows the difference between aftermarket springs/+swaybar.
08-22-2019, 07:37 PM | #21 |
2896
Rep 3,726
IMO that video is pretty accurate before and after I did my suspension upgrades. Body roll stock was horrendous.
11-29-2019, 04:29 AM | #22 | |
87
Rep 236
Drives: e92 335iA
Highly recommend to any e92 owner, it truly converts the rather steering-dull car into a fun to drive machine .-)
"If everything seems under control, you're not going fast enough.” Mario Andretti
